Question about Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
Pairing blackberry curve 8330 with parrot 3200 LS
The Parrot 3200 LS device works fine once it is paired with my Blackberry 8330 but some times it takes a long time, some other doesn't even pair with the blackberry. Any alternatives to restarting the car over and over again?
Thank you!
SOURCE: Pairing Jabra BT4051 to my blackberry
I paired my BT4051 with my BB curve just fine. I held down the power button on the Jabra until the blue light was solid and then added the device through my BB's bluetooth setup under options.
Posted on May 27, 2009
  • 132 Answers
SOURCE: Problem transferring contact list from BB 8330 to Parrot 3200 LS
I had the same issue with my Nokia phone a long time ago. To solve that issue I had to upgrade the Parrot's firmware with the laptop through bluetooth connection while in the car. I have done this a few times to get the most out of my parrot.
I recently got a Blackberry and had no issues with the contacts whatsoever. I do have to say that I dont have 500 contacts, but only 130.
If I were you I would try to update the Parrots firmware to the latest one available in the parrots website.
I am not sure if the parrots has a maximum contacts restriction. That might be also your problem.
Hope it helped.
Posted on Nov 26, 2009
Testimonial: "Thank you. I shall take your advice and upgrade the firmware. When (if?) I'm successful, I'll post my experiences."
  • 21 Answers
SOURCE: pairing nokia n96 with parrot ck3000
Try sending an MP3 to the Parrot kit. I couldn't even get the Parrot BT in my car to ask for the BT password numbers but found out to try sending an MP3, which will fail by the way, and it asked for the password finally.
There was an error in my case, but then the phone asked to connect to the Parrot again and the pairing worked.
There is an issue with newer Nokia phones, something I will be thinking about next phone upgrade.
Posted on May 11, 2010
supernova278
  • 1932 Answers
SOURCE: how do i pair my
The first time that you switch on the 3200 LS-Color, you must pair your mobile phone with the kit.
1.Enable the Bluetooth mode on your phone.
2.On the hands-free kit, scroll through the menus until you come to Settings Pair with phone and select the relevant option for your phone. A 4-digit PIN code then appears on screen. Memorize it.
3.Then from mobile serach the 3200 LS-Color device
Once the search has finished, "Parrot 3200LS / Parrot 3400LS" is displayed on your phone.
4.Select the kit. Your phone prompts you to enter a code: key in the code shown on the kit screen and confirm on your phone.
5.The kit's screen displays "Pairing".
6.Once the data has been exchanged, "pairing successful" appears on the 3200 LS-Color.
Thank You
Posted on Oct 08, 2010
dancandoit
  • 436 Answers
SOURCE: I have just bought a new apple I phone 4. I can
remove all the previous paired phones from the parrot memory and then try again. if this dont work then you will need to have the software of the parrot updated. You can do this yourself but you will need a laptop with bluetooth. then download the software from parrot web site.
Posted on Feb 25, 2011
PAIRING PARROT TO BLACKBERRY 9320
To pair your BB to parrot go to connections
check whether the Bluetooth is ONthe search for devicesand when the name of the system comes..pair with the device.
Thank You.
Dec 26, 2012 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Paired my nokia with my 3200 ls kit worked ok but then stoped and now my nokia cant detect my 3200 ls kit
Try deleting all paired devices first, Menu / settings / paired devices. The remove the battery from your mobile phone for ten seconds. Then try pairing again, this should do the trick, if not the parrot may need a software update.
Nov 23, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
Paired backberry 8520 with parrot ck3100 but contacts will not syn with parrot. tried to transfer contacts to parrot but message just says refer to handsfree maunal .have looked into this with no luck...
Hello chicks,
Pairing both devices from the Parrot Product:
Select Setting / Advanced Settings / Pair with phone / Other phones
* From the phone:
* Select MENU / OPTIONS / BLUTOOTH / ADD DEVICE / SEARCH
* The phone will search for available devices
* Select the Parrot Product name from the list, and enter the PIN code '1234'
* The phone will pair with the Parrot Product and auto connect
Sending contacts via Bluetooth For all contacts sending
* From the phone:
* Select MENU / MANAGE CONNECTIONS / BLUETOOTH OPTIONS
* Select the Parrot Product from the list of paired devices and go to OPTIONS / TRANSFER CONTACTS
May 07, 2011 | RIM BlackBerry Curve 8520 Smartphone
Cannot pair blackberry 8520 with parrot ck3100
I could not pair the Blackberry Curve 8520 with the Parrot CK3100. After looking at the Parrot website, I saw that the Blackberry was actually supported, so it SHOULD work.
Then I found the solution: the Parrot had already too many other phones paired (4 or so), so it could not pair an additional one. After removing the other phones from the Parrot pairing list, the Blackberry paired without a problem. SOLVED!
Davy
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
How do i pair my blackberry with parrot 3200 ls, asking for numeric key
Thank You
Oct 08, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Hope it helped.
Nov 26, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
I cannot connect my blackberry 8320 curve to my parrot hands free
then delete some of the paired devices that you may have already on the parrot device.
Apr 19, 2009 | AT&T Blackberry Curve 8300 Smartphone
Parrot 3100 pairing with blackberry 8310
You have too many phones paired in the Parrot. Delete some of the phones from your parrot and you will be fixed. I had same issue
Apr 19, 2008 | Lands Phones
Parrot 3200 Ls Color Handsfree Bluetooth Car Kit Logo
431 people viewed this question
Top Parrot Cell Phones Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
