Question about Toshiba Satellite A205-S4617 Notebook
Lcd screen won't work on my satellite a205-4617
The laptop boots up ok everything seems to be working fine
i just don't have any picture on the screen. any ideas would be helpful
before i take it to a repair shop.
  • bandit4d Nov 16, 2008
    Thank you for the response i did plug in a external monitor nothing happened. the screen gets light
    when it first boots up then goes dark with lines through it.i know it is working beacuse the finger print reader reads my finger print and gives me the ok sound.soi think everything is ok other then i have no picture.
    Thanks: bandit4d
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    how do you know everyting works fine? have plugged in an exteral monitor?
    Sergeant:
    Champion:
  • 435 Answers
I think the LCD circuit might be faulty or the lamp is defective.
Can you look closely to see any pixels switching on and off in dark background?
If the lamp/ lamp circuit is faulty it would be little cheap to fix.
Also please try with the external monitor once as leecom72 said ...
Posted on Nov 16, 2008
!!!no reaction on plugging the ac adaptor.!!!
Sound like the LCD screen's inverter is causing an short/overload and the power adapter is shutting down (thermal cutout).
Remove the LCD screen and connect an external monitor, power up the external monitor first and the boot up the laptop. The video should automatically on the external monitor. If the display on the external monitor is OK then the fault could be the inverter which is located at the bottom of the LCD screen between the hinges.
LCD screens and Inverters for your laptop maybe available from this WEB site.www.lcdparts.net
Apr 13, 2012 | Toshiba satellite c660
I dropped my toshiba satellite laptop off my lap, it slid hitting where the monitor joins the keyboard. The screen is now blackish-blue when on, windows sounds like it boots fine and even connects to the...
From your description, I am sure the LCD screen is cracked and needs to be replaced. To check if the laptop is functioning, connect an external monitor to the video port on the laptop, power up the monitor first and then boot up your laptop. If the monitor displays the normal Windows image and the programs operate then the laptop is OK and you need to replace the LCD screen.
For LCD screen replacements, check out these WEB sites :-
Normal 0 LCD screens and Inverters
www.lcdparts.net
http://www.yallstore.com
http://www.shope2.com/
http://www.invertercentral.com/qrySearch.asp?Adword=1500&search=1500&Campaign=Google-Models-NA&gclid=CO3lg7HJlKMCFQcbewodZB2qoQ
http://www.nylaptopparts.com/
http://www.ccflwarehouse.com/
Oct 23, 2010 | Toshiba Satellite Laptop with Intel...
My laptop screen is bright. Brightness control works but no picture. The picture is ok on external monitor. Sometimes a faint and incomplete picture appears on startup but disappears after a few seconds....
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Aug 25, 2010 | Compaq Presario 700 470024-192 Notebook
Boots but black screen toshiba satellite M300
See if you can plug in and external monitor and boot from scratch if the external scren comes on then the LCD on the laptop has had it. Ring Toshiba to get it fixed as its in Warrenty.
May 06, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
I have a toshiba satellite a135 s2276. The usb ports are all enabled but it won't recognize any device plugged in Also when i boot up the screen is kinda pinkish in color then goes black. Everything works...
The problem is with your harware. Either there is some problem with your USB ports( Mother Board) or its due to conflicting drives. Reinstall all your USB port drivers.
Mar 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
Defective CCFL backlight may has the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
Mar 06, 2009 | Toshiba Satellite 5205-S703 Notebook
LCD monitor has no display
It's possible you have a problem with either the LCD or with your system board or CPU. Plug an external monitor into your laptop and then boot it up. If you get a picture on the external monitor, the problem is your LCD. If you still get no picture, you likely have a bad system board or processor.
Jun 17, 2008 | Sony Vaio S150P (VGNS150P) PC Notebook
Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
Feb 01, 2008 | Toshiba Satellite A100-ST3211 Notebook
Random screen freeze
You are going to need your WINDOWS CD: http://www.updatexp.com/scannow-sfc.html
Dec 03, 2007 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
