Question about Nikon LS 2000 Film Scanner
Nikon LS-2000 Out of Focus
I recently cleaned and lubricated my Nikon LS-2000 since it was sticking and making noise. Once cleaned (used on of the links you posted) moves like new and no error messages or alignment issues. I did a compare of a scan from before and after cleaning and noted the post cleaning scan is not as sharpe?
All mirrors, lens and optics are spoltless and reinstalled properly.
Using VueScan 8.4.94 on a Vista OS, with SCSI interface.
Is there a manual/mechanical adjustment I can use shapen pictures as software solutions have zero effect?
4 Suggested Answers
SOURCE: Nikon Scan doesn't recognize scanner
You need to check that the ASPI drivers are loaded, otherwise it will not work. The LS-2000 works with Adaptec ASPI v4.71. These drivers do not come with the Nikon product.
Posted on Aug 07, 2008
  • 48 Answers
SOURCE: PC (Dell) won'r recognize scanner (nikon ls 2000)
This is a problem with SCSI bus speed too fast for the legacy device. The recommended SCSI controller is the Adaptec 2906, which will recognize legacy devices and slow the bus speed for them.
You also need an older ASPI driver set, version 4.70 available from Adaptec at http://www.adaptec.com/en-US/speed/software_pc/aspi/aspi_v470_exe.htm
Before you install the 4.70 version you need to be sure to remove any newer versions of these files: Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}ASPI32.SYS Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WOWPOST.EXE Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WINASPI.DLL Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WNASPI32.DLL
These files may be found in WindowsSystem or WindowsSystem32. In order to delete them, you will need to restart your PC in Safe Mode. Once they are gone, restart your computer normally and run the ASPIINST.EXE program which was extracted by running the file downloaded from Adaptec.
Finally, you need Nikon Scan 3.1.2 for the LS-2000, available at http://support.nikontech.com/app/answers/detail/a_id/81
Posted on Mar 03, 2009
SOURCE: Nikon LS 2000 scanner is reporting a hardware error
Hello Mike,
According to a previous post this is your answer by:
johnmichaelc
The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
Posted on Nov 27, 2009
SOURCE: My LS-2000 film scanner has just stopped working
I read this forum entry and it solved my problem also:
http://www.pcreview.co.uk/forums/thread-1936922.php
Posted on Dec 04, 2009
I have a D5000 camera w/ kit lens VR 55-200, less than a year old. Recently and only occasionally what is happening is when I press the shutter release button, the lens won't focus, it won't move...
Your camera is still under the one year Nikon warranty. Call Nikon's repair depot at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday. They will verify your warranty and assist you in returning it for repair.
Jun 08, 2011 | Nikon D5000 Digital Camera
The Nikon LS 2000 Film Scanner says the stage locking screw is still in place but it was removed 10 years ago when I bought it. I tried to put the negative film adapter in, it didn't work. Then I put the...
The lubricant has become sticky and is acting more like adhesive than lubricant. This is the most common cause of malfunction in the LS-2000 and LS-30 scanners. It's a quite curable condition.
Nikon LS-2000 and LS-30 film scanner service and repair is available. Check seller pjferrante2 on eBay. Scanner performance backed for 12 months. Very reasonable price.
Dec 19, 2010 | Nikon LS 2000 Film Scanner
Recently replaced my thermostate in my 2000 Ford Taurus and in the mist of that antifreeze out of the back up resivor spilled on my belt and now they are making an awful squeaking noise an I have tried...
With the engine off, try using a soapy solution using dishwashing liquid, and rag to clean the belt and pulleys. Antifreeze is very slippery and sticks to surfaces. Clean it the best you can, and also tighten the belt slightly.
Nov 12, 2010 | 2000 Ford Taurus
Nikon P80 knocks while recording video.
It sounds like your Auto Focus as you mentioned....take it off and see it it continues.
Mar 26, 2010 | Nikon COOLPIX P80 Digital Camera
Dec 03, 2009 | Nikon LS 2000 Film Scanner
Hello Mike,
johnmichaelc
Oct 29, 2009 | Nikon LS 2000 Film Scanner
Sigma 70-300 Macro Motorised Lens for Nikon has stopped autofocus
If you just purchased the lens I would take it back sounds like the lens is jarred and defective should still be on warranty
Jan 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
Connecting a Nikon LS200 slide scanner to a PowerBook G4
Yes - get hold of an Adaptec USB2XCHANGE SCSI-USB cable and download Vuescan software (www.hamrick.com). This works perfectly on LS2000 - Macbook Pro combo.
Jun 02, 2008 | Nikon LS 2000 Film Scanner
I have the same problem (on XP, Nikon Scan 3.1.2) ... IF I turn the scanner on before the computer (or turn the scanner on and then reboot) then Nikon Scan recognizes it. Can't say I'm happy with the solution, but it works consistently for me.
Apr 18, 2008 | Nikon LS 2000 Film Scanner
Nikon LS 2000 hardware problem
Here's what you need to do (carefully!!):
www.vad1.com/photo/dirty-scanner/ls2000-cleaning/
Dec 08, 2007 | Nikon LS 2000 Film Scanner
Nikon LS 2000 Film Scanner Logo
110 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
