Question about HP PSC 2410 All-In-One InkJet Printer
''clicking'' noise started randomly- cant use printer
Today, my printer just randomly started making a "clicking" noise and wouldn't stop. I wasn't even on the computer or using my printer. I had to push the cancel button and shut it down. Once I turned it on and tried to print something, the same thing happened. The screen just has the HP logo on it and I cannot get the printer to copy, scan, or even print anything. Can anyone help me with this? I am not computer or printer savy and cannot figure these things out. Thanks for your help
    Scholar:
  • 44 Answers
Hi starrz54,
Here is the HP site that talks about resolving unexpected noises (such as clicking)...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu06191&lc=en&dlc=en&cc=us&lang=en&rule=26695&product=303753
You also might try doing a full reset on the device. Here is how to do that: While switching on the scanner press # and 9 to initialize.
I
This should give you some good directions and if it does not resolve the issue, the next step would be to have it serviced or replaced.
Posted on Nov 16, 2008
2011 Suzuki GSX-R 1000 L1 Key inserted, click on ignition, light dims but does not start, a random problem not always
Sounds like there is a short in the ignition wiring 12v side or ground side, check your contacts with a miltimeter and the next time it wont start try jumping the starter to your 12v switched source, bypassing the ignition, It the starter making noise when it does this?
Jan 14, 2014 | Suzuki GSX-R 1000 Motorcycles
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
My car at random just wouldn't start. It was like
If you have a stick shift there is a switch usually on top of the clutch pedal that has to make contact in order to turn engine over. I would check that first.
Aug 21, 2012 | Cars & Trucks
Delonghi PAC AN140HPEC clicking noise.
1) test the mounting pads and bracket for worn
2) The compressor and motor are powerful device for make enough noise.
3) Try to adjust it very well in the frame windows, for vibration.
God bless you
Jun 22, 2012 | Heating & Cooling
My 2001 sunfire starts fine.but after i drive for about half hour it will stall and wnt start again for half hour.the oil light stays on when this happens.wassup with this?
This happened with my Sunfire. It was the radiator. The engine wasn't cooling, but the sensor wasn't showing that it was overheating. So the engine would start when it was cool, but as soon as it got hot, then if I stopped it wouldn't start again.
Apr 14, 2012 | 2001 Pontiac Sunfire
My van would have issues with starting for months. I would have to try starting it up about 5-8 times before it would start up. Battery is new and has been tested twice within the last few months and it...
HI youtube12 - IT sounds like your starter deed not disengage from the flywheel and
by you driving it caused the starter over heat and short out .
You need to have the electrical sys checked out before replacing starter. OK
good luck ziggyone
Sep 16, 2011 | Dodge Grand Caravan Cars & Trucks
Canon Imageclass D661 printer is making a squeeky noise when printing. Sounds like whatever is turning is squeaking. Any suggestions?
How old or how much use does this machine get? The older/more use it gets, the more likely it is to start making random noises and squeaks. It could be a lose belt or just need some lubrication, but it's hard telling where exactly it would need the maintenance. As long as it's printing and copying fine, I wouldn't worry too much about it since it doesn't sound detrimental.
Hope this helps!
Aug 25, 2011 | Canon imageCLASS D661 Digital Printer
Printer making a loud clicking noise when printing.
the feed roller gear is stripping; remove the cover and, adjust the gear retainer before it completely fails. (it should be easy to see the gear once the printer cover is removed.
Mar 30, 2010 | Dell 1700n Laser Printer
1997 sable with 12000 miles electrical problems
earth cable from body to engine and battery to chassis ,clean the connections and fit an additional cable ,also clean and grease the battery terminal
Jan 25, 2010 | 1997 Mercury Sable
HP PSC 2410 All-In-One InkJet Printer Logo
2,152 people viewed this question
Ben Johnson
