TV keeps switching on and off but not staying on long enough for picture to appear. Sound comes on for a split second and off again. Have to turn of main power to switch unit off. Samsung 117inch rear projector. It's about 5 years old.
Had a feeling it was a blown globe. Found that it was when we pulled it out...now I just have ti find where they sell new ones to replace it. I tried looking on the net from shops to manufacturers and I tell you what...they make it so that you have to call in the professionals so you pay triple the price. I will keep trying though.
Koula
Posted on Nov 16, 2008
Have 40" Flat screen TV, first time use, have sound, and can switch channels, but the picture only stays on for a split second, Brand new just out of box.
read instruction manual and or call the customer service for the brand you have, last resort call the store where purchased and see if they will help.
Dec 03, 2012 | Televison & Video
Sony kv 27V15: No picture but sound
Hi! the trouble indicates that your television's picture is the culprit, have your unit check by a qualified technician for verification.
Sep 12, 2009 | Sony KV-27V15 27" TV
I share a TV antenna with my neighbour. there are three splitters in the line - one to give an output to a next door bedroom TV, a second gives a signal to their lounge TV with th other leg continuing to...
I suspect there is a Mast Head Amplifier to supply enough signal to split so many ways and the power supply is powered from the power socket supplying the neighbours TV. Switch it off and no/poor signal.
Mar 21, 2017 | Televison & Video
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
LCD TV PICTURE STAYS ON FOR 45 SECONDS THEN GOES OFF FOR 3 MINUTE
video board is shot, providing u still have sound. must replace.
Jan 27, 2009 | Dell W1700 17 in. HD-Ready LCD Television
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Sony KV-35S66 Audio ok but no Video
Is your picture somewhat weak ? This could be a problem with the picture tube . One thing you can try is to turn the screen control up just alittle at a time to see if the picture comes in . Once it does turn off and back on to see it it comes back on again . It might take 10 to 20 seconds but if it does your picture tube is weak . The control is on the flyback transformer it is the bottom control . Or it may be on the crt board on the picture tube . One thing to check once the picture comes is the video input . If you go to this mode and see faint white lines might want to try to turn the control down a little more to see if you can get them out and the picture stays on , if not thats how going to have to watch it . These picture tubes are expensive $500.00 to 700.00 depending on which one you have . One possible other thing if you tell me the picture was a great picture almost like brand new check the horizontal section for a loose connection as this will cause this problem . Don't get shocked and be carefull , Good luck
Mar 14, 2008 | Sony KV-35S26 35" TV
Televison & Video Logo
Top Televison & Video Experts
