Question about Jenn-Air JGC8536 Gas Cooktop
High performance burner slow to light
After a year of use, my middle (largest) burner is slow to light, sometimes not lighting at all. The ignitor clicks vigorously but often is not able to light the burner. I can manually light the burner with a match so there is gas coming thru. The other burners light fine. Also I'm on LP.
  • 93 Answers
Replace that ignitor on that burner only. Not drawing enough amps to spark properly.
Posted on Oct 29, 2008
SOURCE:
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
Feb 20, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
My GE Monogram gas range will not light. The igniter keeps going off but the gas will not light.
Hi, sometimes cooking spills stop the ignitor from working. Clean the cook top thoroughly and try it again. Spills can also make the ignitor go off randomly when you are not operating your cooker. Check if the ignition point where the zap comes from is not turned or bent too far from its original position. If you have a gas shut off make sure it is fully open to supply enough gas. If all else fails buy a cheap hand held ignitor to start your gas stove. If the cause is a spill which sometimes the problem can persist even after cleaning it may take a while for it to work again. If the problem is with all six burners then your ignitor probably needs replacing. When you hear the ignitor zap check to see if the electronic zap appears to jump across to the edge of the burner. If it doesn't it will not light the flame no matter how many times you try. I hope this helps you.
Aug 21, 2012 | General Electric GE Monogram 48""...
On a gas 5 burner Jenn-Aire the middle largest burner suddenly will not spark or ignite,; it just clicks
The problem could be that there is a grease film the is prevnting the ignitor from sparking and the metal lid on the burner could be slightly off. Simply clean the burner with a non greasy cleaner and make sure the burner lid is on properly.
Jun 26, 2009 | Cooktops
Electric ignitor does not work at all on Jenn-Air Gas cooktop
need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
Jun 21, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
The ignitor sparking will not stop in after the
when you turn the knob or push a switch is going to the on posicion so that means that the switch is stuck in one of the knobs , you just have to see witch one is stuck
Jun 18, 2009 | Wolf Range 30 in. SCB30C Gas Cooktop
Bad ignitor needs replacement
it may just need cleaning at where it sparks to the burner if it is sparking back down the electrode then it is cracked . Some igniters pull out others have a screw that holds them in.
Oct 23, 2017 | Jenn-Air JGC9430ADS Gas Cooktop
Viking stove ignitor
the continues to click problem, for e it was only when my smaller burner was lit. theo others were ok. When I took the burner apart it was very dirty. I cleaned it up (a wire brush in my drill press) and it works fine now. I think it was just bad electrical conduction.
Aug 20, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Wrong ignitor starts when burner is turned on.
Sounds like you have a bad ignitor on that burner.
Sep 25, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Jenn-Air JGC8536 Gas Cooktop Logo
505 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
Norman Worley
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
