Question about Teac DC-D2831 CD Shelf System
TEAC DC-D2831 will not play CDs
The radio etc all work fine. When a CD is in the unit will switch between the 3 discs but none of them play or show that they are moving thru the tracks on the display. i am not sure if the disc is turning or not. The mute light is on when CD is selected and will not turn off.
3 Suggested Answers
mattozan
  • 555 Answers
SOURCE: I have a TEAC Stereo
Try resetting it by pulling the power cord and then replugging the unit.
Posted on Jul 23, 2008
SOURCE: How do I get my Teac DC-D2831 CD Shelf system to
I was having the same problem, I read my users manual and found that there is a time button on the front of the unit itself. My husband must have pressed ithe last time he used it. Works fine now.
Posted on Apr 29, 2010
My Teac DC-D2831 has actually two problems: 1) the muting light won't come off during CD mode and 2) the 3 CDs often come loose in the tray and get shuffled around or stacked up. Help?
check your remote 4 damage. an make sure u dont have efx or nothing turned on while u r n cd mode. o yeah cds have different thickness u mite need 2 use skinny cds. some cds u can see thur n some u cant
Mar 14, 2011 | Teac Audio Players & Recorders
I have an external teac dv-28e-n usb DVD writer device which does not recognise and burn DVD rewritablce discs.
I think that Teac DV-28e Is a CD/DVD-ROM only, and will not burn discs. Teac DW-28e is a CD RW/ DVD ROM unit, and will thus play and burn CDs, but will only play DVDs. Check your model numbers to confirm, and then consider exchanging units if you need to burn CDs.
Dec 20, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
Can't get fm radio stations to come in very well
run wire up the wall,and make a big T,with it,also switch to MONO,that will help
Jul 01, 2010 | Teac DC-D2831 CD Shelf System
How do I get my Teac DC-D2831 CD Shelf system to come on? Nothing comes on? Not the radio, cd, cassett nor the turntable.
Nov 13, 2009 | Teac DC-D2831 CD Shelf System
System is frozen
try using the reset button on the back of the set
Mar 06, 2009 | Teac DC-D2831 CD Shelf System
My mothers Teac DC-2831 skips when playing cds. We have used cd cleaning disc, and even compressed air. Nothing! What can we do? If we have to take it to a repair shop, can you give us one in the Los...
My DC-2831 started doing the same thing -- and continued, despite repeated cleaning with a CD-player cleaning disc. Oddly, older CDs would play OK, but brand new ones -- commercial CDs, not homemade -- would promptly begin skipping or lock out altogether. Solution?
Unplug the system, lock the turntable stylus arm into place with the attached C-clamp, then carefully unscrew the back and side panels. Once the innards are exposed, gently lift out the CD-player and visually inspect it for hidden dust, pet dander, even fur can get inside there and gum up the works, and that's something NO CD-cleaning kit can ever reach.
Once you've inspected and cleaned the CD-player of all visible dust and dirt, carefully replace the player, make sure it's seated properly within the shell, then reattach the side and back panels in the exact reverse order as you removed them. THIS IS CRUCIAL: if you don't put the stereo back together in the exact reverse of how you took it apart, you'll have components off-kilter, screws that won't go back in (and leftover screws are a sure sign you're screwed it up!) and your CD-player will be even more temperamental than ever. Word to the wise.
If all this sounds too scary, then you'll have to either live with the crappy CD-playing performance, or get a new system. You can't replace the CD-player unless you buy an entire new system. WARNING: these all-in-one turntable systems are VERY RARE anymore, so don't get mad and kick your TEAC or toss it out or give it away on a whim. You'll play hell trying to find a replacement.
Hope this helps!
Dec 04, 2008 | Teac DC-D2831 CD Shelf System
CD Player does not recognize CD
If using computer generated dics , disc usally bad burn progam , bad disk, burn speed to fast. Check out NERO burn. OR dirty eye, clean, laser eye with disc clean disc
Oct 05, 2008 | Teac DC-D2831 CD Shelf System
TEAC MC D90
try different cd's my has the same problems. maybe due to early era of cd player. some cd's work ok. use as an amp with outboard cd player. good luck
Aug 18, 2008 | Teac DC-D2831 CD Shelf System
CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
Jun 18, 2008 | Teac CD-P1250 CD Player
Teac DC-D2831 CD Shelf System Logo
62 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
