Question about Garmin Forerunner 405 Handheld GPS Receiver
Can't get my GPS to turn on with the Garmin 405
I did my initial set up and it picked up a signal to set the time but when I go to training and hit start it shows GPS Off.
How do I get it on and off?
  • sbanot Dec 21, 2008
    I have the same issue, and i'm dying to get out there and give it a run.
    Somebody help, please!
  • sircon Apr 08, 2009
    I turned GPS off, now cannot turn it on again. I keep getting the "to location" site.
I too was frustrated because of this. I played with the watch until I found the solution. Hope this helps!
For some reason I needed to be in the training mode to do this.
From the Time/Date mode, do the following:
1.) Press the start/stop button (upper metal button) to get out of Time/Date mode
2.) Press the Training side of the bezzle. You will see a workout display.
3.) Touch the GPS side of the bezzle until "to location" shows up
4.) Press the lap/reset button (lower metal button) to display a menu (may have to do this a couple of times, eventually when you release the button the menu does show up)
5.) Slide downward through the menu options until you find GPS
6.) Click the start/stop button (upper metal button) to toggle the gps on or off
7.) Press the lap/reset button (lower metal button) to exit the menu (goes to the "to a location" screen)
8.) Press and hold the Training side of the bezzle to return to your training screen
Posted on Apr 26, 2009
Using the bezel push at 'GPS' until screen changes then select GPS by rubbing round bezel. GPS I guess will be showing that it is 'off'. Tap bezel at 'GPS' and display should change to 'GPS on'. I turn GPS off and on for every training session as apparently always leaving on drains battery power more quickly.
Posted on Dec 29, 2008
128 garmin ; takes long time to pick up signal and most the time it dos nt and keeps turning off .should i buy a sledge hammer
I wouldnt do that just yet (hit it with a sledge hammer I mean...lol) First make sure its fully charged up that could cause a delay and also cause it to keep turning off on you. After a full charge if it continues to do this then go to www.garmin.com At the top right of the page click on My Garmin and either set up an account or put your user name and password in if you know it. Then go to technical support and ask them about repairing your unit. Explain to them what it is doing and what would the cost be to have it repaired.
I hope this helps you out if it does please leave me a Yes that I did help you with your problem. Thank you.
Apr 06, 2011 | Garmin GPS 128 Receiver
How can I change my Garmin 305 from miles to kilometers?
Hit Mode till you see History,Training,Navigation, and Setting. Scrol to Settings using the down arows on the right hand side of the watch. On the same side of the watch hit Enter.
Hit enter on General.
Scroll down to Units (You can't see it right away, you have to scroll down) hit Enter on Units. There you can change to Metric.
Mar 17, 2010 | Garmin Forerunner 305 GPS Receiver
Compass 'pops up' in middle of a training run - want to stop this
You are in the mode that is used to navigate to a location. When the compass is up, hit the "quit" button, then select "stop go to" and it should stop.
Jan 25, 2010 | Garmin Forerunner 405 Handheld GPS...
Garmin 405
You have to go under Menu, then scroll to Settings, then scroll to System, then scroll to Language. Then you can scroll through the list of supported languages until you find the one that suits you.
Jul 02, 2009 | Garmin Forerunner 405 Handheld GPS...
GPS problems wit a Garmin Forerunner 405
The instructions say touch and hold GPS and to go outside away from tall buildings and to remain stationary for several minutes. Not really sure what their definition of several minutes is guess thats their way of saying "sit still for as long as it takes." If that doesnt work I would get in touch with Garmin. 1-800-800-1020
May 31, 2009 | Garmin Forerunner 405 010-00658-20
I cannot clear a 'to a location' screen
I too was frustrated with this one. I played with the watch until I found the solution... Hope this helps!
Apr 02, 2009 | Garmin Forerunner 405 Handheld GPS...
Turn off garmin
I just find it unbelievable that there is no off button on this watch. I dont want to use it as an everyday watch..its too big and ugly for that.Also you have to remember to turn off the gps as it will drain the watch overnight.You have to switch the gps on every time you do a run. I simple on and off button is all that is needed.It is just a matter of turning it on when you go for a run and you are ready to go. Same with all 'latest ' products..they give you the improvement over the last model but give you a downside...which will probably be corrected on the next incarnation....very clever marketing.!
Feb 03, 2009 | Garmin Forerunner 405 Handheld GPS...
Garmin 405 pair to wrong HRM
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80)
Jan 04, 2009 | GPS
Garmin Forerunner 405 always shows wrong time/date
Turn on the GPS. The forerunner will automatically sync time and date. Make sure the DST is switched to auto. I had the same problem and researched for the answer....which led me here. Turning on my GPS sync'd time and date for me. I hope this helps
Jan 02, 2009 | Garmin nuvi 200W GPS
Garmin 405 won't go into power-save mode
Use the GPRMC1 string for power saving mode
Dec 29, 2008 | GPS
Garmin Forerunner 405 Handheld GPS Receiver Logo
2,346 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
