I have a sound magus amplifier that ive installed in the car just recently the alarm light has flashed on and hasnt turned off since. the amp was quite hot so i thought it was overheated so i tried it the next day and still the alarm is flashing. ive tried reconnecting the positives and negetives again and resetting everything still doesnt work.. what should i do?
In this case the amplifier should have some internal problem, mostly one of the output MOSFET blowout. What\s the model number? is that a X1502?
Posted on Dec 12, 2008
My phoenix gold x200.4 amp turns on but the protect light keep on flashing
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Sep 23, 2010 | Phoenix Gold ZX600ti Car Audio Amplifier
    No sound no protection light
    u must have a faulty wire...recheck youre instalments....or get a professional to do it for you..
    Feb 19, 2010 | Kicker ZX10001 Car Audio Amplifier
    I have a Directed D2400 amp and my red ESP is on
    ESP ties the amp into your vehicle's alarm system. If the amplifier is working normally you can ignore the light. Note that this is NOT the protection LED for the amplifier.
    Nov 04, 2009 | Directed 2400d Car Audio Amplifier
    No Power light or sound from kicker amp and speakers
    OPEN UP THE AMP AND CHECK THE FUSE HOLDER THAT IT IS CONNECTED TO THE BOARD
    IT MAY HAVE GOT BUMPED AND THE CONNECTION MAY HAVE BROKE IT MAY BE A HAIR LINE BREAK WITH THE COVER OFF AND THE POWER ON MOVE THE HOLDER MAY NEED TO BE RESOLDER THE CONNECTON THATS ALL IT IS GOOD LUCK
    Feb 20, 2009 | Kicker ZR360 Car Audio Amplifier
    Nitro BMW 1000w amp not working
    if AMP turns on and no sound , check the inernal fuses that protect the output from overload , in most cases this fuses act like a cicuit breaker , they set back on again in a few seconds. hope this helps
    Apr 28, 2008 | Nitro BMW-481 Car Audio Amplifier
    Sounds problem
    First things to check:
    1. You changed the fuses on the amp, but have you checked the fuse that is inline on the +12V wire? Most of the time, it's right near the battery terminal.
    2. Do you have +12V at the amp's power terminals? If not, either your +12V or ground line has a break or disconnect.
    3. Try taking a piece of wire and connecting it to both the remote connection of the amp and the +12V on the amp. This should cause the amp to turn on (if all is well). If not, the issue might be internal to the amp and would require professional repair.
    Mar 13, 2008 | Directed 1100d Car Audio Amplifier
    Red LED "Protection Light is on" What is the problem
    The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
    Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
    Problems with Infinity Amp 611A
    are you running a large ground wire directly to the battery negative terminal?
    Jun 03, 2007 | Infinity Reference 611a Car Audio...
    No Sound coming out of amp to subwoofer
    check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
    May 23, 2007 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
    251 people viewed this question
     Grubhead
    Grubhead
