Question about HP PSC 1210 All-In-One InkJet Printer
Hp 1210 paper will not feed
The printer sounds like it is pulling the paper or trying to but no paper moves I cannot see any rollers moving
  • 1 more comment
  • invitejinx Nov 19, 2008
    My HP PSC 1210 will not print. It keeps on saying "Out of Paper" Continue or
    Cancel Printing. The thing is... my PSC is new, theres no dust or the roller is not stuck. Is there any other troubleshooting step possible for this kind of issue?
  • Anonymous Mar 12, 2009
    I have the same problem and have cleaned the rollers with a damp cotton swab. The large roller that sits further inside the machine does not move when I attempt to print, even after cleaning.
  • Jared Lichtenthal Mar 12, 2009
    I cleaned the rollers with a damp cotton swab. The large roller that sits further inside the machine does not spin at all when I try to print, even after cleaning.
    Problem Solver:
  • 28 Answers
Hi ihimc1, over time dust and paper fibres can cause the rollers to stick, which can result in the paper not feeding please take these steps below to clean the rollers.
Turn off the all-in-one.Unplug the power cord from the back.Remove the rear access door. Clean the rollers one at a time using a clean cloth that is slightly dampened with water. Rotate the roller to clean the entire surface. Verify that the three paper feed rollers on the rear access door are clean and rotate freely.
Reinstall the rear access door and then plug the power cord back in.Turn the all-in-one back on.
Posted on Nov 16, 2008
Printer will not feed paper. Says it out of paper
are the feeder rollers moving? If so, the paper feeder rollers need to be cleaned.
Aug 06, 2009 | HP Office Equipment & Supplies
Hp psc 1400 inkjet fix, paper jam
Please try these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Print is too cut off at top of page
If the printer is pulling the paper properly then its the problem with rollers try these steps:
Jan 31, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Smudged image in HP 8000dn
You need a new TRANSFER ROLLER, it's the spongy roller under the drum.
Jan 16, 2009 | HP LJ-8000DN Laser Printer
Paper Jams
Nov 27, 2008 | HP Photosmart 2610xi All-In-One InkJet...
Paper won't feed.
I was not familiar with this model and pulled out a paper jam from the front. I now know this is a BIG NO-NO.
It now will take the paper to the beginning print position, sounds like it is printing but paper does not move any further - ever.
Nov 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
Will not feed paper
Sounds like the gears are out of alignment for the paper pick up tray.
May 28, 2008 | Brother HL-2070N Laser Printer
Print cradle cannot move error
hi,
this seems to be a hardware problem..... anyway try this...
> unplug the powerchord
> open the rear access door, and check whether there is any paper jammed or any bit of paper or thread stuck inside.... if so remove it
> clean the rollers using a lint free cloth
> close the rear access door
> open the door so that you will get full access to the cartridges...
> move the cartridges to and fro for several times manually with your hand
> close the door
> plug the power chord
> try again to copy multiple pages
thanks and regards
agnel
Mar 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
Paper will not feed into printer
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
HP PSC 1210 All-In-One InkJet Printer Logo
1,348 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
