Question about Bissell Vacuums
I changed the belt on my vacuum,and the belt burned up,and snapped.Right after I changed it.Am I missing a piece??
  • 328 Answers
Sometimes it can depend on the quality of the belt - if its brand new then it shouldn't snap the moment it is changed; if its an older belt sometimes they can break up the moment they're changed. Ensure that the model you have is correct with the correct product code of the drive belt. Also Check that the sides of the brush bar are not clogged with dirt - one way to check would be to check the brush bar rolls freely with no belt on it before putting a new one on. Another issue is something my old LG upright used to do - it used to break new belts even when the roller brush was completely clear - and the only way to get it to stop was to replace the heavy dirt bag with a new one. It seems the slightest bit of strain on a motor can make things like belts break. Hope all this info helps.
Posted on Nov 18, 2008
Sent away 2new belts for dyson dco4 hoover after the one i replaced snapped .after awhile i emailed the firm who assured me were the correct size+ number,after a fight i got the belt onit was on 4or 5...
These are a difficult set of belts to replace. If you don't have everything just right when you reassemble the clutch or if there are any restrictions in the brush roll it will not work properly. It's best to test the clutch assembly in both positions after installing the new belts to make sure you did it correctly before putting it back in the vacuum.
Sep 13, 2013 | Dyson Vacuums
Dyson DC07 belt change has resulted in very noisy vacuum!
Hi I agree with the first 2 solutions above but not the 3rd one.
If you have suction coming through the hose when the machine is in upright position then the u bend has nothing to do with this problem.
Right so ... The belt snapped.
The answer to you question is "why did the belt snap" its true that it could just be old age but its more likely to have been caused by a foreign object being sooked up.
How the belt/brushbar/motor interact
Your belt simply connects the motor to the brushbar know as Direct Drive. If an object get inside the space between the motor and the brushbar or if it can jam the brushbar then this will cause the rubber to burn. The motor will keep spinning and the belt wont be able to so will snap.
So its easy to see that the belt has snapped and people just think "'oh the belt has snapped"
You might wonder where im coming from here.
Anyway because the brushbar got jammed it may also have been buckled slighty either as a result of the foreign object causing it to stop suddenly from spinning at high speed or/and the result of the heat build up.
The rattling noise you now find your Dyson making is more than likely because your brushbar is buckled and when it spins the bristles are hitting the housing unit.
Your belt will snap again unless you replace the brushbar
Apr 10, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum Belt keep breaking
When your first belt burnt, the burnt plastics goes into the roller ends and then it dries off causing your roller to not turn or put more pressure on your belt. Until you clean that you will continue burning your belts soon after you put them in. You need to add a little bit of WD40 or any other type of lubricant after you remove the tar from the roller.
Feb 26, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
I sucked up a long piece of string, and it rolled around the bottom and smelled like burning. The piece of string is gone, but the motor doesn't sound like its engaging. Is this going to be expensive? Can...
flip the vac over take off the bottom cover plate to expose the belt and see if it still actually on the shaft, more than likely when you tried to run the vac while the string was wrapped around the beaterbar it caused the belt to either snap or stretch out so replacing the belt should bring it back to life without your having to spend more than a few dollars for spare belts and you do need to have some on-hand when they wear out
Feb 19, 2010 | Bissell CleanView II Plus Upright Bagless...
Vacuum smells like rubber burning. Replaced belt. same result
My vacuum's belt fell off, So I fixed it. Two days later my vacuum wouldn't turn on, so I opened it up again and took out a dust ball in between the electrical wires. I turned it on and sparks and snapping sounds came form the motor. Also burning rubber smell, What wrong? Is my vacuum fixable?, or should I buy a new vacuum?
Jan 15, 2010 | Oreck XL2000 Bagged Upright Vacuum
Put new belt on and the wheels are to high in the front of sweeper
Is this a dirt devil. First and foremost these things ****! secondly the wheels have to be snapped in underneath the piece that covers the belt. even when that is done the wheels will force the vacuum to low and stress the belt so much that it breaks! See my other suggestion on how to remedy this!
Sep 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Burning smell and not picking up dirt
You probably need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Jul 02, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Vacuum smells like burning rubber when on, no suction, leaving black marks on carpet
Usually when my vacuum smells like burning rubber, the belt needs to be changed and that is very easy to do. You just need to remove the the screws that hold in the rotator and put in a new belt. When the belt needs to be changed the vacuum will not pick up anything and this could make it seem like there is no suction. I hope this helps!
Nov 25, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt is burning?
is the brush turning?  remove any debris that is keeping it from rotating.  It does sound like the belt is burning because the motor is trying to turn it and the brush/sweeper is jammed.
Oct 16, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Vacuums Logo
67 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
