Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
The Fisher Peykel dual drawer dishwasher : the top unit LED is off and the setting for length of wash is not lit up and is not functioning. There is power to unit because when I hit the lock button it beeps. Also the red light for the glass cleaning liquid compartment is lit. What seems to be the solution? I am an ME and hands on type, please advise.
  • Fisher and P... Master
  • 2,651 Answers
Can you see a small lock inside the display panel??? the control may be locked. another issue might be a broken heater plate, not a very home owner freindly part to change( heater plate has a fuse inline that would kill power to function
Posted on Nov 16, 2008
  • patti_1946
    patti_1946 Dec 06, 2013
  • Ron Coons
    Ron Coons Dec 06, 2013
    In either drawer? this seeems unlikely, i would check incoming electrical supply, these units are plugged in ( not hard wired) generally either under the sink or the unit itself( also look for a possible tripped GFCI breaker nearby
Fisher paykel cross draining
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Mar 22, 2014 | Fisher and Paykel Dishwashers
Greetings. I have a Fisher & Paykel dishdrawer - the top drawer appears to have lost power mid cycle and the lid has not retracted - no led display - no response from the buttons. The bottom drawer...
Describethe inside of unit,any wear on it anywhere, the rack the dishes go on is it plastic coated? is it wore with rust comeing though on tips here and there?
Mar 07, 2011 | Fisher and Paykel DishDrawer DS605FDSM...
Haveing a u3 code on my top draw of my fisher & paykel any help on this
First have the unit turned off. Then open up the drawer that,s giving you trouble.
The badge ought to be lit.
Now simultaneously press the static touch pads on each end of the led status lites (the ones on the drawer top?) (Cycle Select, and Eco-sensor pads)
Hold them for about 5 seconds.Now If you have a metal front machine, the badge display will either show HP or LP. Assuming you have normal water pressure about 50 - 70 psi you want to select the HP setting.
Do that by pressing the start button till you get what you want, then press power off to lock the setting in.
Mar 06, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The dishwasher top drawer is leaking all over the floor during the cycle. When the top drawer is running, It fills up the the bottom of bottom drawer with water also and then neither drawer drains...
Fisher and Paykel design a air gap kit to prevent the water back flowing to the other while one is running. it really works and worth of your money. You need to change the lid seal and a pair of actuators from the top drawer. Because of the leak then the floor switch activated not allowing a complete cycle. Need to dry out the wetness from the bottom housing of both top and lower drawers by pulling the tubes out and accessing from the left side with small tower until it completely dry. Here is a link to buy air gap kit
Dec 15, 2009 | Fisher and Paykel DD605SS Stainless Steel...
I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.
Dec 12, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Pykal Dual Drawer Dishwasher. Suspect after young child played with control buttoms on top drawer the power won't come on. Bottom Drawer works perfectly. Have tried turning unit off at power...
Press and hold the key or lock button for 5 sec or till you here a beep to unlock. Or till the light goes out above the lock button. You can get your manual here just find your dishwasher.
Good luck and please rate
Sep 16, 2009 | Fisher Dishwashers
Won't begin the wash cycle, just continuously drains and fills.
Have you tried pulling out the motor rotor and checking for anything stuck under it? try swapping it with the other drawer. If it still won't go you need to swap over the motor controllers between the two drawers if the fault moves you need a new Motor controller module. Cheers
Apr 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel 2 drawer dishwasher
When it sticks like this, does it continue to wash or does it stop?
Nov 27, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
None use for 7 days
I have a fisher paykel dd603 dishwasher. If I select the normal wash setting on the top drawer, it posts the time in the lcd screen as 56 mins. The unit will wash as usual until it reaches the 28 min mark. At this point it will stay on 28 mins and continue to run, but it won't rinse or empty the drawer of water. Also it never counts down below the 28 min mark. It has flashed a F4 and F1 code. I've cleared them both, and checked to make sure that no water is standing on the bottom of the unit, and that the heating element is working. I should mention that the top drawer did overflow about two weeks ago, and that I did clean up the water. I don't know where to look from here. Any suggestions?
Sep 10, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
158 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
