Question about Compaq NC6120 P-M 730 XGA Notebook
Can i join my laptop to monitor if yes then how
I want to know how can i join my laptop to monitor.
    Sergeant:
  • 306 Answers
There is a 15 pin connector on the side or back. With the laptop turned off, connect the monitor cable to the laptop and then turn it back off. Press the Fn key and the F7 key at the same time to switch between the two displays. Always disconnect and connect the monitor with the laptop off.
Posted on Nov 16, 2008
Can you use hotspot from your smartphone to an LED flat screen computer monitor to watch movies
Yes, if the computer is able to join your hotspot and you have enough data. Keep in mind that you are accessing a stream that is being used by many people at once (typical cellular tower), and quality may be reduced.
Else, if you don't have some sort of computer hooked up to the monitor, no, you cannot watch a video.
Dec 01, 2015 | Computers & Internet
Can a laptop be connected to this monitor
Short answer - Yes.
Here you can see the connection options of the monitor:
It has a (white) DVI and a (blue) VGA connector. Your laptop (although you didn't mention what model you have) should have at least one of them.
Note: The monitor has no HDMI. Since the monitor has no speakers, this is not important.
Let me know if you have more questions - happy to help.
Nov 19, 2013 | Acer P215H LCD Monitor
Compaq laptop prasario cq60 won't turn on yes it's plugged in yes outlet works yes I checked all electrical connections and outlets
have you tried to remove the battery and wait a couple of minutes then re-insert. make sure your battery charger is working, light flashes also indicates low power.
Mar 01, 2013 | Computers & Internet
I need a driver for a FPD 1975W LCD Monitor
Please mention the serial number of your monitor or visit below page to download the driver for it.
http://support.gateway.com/support/drivers/dlcenter.asp?Tab=My
Let us know further.
Thanks for joining us.
Have a nice day.
Dec 08, 2010 | Gateway FPD1975W 19" LCD Monitor
When I try to switch the computer on Monitor says "vga input: no input signal" then it goes to sleep and yes, i have already checked that all the cables are in place
the problem may be with the vga card or the desktop see the desktop is working wether it work check that or if u have a laptop try to connect the monitor to the laptop and see if the display comes on the monitor of the laptop by this you will come to know about the problem is with the monitor or the pc
Nov 15, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My compaq presario f500 laptop monitor wont stay lit. It seems to be a loose wire or something because i can get it to turn on temporarily by swiveling the monitor on its hinges. Any help would be greatly...
Ok. I have this exact same laptop and not so much the exact same issue. But I can tell you, screen issues are one of the problems that goes with a laptop that is GOING TO FAIL.
Go to hplies.com and you will see almost 2,000 users with the same issue. The problem lies with the nVIDIA GFX chip on the motherboard. THE ISSUE IS UNREPAIRABLE. Any repairs will force the laptop to fail again.
This issue has actually landed me in small claims court where I am suing for hte full cost of this laptop because not only is hte laptop defective, nVIDIA admitted it, and HP covered it up.
Join us at hplies.com and we will give you the know how to get this issue fixed/your $ back. We even have links to all of the information!
Jan 05, 2010 | Compaq Presario Notebook
Help!!! Trying to connect the LCD to my laptop to use as a monitor... Does anyone know how?
just plug the LCD monitor at the VGA port (Blue port) of the Laptop and press Fn+F8 and it will display the screen on the external LCD screen. hope this helps
Nov 03, 2009 | Computers & Internet
Dell monitor and acer one laptop
Yes, you can connect. BUT, after that right click on the desktop and select Properties->Settings. There you will find two monitor icons. The left one is your Acer display while the right one is your new Dell Display. Select the right one and configure it. You should have the same resolution and color as the main Acer display to use it optimally.
Aug 09, 2009 | Acer Aspire One PC Notebook
Laptop monitor has a big black spot
If it is actually booting, then you should hear some beeps as it starts, if there are actual problems with the system &/or hard drive.. You need to count the beeps & report them here, so we can decide what the problem is.. If the system is starting up ok & it's a screen related fault, the easiest way to test is to connect an external monitor, via the external monitor port. Most laptops have them. In fact I know the Dell 1100 does. Once you have connected the monitor, there is a sequence of keys on the keyboard to press, to switch to the external monitor. This will prove where the problem is..
However, I have some sad news for you.. Apparently there is a law suit against Dell (Class Action in fact) for overheating CPUs.
I think your 'video' problem is most likely because of that, then a faulty screen. There is a rather complicated procedure for fixing the problem here:
http://www.danandsherree.com/2005/04/02/our_dell_inspiron_11.php
This something you should really think about doing, if it's already not too late. I know it looks complicated, but if you know someone who knows how to use tools, it should be done.
Also, if you want to join the class action.. Here it is:
http://www.lieffcabraser.com/dell-inspiron-3.htm
Lots of luck with all this. Feel free to talk if you need help.
Rgds,
dave
dkahlbaum@bigpond.com
May 03, 2008 | Dell Inspiron 1100 Notebook
Computers & Internet Logo
76 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
