Question about Sony SDM-HS95 19" LCD Monitor
Monitor is Pink
Not sure what happened, but my 13 year old said the monitor wouldn't come on (appeared black) and she kept pressing the power button. When it finally came on, all the colors on the monitor appear "pinkish." I suspect that she wasn't pressing the power button, but may have been hitting the "menu" button instead. I checked out all the settings and don't see anything out of the ordinary that would make the colors appear pink. (We have two monitors and I compared the settings with the monitor that is working just fine and they are the same). Any idea why everything is pink?
    Top Expert:
  • Sony Master
  • 53,736 Answers
Go to control panel and change the desktop background color
Posted on Apr 24, 2017
SOURCE: Constant white screen
check the brightness and contrast from the menu on the monitor try increasing it ... the problem will get solved...
if same problem persists contact ur near by experrt technician he may tell that the tube is gone he must recharge it....
Posted on Feb 06, 2008
tantong
  • 138 Answers
SOURCE: Pop up menu won't go away.
If you can do the factory reset in the pop up menu, try it. You might have to try with another power supply, cord, or computer and check where the problem is.
Posted on Mar 16, 2008
Mark_Webber
  • 472 Answers
SOURCE: Menu pop ups
It will only be one of 2 things, neither easy to correct I am affraid.
  1. The contacts behind the buttons have become faulty and are contacting as if they were being pressed by the buttons on the control panel. To check this is simple (well for me). You will need to open up the monitor and disconnect the front control panels cable. If the pop ups stop, theres your answer. It would then need to have another panel installed.
  2. The internal eeprom has an issue and is detecting that you are pressing the menu buttons and so displaying the menu. This could be a simple case of residue or even lint in the circuit that is giving an incorrect reading that is then translated incorrectly by the eeprom.
Posted on Apr 21, 2008
scottyfixit
  • 186 Answers
SOURCE: Blank Screen, Flashing orange power light...
1st Idea - Let's take a look under the cover. I'm not sure how tech savvy you are, but I'm sure you're pretty good if you have a soldering iron. Once inside locate the power supply section. See if you see any blown capacitors on it or any other boards. One obvious way is to see if they are bad is if they have bulging up tops. There could be some weak or bad ones that aren't popped up, but let's start from there. If there are any bad caps, they are dirt cheap price wise at an electronics shop. Keep me posted and let em know what you find. - Scotty
Posted on Apr 30, 2008
T3KK
  • 171 Answers
SOURCE: My monitor turns on but then goes black after
It could also just be the button is faulty... but a 6 year monitor is going to start throwing more and more problems at you.
Go to eBay.com and treat yourself to a nice new monitor - they are very cheap these days.
Posted on Oct 10, 2009
Gateway FPD 1730 (mfg June 2004) On start-up, monitor flashes bios screen for less than half a second, then flashes the Windows XP logo for less than half a second and then stays black, no image. No...
All support is finished for XP years ago. The system is 13 years old and well past it expected life. Average is 8 to 10 years on a shop bought unit like Gateway, 12 years on a custom build.
I am thinking you probably have a dry joint on the board behind the switch as holding the switch makes the monitor work.
My advice though is a new computer running Windows 10, technology moves on in hardware and software.
Mar 08, 2017 | Gateway FPD 1730 17" Flat Panel LCD...
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
Monitor powers on but screen is black. then a grey stripe appears across the screen. by pressing the leftmost button a faint picture shows the auto-reset? screen, a dell screen, and i can see the main menu...
Hi! I believe that the monitor has come to its end. 6 years is quite long for a monitor. You may have it repaired for there may be blown capacitors that needs replacement but a new monitor will be a great idea. HOpe this helps and have a good one!
May 18, 2010 | Dell E171FP 17" Flat Panel LCD Monitor
There is a black line and see through pink bar on my monitor
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
also check you warenty its usually 3 years
Apr 12, 2010 | Dell 1702FP UltraSharp 17" TFT LCD...
The led is blinking and the screen is flashing and stays black, no picture or desktop appears and monitor menu doesn't work when power on comp after being off for few hours or longer, Tried with changing...
Make sure that your computer isn't going into Standby or Hibernate mode. You can test this by briefly pressing the power button and wait to see if the screen comes back on.
Oct 26, 2009 | Samsung 943NW Monitor
No picture on monitor 997M
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 08, 2009 | Microtech Computers & Internet
Possilbe to reset monitor?
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
19 "lcd gateway monitor will not power on.
Have you tried your monitor on somebody else computer?
Jun 14, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Sony SDM-HS95 19" LCD Monitor Logo
42 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
