Question about Mitsubishi WS-55819 55" Rear Projection Television
Mitsubishi ws-55819 tv is 7 years old. We unplugged for a few days and moved it to another room. When we plugged in, timer light blinked 3 times and when power button pushed - tv turned on for 2 seconds and then shut itself off. Tried self diagnostic suggested inanother posting ---- help menu and input for 5 seconds --- light pattern= blink,blink, pause, blink, blink, pause --- repeated 10 times total. Please help thanks joys6
  • 41 Answers
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
Posted on Dec 21, 2008
SOURCE:
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Unplugged my Ws-55711 TV to move it to another room so the carpet could be cleaned. When I moved it back and plugged it in, the green light kept blinking for more than 60 seconds. I unplugged the TV for...
Open up the front, look under the right side picture tube. Look for puddle of oil on signal board. If you see this, it has bad picture tube & signal board. Not a good repair.
Jan 17, 2011 | Mitsubishi WS-55711 55" Rear Projection...
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
WS-55819 TV, about 8 years old, stopped working. No picture, just black. When trying to turn on, power light appears for a couple seconds, then turns off. No other indications of life. My kids...
DO THE SELF CHECK YOUR SET HAS:
When you turn it on and power light goes off in a few seconds;
On the front of the set push and hold both the Menu and Input (Device) buttons for at least 5 seconds and release both.
Power light will then blink a two digit code, most common is 2 blinks, a pause and 2 blinks--it will repeat the code at least 5 times.
Let me know what code you find and I will tell you what it means and maybe what is wrong with your tv.
I hope you find 2,2, as that is the most easy to fix.
If this helped you rate this solution as I do this here for free.
SD TECH
Jan 14, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55819 HDTV won't power on
At the very least you are not getting any of the Standby power to the Microprocessor (5 vdc). I would concern myself with that area once you get the manual. In the mean time check all the fuses.
Dec 01, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws 55819
Bad convergence ic and should replace caps also
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Nov 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
188 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
