Question about LG RUMOR Cellular Phone
Display has D+24 under signal strength display. What is it?
Phone has completely cut off at times, not able to hear other party answer and other party has dead air on their end. Turn phone off and back on comes back okay but has now displayed the D+24 and do not know what it is. Cycled power again and still have display.
    Problem Solver:
That is a count down
Go to the menu settings/tools
Then tools
Then planner
And laat go to countdown
Hope this helps
Posted on Feb 18, 2011
  • 1 more comment
  • Littleman727 Feb 18, 2011
    To remove the c
    Thw d 24 is just a reminder it has nothing to do with your phOne behind mest up
    It just means that iys 24 days past the countdown date
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Do you know how to open the phone up and check for liqued damage? That is what it sounds like.
Posted on Nov 17, 2008
Radio cuts out
When it cuts out does the radio's display still work? Can you change channels but just not HEAR anything? Did you buy it from a private party or a dealer? Acura dealers may cover this under a warranty. Otherwise, time to join an Acura forum and look for answers there.
GL,
Td
Oct 01, 2012 | 2005 Acura TL
Tip
How to fix or repair your phone if it doesn't ring.
Please try the following troubleshooting tips:
Ensure that your phone is powered on and that there is sufficient signal strength. When you are at the start screen or in a call, the strength of the radio signal is indicated by the signal indicators on the left side of your phone''''s display. These indicators move up as the strength of the signal increases and down as the signal decreases. If there is a headset attached to the phone, it will not ring. You should be able to hear the ringing through the headset. Detach the headset and retest the phone to determine if that resolves the issue.
Check to see if the phone is in the "Silent" profile. If the phone is in the "Silent profile", change the "Silent" profile to the "Normal" profile and retest. To change your profile, please refer to your user guide.
Ensure that a ring tone has been enabled and the volume is not too low. (Please follow the instructions in your user guide.) If your phone goes straight to voice mail without ringing and your phone is powered on and you have sufficient signal strength, your service provider may need to reset your voicemail services. If your phone still will not ring, please submit your phone to repair so they may try to resolve the issue for you.
on Sep 28, 2010 | Cell Phones
How do I turn off the annoying beeping alert after the cycle is complete?
Hello Joanna,
Welcome to FixYa.
I think I can answer your question..."How do I turn off the annoying beeping alert after the cycle is complete? "
Follow these steps for the SHV6800 will be the same...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
SHU 9910-9920 Delicate/Econo
SHU 8800/8810 Quick Wash
**SHV 6800 Delay Start Hours**...should be applicable to yours, let me know if not.
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
If the display blinks with a "0", you will hear
no signal (indicates OFF).
If the display blinks with a "1", you will hear a
LOW volume signal.
If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
If the machine beeps, then the Cycle
Completion Signal has been enabled.
When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Oct 18, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?
Welcome to FixYa.
I think can answer your question..."How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?"
Follow these steps...
**SHU 9910-9920 Delicate/Econo** should be yours
• If the display blinks with a "0", you will hear
• If the display blinks with a "1", you will hear a
LOW volume signal.
• If the display blinks with a "2", you will hear a
function:
• If the machine beeps, then the Cycle
• When you push the button again and it does
program mode.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch SHU9915UC Dishwasher
No network coverage
Network IC Problem. We also faced the same problem here. The Signal Bar shows Full Strength for a few Seconds and immediately drops down to Zero Strength but it Displays the Operator Name.
Feb 23, 2010 | Sony Ericsson K550i Cellular Phone
Facing peculiar problme with my HTC Cruise Phone
Hi Nitin,
Select the network manually and try if other parties are able to reach you without any trouble.
Jan 08, 2010 | HTC Touch Cruise Smartphone
Cannot get a signal on my nokia 6021
You need a new phone, water and electronics are not a good thing.
Sep 21, 2017 | Nokia 6021 Cellular Phone
Signal problem
u try to switch off the mob and take the battery and sim.after some time u put all and see it may work. r other wise try the following web sites.......
http://www.simplemobilephones.com/
http://www.wirelessunlocks.co.uk/?gclid=CLGf8v6v7pICFRyrbwodI0l95w
http://www.gsmok.com/index.php?mod=shop&tree=038&gclid=CP-mg5Ww7pICFRspbwodViG_4w
http://www.mobile2mobile.net/unlock/RemoteunlockingMotorola.htm?gclid=CO60i7Kw7pICFQvWbgodCyUK3w
did my solution is helpful for u... yes means post ur ratings to me....
Jun 02, 2008 | Nokia 5200 Cellular Phone
Nokia5200
I am using Nokia 5200 cell phone for the last 6 months.Suddenly voice problem started as it is a flip phone the material base is very soft .If the other party calls me I can not hear the ring tone.when i contacted the service centre they told me that under the Keypads there is a case that holds the cover with 2 small clips ,that is broken which is difficult to find so better apply some adhesive or feviquick , After a month now the problem is of signal.My cell sometimes show no signal or shows only one bar of signal, Temporarily this can be sorted out if I press the phone between the "GO TO" KEY AND THE "GREEN ANSWER KEY" it comes with full signal.then after some times there will be no signal.Can anyone tell what will be the problem ?
May 31, 2008 | Nokia 5200 Cellular Phone
Phone calls won't connect
I have the same problem with my Verizon treo 755p. It will dial but I can't hear anything from the other end. I can receive calls but when I answer, I can't hear the person on the other end. I guess I need to visit Verizon to have them look at it or give me another phone.
Mar 30, 2008 | Palm Treo 755p Smartphone
LG RUMOR Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
