Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Husky 6 gallon dry/vac wont **** in air, only blows air out
My wet/dry vac blows air out instead of sucking it up. Is there a way to fix this?
    New Friend:
  • 60 Answers
Maybe you have the vac hose plugged into the blow out port.
Posted on Nov 16, 2008
Shop Vac MAC 12-200D my shop vac is blowing air instead of sucking air. How do I fix it
this might sound silly but have you got the pipe in the blowing end instead of the sucking end hope this helps
Oct 09, 2016 | Shop Vac Vacuums
My very old 6 us gallon wet-dry shop vac now blows instead of sucks.
connect the hose on the other end where it say vacuum not blow.
Sep 19, 2016 | Shop Vac Vacuums
Can u wash the paper filter on a wet dry vac
You really cannot wash the paper filter. You can blow it out with an air hose if you have access to one, or vacuum it off with another vacuum. If it does get wet you should let it dry outside of the vacuum before you use it again.
May 10, 2014 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Ridgid shop vac is not sucking
Check the intake hose for a blockage. Attach the hose to the exhaust outlet and turn the vacuum on. If no extracted air is blowing out of it the hose is totally clogged up
Apr 10, 2010 | Ridgid 25648 Wet/Dry Vacuum
WHAT IF THE SHOP VAC IS BLOWING INSEAD OF SUCKING
Check for blockage and make sure that the hose is in the correct port.
Mar 19, 2010 | Shop Vac ShopVac 3 HP 2 Stage 10...
How do i change from leaf blower tovac? vac will only blow i need to cahange it to vac mode
fell on top of vacum for the place where the air is being sucked in that is the vacum port put hose on this port
Oct 22, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Jul 16, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
1,021 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
