Question about Philips 55PP9352 55" Projection Television
Philips 55PP9352 Rear Projection, no picture or sound, chirping.
I have read several of the other posts with a similar problem. My questions are, how do I locate the bad HOT (Horizontal Output Transistor) or Flyback. I think I can repalce these myself, if someone can tell me where they would be located on the boards and how to test them.
  • 3 more comments
  • cooperstor_j Nov 16, 2008
    I am not an electronics expert or I would not be asking here. However, I am aware of the electrical hazards involved. I am an IT manager so I do similar work on computer hardware. I just need to know where to locate these parts on the boards, how to test them, what devices to test them with, I can post pictures of the boards if needed. I also have a PDF of the service manual for this chassis model.
    John
    How do I test if the HOT or the flyback is bad? What is the procedure for removing a flyback?
    Have already tried other power circuits. Also power supply is fine. I am looking for a step by step procedure for testing the HOT and flyback and how to remove / replace the flyback.
    I found in the service manual how to get to the TV to diplay the error codes through the front power LED. When I did this it looks like I am getting error 22 which is, according to the service manual: Flash protection (detected via Bocma).
    What is this?
    "The fact that you are asking how to perform basic forward and reverse bias test on a transistor, thinking that you could test an FBT as well as how to desolder their joints tells me that you are unfamiliar with electronics. Might I suggest that you reconsider performing a DIY, it is not highly recommended at this point."
    I paid the premium service fee to find out the problem, and get a step by step guide on how to fix it. Not to be criticized and judged that I am unfamilar with electronics. Also, being told repeatedly to leave it to a professional. Okay, then what good is it speanding money here? I am asking for a refund, and I go elsewhere to get help with this problem.
  • 88 Answers
SORRY in rhis case Gohead with aa good technician and not advisable
If you are not A electronics expert.
if you do a small mistake it will spiol other things(other companents) Also
so pleaseconatact A qualified TVEngineer.
Wish you all the best.
Posted on Nov 16, 2008
  • 2,296 Answers
The following instructions are to measure the HOT. I would suggest to de-solder it from the circuit and test it outside the circuit.
The FBT can only be tested if you have the schematic diagram, but you will also have to remove it from the circuit to test the internal windings.
With the meter set to measure ohms, clip one meter lead to the base connection of the transistor.
Touch the other lead first onto the collector lead and then onto the emitter lead.
The readings should both be the same, either both high resistance or both low resistance.
Now reverse the leads and repeat the procedure.
The results should be the opposite of those obtained before.
If they were both high before they should now be both low.
If they were both low before they should now both be high.
Now measure the resistance between emitter and collector.
It should read high resistance in both directions.
If you don't know the transistor connections consult a data book.
If you cant find the data then measure between the three connections in both directions.
You should now be able to identify the base connection and then decide if the transistor is OK.
Note that for this to work the internal battery of the meter must supply a voltage high enough to overcome the forward resistances of the transistors.
Many meter have a position marked with a diode symbol which must be selected when checking transistors or diodes.
Note that NPN transistors have low resistances where PNP have high, and vice versa.
    Scholar:
  • 181 Answers
Its a high voltage device and is risky to handle repairs without a proper technician
  • fixyy Nov 16, 2008
    well,to check if the fly is good is not easy without a testing tool called a ringer, and you have to take it out of the circuit, you can resolder all the pins no hurt, to work on the set you have to discharge the big caps on the board go here.
    http://riddledtv.com/repair/journal/Disc...
    Also continous blinking of the standby red light may mean
    No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path maybe defective.
    Also the hot maybe bad test it.maybe q601 not shure.
    Go here and read these articles;
    http://www.techlore.com/articles;jsessio...
    Genius:
  • 1,913 Answers
Check your power suply waltage and fluctuation.aslolo check earthing is working properly.try at your projection at other places.
  • kishor khatri
    kishor khatri Nov 16, 2008
    check your diode. and transistor.diode has 2 legs and transistor has 3 legs.u can test with amp read carefully those diode how pass amp.then test that proper ampear is flowing from them when u givr voltage.
    Brigadier General:
  • 6,966 Answers
Initially, access to a service manaul (Chassis # DPTV310) or at the very least a schematic diagram with voltage readings would be of great help. This is of course assuming that you have a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. If you have confirmed that it is either the horizontal out transistor (HOT and/or the flyback transformer (FBT), pls reference the image below. It may not exactly be what is in your Philips. Again, pls be reminded that their are dangerous and fatal voltages inside.
Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 16, 2008
    Hi again,
    Appreciate the quick postback and thanks to Ekse for commenting on it.
    To answer your questions:
    • How do I test if the HOT - some DVM/VOM have built-in transistor testers. Should this be not available, the three terminals of the transistor could be tested like a diode with forward and reverse bias. In some designs, the transistor has a limiting resistor connected to the base/emitter while in others, a damper diode is built-in to the collector/emitter. In some designs, a different type of transistor maybe used where the normal tests could not be applied. There are also instances where the test would yield false positive results and could be verified by checking for leaks at high resistance settings;
    • or the flyback is bad? - requires a ring' test, where an external instrument/device injects pulses to the FBT primary circuit and check its HV output as well as secondary voltages
    • What is the procedure for removing a flyback? - you would need a soldering iron and a desoldering tool. The soldering iron provides the heat to melt the soldering lead while the desoldering tool provides the suction to remove the melted lead.
  • Louie  Role
    Criticizing and judging you was never the intent; please accept my apologies if you were offended. In my view, offering assistance also means that the information should not pose danger to the user hence the reminders of the potential hazard pursuing a DIY. Perhaps, as English is not my native tongue, I should have been more circumspect with my choice of words.
    Your initial concerns were:
    • where they would be located on the boards;
    • how to test them.
    To my belief, both were addressed.
    Should you still feel that your issues were not properly attended to, pls email premium.support@fixya.com for your subsequent request.
    I bid you luck in your repairs.
  • Philips Master
  • 13,433 Answers
Leave this high voltage repair to a professional.
  • Ekse Nov 16, 2008
    The flyback generates 20 000 to 30 000 volts for color TV tube.
  • Ekse Nov 16, 2008
    Benimur has posted you a picture and service manual, please press the repost link to get rid of my solution and view hes.
    Thanks and good luck.
No picture No sound, chirping from a board
Is the FBT,the high voltage transformer.The big black block of plastic with a red wire solder to a board.MIght even have to change transistors deflection board also.
Nov 21, 2009 | Philips 60PP9352 60" Rear Projection...
Philips rear projection tv 7 years old 55PP9352..
when yellow led....push the "P-" button about 5 times then push the left hand square button (looks like square with arrow pointing right) several times until it cycles to the input device.... order is ext1, ext2, ext3, front input, TV....
Nov 04, 2009 | Televison & Video
Philips 55PP9352 Rear Projection, no picture or sound. When the power button is pressed the red indicator light comes on and there is a chirping sound coming from the back. The convergence chips...
FBT is on power suplly deflection board it has 2 wires coming from it one goes to high voltage trippler box the other 1 goes to screen control box Hori out put is next to FBT 3 legg transistor on aluim heat sink Base to emitter will read short has internal Diode if it reads short on base to collector then hori output is Bad. Call Mats for Parts they will send you a catolog if you ask them too! 1-800-628-1118 Let me know if you need any more help.
Sep 10, 2009 | Philips 55PW9363 55" Rear Projection...
Red power light on chirping beeping sound
Hello miko_alexand,
That problem indicates that the Horizontal Output Transistor (HOT)is beginning to malfunction. I would suggest that if you have a background in electronics that you do the following:
1) unplug and open the back of the set
2) look for the HOT and locate the Collector, Base and Emitter of the transistor and using your multimeter set to read resistance measure from the collector to the ground, it should read high almost infinite, red from base to ground it should read low and from emitter to ground it should read low.
3) if the HOT when read from the collector to ground reads low then you can bet that the HOT has a short circuit from collector to ground, and will have to be replaced.
4) In addition I would also perform a ring test on the Integrated High Voltage Transformer (IHVT).
This will tell you if the IHVT has suffered any damage from the HOT malfunctioning. You may end up having to replace both of the components.
If you do not have a background in electronics I would suggest that you take the TV to your local TV repair facility.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 20, 2009 | Philips 55PP9352 55" Projection Television
Mine had the same problem, and it turned out to be the power board.
Dec 20, 2008 | Philips 55PW9363 55" Rear Projection...
This is a common problem with this model. The convergence circuits have shorted out causing the HVG to chirp.
Goto the site www.TvRepairKits.com and get their "chirping" tv repair kit. It will fix the no audio+no video + chirping problem.
Nov 16, 2008 | Philips 43PP9202 43" Rear Projection...
No av-input picture with sound
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Sep 25, 2008 | Philips 60PP9363 60" Rear Projection...
Convergence
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 13, 2008 | Philips 55PP9352 55" Projection Television
Philips 55" rear proj. tv...55pp9352
Mine had the same problem. It turned out it was the power board that went out. The ic's might need to be replaced again, because they could get whacked out when the power board blows out.
Sep 11, 2007 | Televison & Video
those ic's are to be replaced with original parts..also suggest audio ic..john
Sep 11, 2007 | Philips 55PP9352 55" Projection Television
Philips 55PP9352 55" Projection Television Logo
365 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
