Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water leaks on floor intermittenly from under middle
Kenmor side by side model 36358251890 intermitent water leak
underneath central area
whats wrong?
  • sfrankj Nov 21, 2008
    Guru abercass
    Your diagnosis and solution is right on the money!!
    I finally got to fix the unit yesterday.
    Your expertise and assistance is much appreciated....
    Thank you sfrankj
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine. or your plastic tubing carrying water to the door assy may have a crack (dry rot)
Posted on Nov 16, 2008
Water leaking under fridge
a contant runing of water is most likely a leak in the ice maker supply hose , an intermitant drip of water is a drip pan thats full in bottom of fridge (closest to floor ) this water comes from the auto defrost cycle most times this water evaporates away , but as fridge gets older it makes more frost that needs melted hence more water ,sometimes it over comes the pan and runs to floor , a good flashlight and getting down to look underneath usually tells you source of leak
Feb 20, 2015 | Refrigerators
Water leak from my Kenmore Coldspot Frig Model 106. 59792990
U have a restriction in drain tube under evaporator coil. So every time it goes into a defrost instead of going down the drain tube it is running over and out the front of fridge
Mar 08, 2013 | Kenmore 53642 / 53644 Side by Side...
I have a Kenmore side by side refrigerator, model number 106.53632300 that is leaking water and coming out onto the floor. The drain pan (I'm assuming that's what it is) underneath the fridge is full of...
Sorry to read about your problem, I hope this helps you out.
i would turn off water to the unit, if its hooked up.see if it stops.. if not you lost the unit and it is melting
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Kenmore 53642 / 53644 Side by Side...
I have a Kenmore refrigerator side-by-side with water/ice in door. Model number 363.9534783 serial number L431 12755. It is now intermitantly leaking water on the floor. A couple of days could go by with...
1. A door open partially will cause a frost build-up then thaw and run down to the floor. Check all doors for proper closure and educate other users.
2. An issue with an unhappy animal is quite common
3. Door switch intermittently causing a light to stay on ora fan to not run
4 Ice build up around ice door chute .
5. Water dripping into ice tray and overflowing. Replace water valve.
Oct 18, 2017 | Kenmore 57029 Side by Side Refrigerator
Water leaking on the floor
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in.
Good luck! :)
Vlad
First Choice Appliance
Jun 03, 2010 | Jenn-Air JCD2290HES Side by Side...
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore side by side - water dispenser leaks from time to time.
The problem is most likely at the water inlet valve located at the floor at the back of the refrigerator. These valves have a seal that should close off after use but sometimes stick or get a foreign object in the seat. It is intermittent causing only an occasional leak. Sadly, there is no service to the valve and you can only replace it. Good luck, AJ
May 22, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water leak @ bottom front left with water turned off
this quite simple, inside the freezer compartment lower half there is a removable inspection cover, or what you may call the rear interior wall. remove this cover/wall and underneath the cooling coils is a drain hole for the defrosted water to escape to the pan located under the refrig. This hole is obviously blocked with some object, possibly just ice. As it is blocked the defrosted ice in the form of water cant exit the normal way so it is over flowing onto the freezer floor. everytime the defost element comes on more water will leak. solution is to clear the drain hose possible with hair dryer , or gently running a firm but flexible plastic tube through the drain tube to push any blockage on through. This has to be done very slowly and carefully.
May 19, 2009 | Jenn-Air JSD2789GEW Side by Side...
Water leaking from bottom of refriderator
Is this a self defrost refrig. if it is then it might be doing that, which then you might want to look for the drain that is suppose to drain into this pan. It might be missing the pan try that, let us know thanks.
Dec 07, 2007 | Refrigerators
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
120 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
