Question about Philips 43PP9202 43" Rear Projection Television
Philips 55PP9352 Rear Projection, no picture or sound, chirping.
I have read several posts about a similar issue reported from other people. When the power button is pressed the red indicator light comes on and there is a chirping sound coming from the back. I have read some of the ideas on what could cause this, specifically the horizontal output transistor or Flyback. I have done searching but what I need to know is, what do these parts look like? Where would they be located, on which board? How do I test them? I can certainly replace them but I need help on the identification.
  • mydishfree Dec 20, 2008
    Philips 55PP9352 Rear Projection, no picture or soundWhen the power button is pressed the red indicator light comes
  • jason May 11, 2010
    still need help? just let me know
  • Philips Master
  • 3,459 Answers
This is a common problem with this model. The convergence circuits have shorted out causing the HVG to chirp.
Goto the site www.TvRepairKits.com and get their "chirping" tv repair kit. It will fix the no audio+no video + chirping problem.
Posted on Jan 11, 2009
Philips 60pp9202 I get no sound, no picture and a chirping noise
Chirping in a phillips is usually related to the HOT ( Horizontal Output Transistor) or the Flyback ( HV Generator having a issue.
Dec 11, 2009 | Philips 60PP9202 60" Rear Projection...
No picture No sound, chirping from a board
Is the FBT,the high voltage transformer.The big black block of plastic with a red wire solder to a board.MIght even have to change transistors deflection board also.
Nov 21, 2009 | Philips 60PP9352 60" Rear Projection...
Philips rear projection tv 7 years old 55PP9352..
when yellow led....push the "P-" button about 5 times then push the left hand square button (looks like square with arrow pointing right) several times until it cycles to the input device.... order is ext1, ext2, ext3, front input, TV....
Nov 04, 2009 | Televison & Video
Philips 55PP9352 Rear Projection, no picture or sound. When the power button is pressed the red indicator light comes on and there is a chirping sound coming from the back. The convergence chips...
FBT is on power suplly deflection board it has 2 wires coming from it one goes to high voltage trippler box the other 1 goes to screen control box Hori out put is next to FBT 3 legg transistor on aluim heat sink Base to emitter will read short has internal Diode if it reads short on base to collector then hori output is Bad. Call Mats for Parts they will send you a catolog if you ask them too! 1-800-628-1118 Let me know if you need any more help.
Sep 10, 2009 | Philips 55PW9363 55" Rear Projection...
Red power light on chirping beeping sound
Hello miko_alexand,
That problem indicates that the Horizontal Output Transistor (HOT)is beginning to malfunction. I would suggest that if you have a background in electronics that you do the following:
1) unplug and open the back of the set
2) look for the HOT and locate the Collector, Base and Emitter of the transistor and using your multimeter set to read resistance measure from the collector to the ground, it should read high almost infinite, red from base to ground it should read low and from emitter to ground it should read low.
3) if the HOT when read from the collector to ground reads low then you can bet that the HOT has a short circuit from collector to ground, and will have to be replaced.
4) In addition I would also perform a ring test on the Integrated High Voltage Transformer (IHVT).
This will tell you if the IHVT has suffered any damage from the HOT malfunctioning. You may end up having to replace both of the components.
If you do not have a background in electronics I would suggest that you take the TV to your local TV repair facility.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 20, 2009 | Philips 55PP9352 55" Projection Television
No picture/ chirping noise
Common problem with this model. Goto www.TvRepairKits.com for a kit with instuctions.
Jan 30, 2009 | Philips 60PP9401 60" Rear Projection...
Mine had the same problem, and it turned out to be the power board.
Dec 20, 2008 | Philips 55PW9363 55" Rear Projection...
No av-input picture with sound
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Sep 25, 2008 | Philips 60PP9363 60" Rear Projection...
Philips 55" rear proj. tv...55pp9352
Mine had the same problem. It turned out it was the power board that went out. The ic's might need to be replaced again, because they could get whacked out when the power board blows out.
Sep 11, 2007 | Televison & Video
those ic's are to be replaced with original parts..also suggest audio ic..john
Sep 11, 2007 | Philips 55PP9352 55" Projection Television
Philips 43PP9202 43" Rear Projection Television Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
