Question about Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive
My hitachi nra 83 a2 doesnt fire ...when you plug it to the air hose ...air comes out of the top ... it doent fire
  • 23 Answers
You need an o-ring repair kit. the part number will be located in your owner's manual. a blown upper o-ring is usually due to leaving it out in the weather for extended periods of time or hooking it up to a compressor with a psi regulator set over 120.
Posted on Nov 17, 2008
Why won't feed plunger advance nails?
The two hex head screws on the very top of the head hold the air deflector and attach to the headvalve (the part inside the head with rubber coating, this headvalve has a gasket under that should be check for proper alignment ). Other small screws that look like set screw are only plugs that are removed to install auto control hoses in factory work. These are only plugs so just put them in a few turns with locktite.
Jan 23, 2013 | Hitachi Tools & Hardware - Others
I have a 2002 gallant and the heat doesnt blow warm air..any thoughts?
Make sure that the radiator is full and if you still dont have hot air then check to see if the top rad hose and the bottom rad hose are hot after driving for 30 minutes. Now if the bottom rad hose is not as hot as the top hose then replace the thermostat. If both the hoses are hot then check the two hoses going into heater core at the fire wall, both of the hoses should be hot, if not then problem is in the heater core.
Nov 08, 2011 | Cars & Trucks
I have a nv45ab roofing nailgun & it blows air out of exhaust on top any sug.
Hitachi nailers use an unusual design of actually moving the cylinder to fire instead of moving the headvalve. If the cylinder gets stuck in the open position (down), air will leak out of the head. To reset the cylinder, remove the nails and connect air supply. With air connected, lightly rap the head of the nailer against coiled air hose or soft rubber (too hard of a hit could damage the head). If after a couple of hits air still leaks, remove head and check headvalve for cracks. Replace as needed. If headvalve rubber looks ok, remove cylinder and clean/lube. If cylinder has fine scratches where orings make contact, sand smooth with 400 grit sandpaper. Lube with silicone paste, white grease or nailer oil.
Jul 29, 2011 | Hitachi Tools & Hardware - Others
I changed the feeder springs in my hitachi NV83 a2 and it wants to double fire and jaming up the driver with seconded nail. it was skip nailing before i changed springs. any help you could give me would be...
Your nailer is a very heavy duty nailer with very powerful blow. Works best with full size nails, not 2 inch range that are used in fencing, they are not spaced correctly for your gun (like hitting number 6 nail with sledge hammer). Open side door and remove the nails, leave the door open and dry fire gun against piece of rubber or old coiled air hose. The driver should return all the way up between shots and the feeder should move back then forward just as fast as the driver moves. If the feeder seems to move in slower motion then pull feed piston and replace orings and remove debris from feed cylinder. If the driver seems to stick out further than normal then lower bumper could be breaking up causing debris to enter feeder. Make sure that the driver is not bent and has a squared bottom, if rounded, remove and grind square. Finally adjust the depth control up or down slightly and bump fire for test, do not place gun on the work then fire. good luck
Jun 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
When firing nailer first nail shoots good but next nails head will get stuck between the push rod chamber. push doesnt seem to return fully top when nail is cycled.
Try oiling the tool first. Remove the nails, squirt a decent amount of air tool oil in the stem where the air hose coupler connects, and fire the tool a dozen times or so. Then put in the nails and test. If it still hangs up then it will need the o-rings replaced.
Jun 11, 2011 | Porter Cable Coil Roofing Nailer
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
83 SILVER SPUR,FIRING ORDER?
The firing order is A1-B1-A4-B4-B2-A3-B3-A2. left side being B bank.
If you need schematics and are in the USA, try ALBERS in Zionsville for all you R/R needs.
They are very helpful and will download or fax you copies of wiring and spec's you need although if not buying parts they may charge for faxes.
If your in UK try the guys at phantommotorcar@aol.com or look them up on Google.
Jan 14, 2011 | Rolls Royce Silver Spur Cars & Trucks
Nail gun is miss fireing sometimes might only fire 1 in 4 nails fired
remove all the nails and remove the air hose. BUMP the tool on something and does the driver come down on its own if so it needs new o rings. also take a look at the feed pawl for a broken spring that would prevent it from feeding nails and lastly look at the coil of nails to make sure they pull freely. Let me know if you need more assistance.
Sep 10, 2010 | Hitachi Tools & Hardware - Others
The front cylinder on my 83 honda shadow 750 doesnt seem to be fireing it has new plugs its getting spark, is it possibale that only on cylinder is getting gas? i take the plugs off when the bike is...
the carbs need to be cleaned out, the front carb has a stopped up low speed jet. If you have already cleaned them then they need to be synchronized. Cleaning means removal and dis-assembly, you cannot get to the jets by spraying cleaner in the air intake.
Jun 06, 2010 | 1984 Honda VT 500 C Shadow
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Circuitry open/shorted.
  • Damaged folding top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Parking brake not engaged.
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top motor upper and lower hose .
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Damaged fluid reservoir.
  • Go to Pinpoint Test D.
Jan 04, 2009 | 1989 Ford Mustang
Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive Logo
243 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Roger Paull III
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
