Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Will a kenmore fridge water work without filter
There is no filter in the fridge would this be the reason the water wont work
    President:
  • Kenmore Master
  • 2,651 Answers
This refrig assuming filter is located under the kickplate below frig??? is not reliant on having a filter in , you can safely use with no filter. so you may have an issue with water valve, ad nor incoming water supply
Posted on Nov 16, 2008
DOES THE KENMORE ELITE FRIDGE REQ A WATER FILTER
that depends if you want filtered water or not. if you like the taste of your tap water, then no. but if you have hard or well water, you'll want one to keep the pipes and solenoid clean.
Nov 12, 2009 | Kenmore Refrigerators
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Where the heck is the water filter?
some fridges don't have water filters, some have them behind the bottom grill or inside or on the back
Mar 24, 2009 | Kenmore Refrigerators
Water not coming out
Without knowing the model # filter is usually located on bottom of fridge in grill. When you depress the lever listen for the water valve in back of fridge to click on if not you may need a new water valve. What is the age and model # of fridge?
Nov 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Fridge - Bad Testing Water
Your refrigerator definitely has a water filter. If you have gone 5 years without replacing the filter, you and your family have probably been drinking contaminated water, for some time. Water filters should be replaced every three to six months. On some refrigerators, and in cases of higher water consumption, the filter must be changed every 60 days. Sears sells replacement filter cartridges for Kenmore refrigerators.
The water filter on your refrigerator is located at the front base of the unit, in the grille, below the freezer door. There, you will see a round cap. Turn the cap counter-clockwise, until the handle is vertical.Then, pull it out of the grille. The filter cartridge is attached to the cap. After removing the cap and filter, slide the cap off from the existing filter cartridge. Slide the cap on to a new cartridge, and re-insert with the cap handle in a vertical position. Push it in, firmly. Then, turn the cap clockwise, until the cap handle is horizontal.
Oct 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water gets to filter but not anywhere else
your water line that goes past the filter is clogged. use compressed air to flush out
Oct 17, 2008 | Kenmore 50522 / 50524 Side by Side...
Using without water filter
The effort it would take to eliminate filter would be too much. Just leave filter in place. If new house filter is working right you should never have to replace fridge filter and your water will be double-filtered :)
Jul 02, 2008 | LG LSC26905TT Side by Side Refrigerator
Filtered Water tastes "off"
Could be something foreign in the water line on the fridge side...or somewhere in the ice maker/ water dispenser inside the fridge......when it tastes stale....maybe there is something maybe mold or something that is part of the plastic ????
I usually add an in-line filter to my water line before it reaches the fridge so that 99% of the elements are trapped before it gets to the fridge. My original filter is still good. Maybe someone needs to inspect the ice maker with a a bright light and an inspection mirror to see if there is any thing that looks suspicious....this is only a suggestion but leaving the line disconnected for so long could even cause something like a small insect to crawl inside the line...
Mar 06, 2017 | Kenmore 56872 / 56874 / 56876 / 56879
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
362 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
