Question about HP Office Equipment & Supplies
I would like to know when I can expect a replacement printer. I have allready been told but I lost the paper the date was on.
  • HP Master
  • 4,806 Answers
All you have to do is contact the supplier you bought or returned you printer to and they will be able to track for you, most deliveries are between 3 to 5 working days if they are replacing the printer
Posted on Nov 16, 2008
  • HP Master
  • 6,487 Answers
For the replacement of this printer you need to contact HP support since they are the manufacturer of your printer and they will also the one who will replace it...
50.2 fuser error issue. I had a paper jam that I pulled out. Now 0I get this code. I turn off the machine, pull the plug, remove the fuser and let sit for 30 minutes. I revise and boot up the printer...
I suggest you should contact Hewlett Packard technical support or a local service provider for further assistance as you have allready compleated all of HP's reccomended actions with no result.
Mar 01, 2011 | HP LaserJet 2840 Printer
Canon Selphy 710. The rollers don't grab the paper. Can this be fixed or do I have to buy a new printer? The drivers are up to date.
Had the same problem after not using the printer for many months. Removed the feed tray and blew into the printer. Then printed something but gently pushed the paper a few mm until the printer took it. Obviously top of the paper tray has to be removed for this. Expected to have to do this every time, but after four prints (which incidentally were perfect) it now works like a dream, taking the paper without attention.
Dec 15, 2010 | Canon SELPHY CP710 Thermal Photo Printer
My printer will not feed the paper from the tray.
Have you told the printer what type of paper you are using? If,for example, you were using a heavy weight paper, like a 67 bond paper, and now you want to use a regular 20 pound paper, but have not told the printer about the change in paper weight, then the printer will not feed your paper properly. It is expecting to have to move 67 pound paper through the rollers which move the paper, but is encountering a 20 pound paper. That difference in paper weight will cause your printer to spin uselessly, trying to move a very light paper into the mechanism.
Try to set the paper properties to match the weight of the paper you are actually using, such that the paper and the mechanism, are equal and see if that makes a difference.
Dec 06, 2009 | Samsung CLP 300 Laser Printer
CAN NOT PRINT COLOR -PRINTS PINK STRIPES
Take some paper towels, fold them in half, spray them with alcohol FREE glass cleaner and set your color cartrige on the paper towels and let them soak for thirty minutes or so. DO NOT USE ALCOHOL it sets the ink. also clean the thin plastic strip in the back of the print heads this is the encoder strip and it tells the print heads when to dispense if this is dirty from overspray it will affect your print quality. Use q tips and the same alcohol free window cleaner.
Jun 04, 2009 | HP Officejet 9110 All-In-One InkJet...
Epson stylus C43UX. my printer keeps saying paper jam and paper not loaded correctly and just spills out the paper i load. the paper is loaded perfectly but it just wont print! the stupid red light just...
The printer reports a paper jam because the paper feed system cannot feed paper.
Look down into the place where the paper goes (the "automatic sheet feeder" or ASF) and you should see a fat wheel with a grey ribbed rubber facing. Place a single sheet of paper in the ASF and do a test print (right click the printer icon and select properties). Watch to see what happens in the ASF. The plastic panel behind the sheet of paper should move forward to push the sheet against the rotating rubber wheel, which should then feed the paper into the print position. This is presumably not happening! Can you what does happen?
If the expected movements are not happening, you need to remove the printer top cover to see what the problem is and resolve it - perhaps the ASF has come loose or something. This is easy if you know how to do it - otherwise it's likely to cause you to take a large hammer to the task! If you need help on this, please report back with a new post.
Mar 27, 2009 | Epson Stylus C43UX InkJet Printer
Error code jam 2displays after removing paper jam. Samsung printer SCX 4100
Ross,
You have had several excellent solutions brought forward in your premium post, especially to look for little pieces of paper that interfere with the LED lights and the light sensor for that area that sends a paper clear or paper occupied signal to the printer.
When this type of issue arises it is normally after the normal term of life the engineers who designed the printer expect from the printer. Most all rollers have sleeve bearings on either end and these bushings become eccentric vs. round after a predictable amount of print jobs. When these holes do become eccentric one side of the roller turns slightly faster than the other that actually has difficulty keeping up with the other end of the roller. This will cause paper to feed at an angle through the paper path.
Ultimately this leads to a paper jam. Once you begin to have one jam, here and there, you eventually have jams more and more often. When this occurs and actually prior to this series of events, the printer has reached its end of life expectancy. This is a value expressed in pages printed per month or months of service where the engineers expect so many pages per day to be printed. This whole design and life expectancy is exactly the same for copiers and why Xerox, for example, has to come on site at the job or library and do a system overhaul. These overhauls are a replacement of bushings and belts used within the power train.
What this all means is that your printer is either outside its life expectancy and probably its warranty as well.
If you are still in warranty, don't mess around trying to find a band-aid fix for this problem and have it serviced under warranty. You'll receive a refurbished machine in return. This is the best way to proceed. If you are out of warranty and like the machine get a refurbished one.
So, to repeat:
a. Look for small pieces of paper that could be blocking the light sensors and sending a paper jam signal to the printers CPU.
b. If you are out of warranty get a new printer or refurbished one.
c. If you are in warranty get it replaced under warranty for a refurbished model.
Regards,
Worldvet
Any questions? Please use the comment box below to respond.
Aug 25, 2008 | Samsung Office Equipment & Supplies
My printer is stop printing
are these still current issues?
Aug 13, 2008 | HP DeskJet 3745 Printer
Epson stylus photo r1800
Return it to them. If it is under warranty, they should replace it.
Oct 06, 2007 | Epson Stylus Photo R1800 InkJet Printer
13 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
