Question about Refrigerators
I want to change the thermistat on my upright 160 litre slim line freezer so that it runs like a fridge for more energy efficiency what would be the best solution
    President:
  • 1,462 Answers
Not really possible to do - design of a fridge and freezer are totally different
Posted on Nov 16, 2008
How much electricity do I need to keep my Woods chest freezer running during an extended power failure?
The amount of Energy is determined by the Efficiency of the Fridge, the Generator Output and the Size of the Fridge. Then you have to take into consideration the amount of food inside because it is what keeps the food cold. An Empty Fridge has nothing to retain the coldness
Oct 02, 2014 | Freezers
Freezer seems to run all the time.
Good Morning Linda, this is Z. I appreciate your post!
I understand your Frigidaire freezer seems to continuously running. Unlike older freezer that turned off and on frequently, newer models save energy from having to start up and shut off repeatedly. For example, diesel-powered trucks conserve fuel and energy and therefore have less engine wear and tear by keeping the motor running; much like newer energy efficient refrigerators/freezer. If the compressor is running on a more constant basis; it is maintaining the temperature within your freezer, rather than having to cut off and start again to adjust the temperature.
I hope this information explains why your freezer runs more often. However, should you feel that a service technician is needed; you may visit the manufacturer website to find a provider in your area that will look at your freezer.
Best regards!
Aug 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Westinghouse 633 litle, 2 door
The latest 2 door Westinghouse 610 litre without ice maker is a 2.5 star rating with energy consumption (kwh/year) quoted as 605. We had an older 633 litre Westinghouse about 20 years ago which was less efficient and I would assume about 2 star rating. With older fridges the door seal and thermostat are more important as they will waste electricity if not working well.
Mar 12, 2014 | Westinghouse Refrigerators
Fridge temperature too warm
As you know this is very large fridge and try to find service manual for help and solve problem with using deduction method of step by step trouble shooting and eliminate possibilities
This might be compressor problem or evaporator problem or main controller problem or sensors or etc.
Baumatic TITAN 5 Stainless steel 4 door 607 Litre Frost Free Fridge/Freezer
Technical Details :
* Total gross/net capacity: 607/557 litres
* Gross capacity fridge/freezer: 428/179 litres
* Net capacity fridge/freezer: 397/160 litres
* Energy efficiency class:
Dec 06, 2013 | Refrigerators
The door open light is on and the fridge is not getting cold
You have broken door seals and need a replacement soon. Opened door while your freezer running is WASTE the energy and bucks.
Regards, Jay
Oct 25, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Sears model 253.9280212 UPRIGHT FREEZER NOT KEEPING FOOD COMPLETELY FROZEN. EVEN AFTER HALF OF CONTENTS HAVE BEEN REMOVED, REMAINING CONTENTS DO NOT COMPLETELY FREEZE. WHAT'S WRONG? HOW TO ID PROBLEM?...
make sure the unit is running and not shutting down to soon if it is change the cold control if unit is staying running the replace unit
May 06, 2010 | Freezers
Not giving up on frigidarie
this would appear to be a thermistat control issue.make sure that the doors are closed tight and the seals are in good shape this will also cause long periods of run time.if those thing are good replace the thermistat control.good luck with your fridge let me know hwo things worked out for you.
Jan 21, 2010 | Frigidaire FRT15B3A Top Freezer...
Fridge walls very warm around freezer door
that is ok these fridges have the condencer lines within the walls of the fridge or some have heaters this is for condensate not to form on the fridge it keeps the fridge dry on the outside
Sep 26, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Fan is running, fridge and freezer not cold
I have a Westinghouse side by side refrig/freezer that the compressor will run but will not cool or freeze. Do you have any suggestions?
Apr 06, 2009 | Refrigerators
Whirlpool Freezer doesn't freeze?
insulated or not, garages are generally too cold for new energy efficient frigs to operate. ambient temp needs to be above 60 to work efficiently.
Mar 07, 2008 | Refrigerators
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
