Question about Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
The motor shaft cover on our DLC-8 Plus food processer cracked and we can't find a replacement. Cuisinart says they no longer carry it. Any suggestions?
  • 1 more comment
  • JimChem Nov 27, 2008
    I have the same problem. Did you find a soultion or do I have to buy a new base unit?
    Does anyone know how the different DLC-8 models differ? I see there is a DLC-8M.
    Jim
  • eeaastone Dec 31, 2008
    I have a DLC8Plus with the same problem and wanted to know if anyone knows if the DLC-877BGTX-1 cover with large feed tube or the DLC-85 Pro Custom cover will fit on our broken tops???? I love my machine and missed it over Christmas..I need a new top desperately,
  • bcrisp Jan 28, 2009
    I have the same problem except my Cuisinart is a DLC8. No letters after it. Mine is 28 years old and in great condition except the motor shaft. I am hoping someone has an old machine that they could sell me the part.
    New Friend:
Sure, you can find it on amazon, here: Amazon com Cuisinart Motor Shaft cover. Hope this was helpful. have a nice day
Posted on Dec 03, 2014
I wrote in December with my problem and went on the web sites mentioned. A cover only cost $69.00. A new bowl and cover was $99.00. I only needed the cover. The new cover did not work and I ended up going to Macy's when they had the DLC-8S on sale for $99.00 and bought a new one. I took my blades with me and they fit the new machine. DON'T WASTE YOUR TIME AND MONEY (unless you find an old machine at a yard sale) THE PARTS COSTS AS MUCH AS A NEW MACHINE ON SALE. ees
Posted on Feb 12, 2009
I got the part from smallappliance.com and it went on fine. The problem is that now my old bowl and none of the blades fit on it. My model is too old. I called cuisinart and she said they no longer make parts for my machine. I would have to find an old one and get the part off of it.
Try http://www.abtecparts.com/cuisinartdlc8sc,dlc8mc.htm. I just broke mine, too, and this looks like the right part.
Posted on Jan 17, 2009
I hace DLC-8 PLUS CUISINART AND THE MOTOR DO NOT START, WHAT SHOULD i DO?
Posted on May 21, 2010
Hi...the motor shaft cover is available from a view sources on the web. Unfortunately, removal of the cover and replacement is far from easy and probably should be done by someone who knows what they are doing. I was able to remove the cracked cover but when I tried to replace it with the new one, it shattered into several pieces. I recommend you contact www.smallappliance.com They have the part and will install it for you.
Posted on Feb 11, 2009
  • 8,596 Answers
The letter after the DLC-8 is critical to finding the right part. Very hard to find. I would call the local small appliance shops until you find a collector with an old processor that would be willing to sell you the parts.
Posted on Dec 09, 2008
How do you get the motor shaft cover off? I need to replace the old one.
The shaft is spinning inside the sleeve. So is should not be hard to remove. With a DLC-7SP, I grabbed the spindle with some pliers, channel locks might do well and put a handle of a screwdriver between the pliers and the top deck and pried. Second attempt and it pulled up easily. Place the screwdriver beside one of the top deck screw covers to transfer force directly to the motor. Otherwise top deck would probably break.
Oct 07, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Cracked plastic sheath on the motor drive shaft
Clean the old shaft to remove any contamination.
New one can be driven on with a hammer and block of wood.
Jul 08, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Cuisinart DFP-11 Deluxe 11 Food Processor Motor Shaft Cover is broken. Can this part be replaced by the user? What part number is required? The manual does not provide this information and the processor...
You can get the Motor Shaft Covers for most if not all Cuisinart models from their customer service. They are not shown on the web under parts, but if you call them, they can help you get the right part. Just have your model # ready. For many, the part is $3 plus shipping and handling.
May 13, 2010 | Cuisinart DFP-11 Deluxe Food Processor
The drive shaft extending vertically from the motor base has developed a crack. This runs from the top of the shaft down to almost where the shaft enters the motor base. The effect is to make the...
I just called Cuisinart customer service. Depending on your model, it sould be under warranty. They sent me a new shaft sheath immediately with no expense.
Dec 09, 2009 | Cuisinart Little Pro Plus LPP 3 Cups Food...
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
Plastic housing cracked Cuisinart DFP-11 Deluxe food processor
The Motor Shaft Cover parts are not shown on the Cuisinart website under parts, but they are available if you call Customer Service. These parts are quite inexpensive (often $3 + s&h). Have your model number ready, and they can get the right one out to you.
Jan 03, 2009 | Cuisinart DLC-5 Food Processor
Broken plastic piece
if it is the motor shaft cover, amazon or smallappliance.com
Apr 07, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart Food processor
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Mar 25, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-8S Pro Custom Food Processor Logo
4,022 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
