Question about E-Machines eMachines Desktop PC
I think motherboard is shot
I have an emachine that just reboots after i put a new power supply in. the original power supply was shot. It starts up to the point where it asks to start windows in different modes. No matter which mode i try the computer shuts down and restarts to that point. I think the motherboard is shot. Am i correct or is there some other problem? If the motherboard is shot, is the cpu also shot? If the cpu not shot can i use it in a intel D845BG motherboard or intel 815
  • Nathaniel Netzke Nov 16, 2008
    Theres nothing wrong with the hard drive that has windows on it. I know that because i have put that hard drive in a different computer that works.
  • 300 Answers
You may be able to start the system restore from the repair console if you have your operating system boot CD by following the steps here.
Hope this helps. Please remember to rate thsi information.
Thanks
Posted on Nov 16, 2008
I have a T5026 EMachine won't power up. Green light on motherboard is on , could it be the switch , tried putting a new power supply box in it.
to see if the power swithc is the problem-
first, try to isolate the wire that connects the power switch to the motherboard. once you have deternined where the power switch plugs, then remove the wires from the motherboard leads and try to short the leads by connecting them with a metal device like a screwdriver tip. if the switch is broken, it will boot when shorted with the screwdriver. if it still will not boot, then you probably need either a new motherboard or a new cpu.
Nov 06, 2010 | E-Machines Emachine T5026 power supply **...
I'm trying to "rebuild" an old desktop computer of mine just to play and learn new things. It's an Emachines T2625 . Everything is in working order, but the integrated video seems to have went bad... I...
just start over and buy a motherboard and processor and memory and plug your stuff into it. you will need an operating system because the emachines operating system only workes with an emachines motherboard. emachines is the cheap brand from gateway and i have had nothing but trouble with those machines. Hope this helps and good luck
May 02, 2010 | E-Machines eMachines Desktop PC
My AMD computer started rebooting on its own minutes into a boot. I tried reinstalling a fresh copy of XP but it would reboot into the installation. It reboots in the BIOS setup so it is not the O/S. It...
this is a mobo setting try reseting the board using the bios jumper switch it to the reset possition turn on pc /switch off pc and replace to original setting see if this helps b4 replacing board
Jan 01, 2010 | Computers & Internet
Emachine T5508 desktop will not power on. There
thats not true but the fan skould be running if the power supply is working. take the power supply out and take it to best buy they can check it for you.bobg22
Nov 15, 2009 | E-Machines eMachines Desktop PC
MY BROTHER JUST GAVE ME THIS MOTHERBOARD FOR MY EMACHINE AND SAID IT CAME OUT OF AN EMACHINE, WHAT POWER SUPPLY DO i NEED TO INSTALL? Intel D845EPI Motherboard
i have seen those in some emachines but the original power supply stinks the processor needs a power supplie the has at least 300 watts but 400 plus is a better choice depending on which emachine case to have it might need ti have the case modded to fit a larger power supplie some emachine case have a plate mounted the allows both power supplie type to be used the small power supplies are garbage so go with the larger p4 power supplie most all should be able to be modded to fit in you case. Just remember the more power in mean the more power out.
Jun 10, 2009 | Intel Computers & Internet
T2682 emachine running fine video lite went yellow & HD also
The first thing you should do is remove the video card and try to boot the PC using the onboard video (video on the Motherboard) and see if that solves the problem. If it does, try putting the video card back in in a DIFFERENT PCI slot and try it again. Sometimes Windows loses its marbles about cards inserted into PCI slots. My nieces eMachine loses its marbles over the Wireless LAN card about once a year, so I just move it to a different slot (swap it with the phone modem card). If that makes it flaky again, try updating the video card drivers. If it doesn't help, your video card is shot.
If it isn't the video card, try taking out one memory chip at a time and booting with the first one in. If that doesn't do it, swap the memory chip with the other one and try booting it again. If needed, replace bad chips....
After that, it is probably the power supply or the MB itself. Swap out the power supply first. If it is not the power supply, then it is probably the MB, and you are SOL.
May 10, 2009 | E-Machines T2682 PC Desktop
On working on my mother's emachine W3410. Her
test the ram and the cpu, if its not one of those, then it IS the motherboard.
Mar 21, 2009 | E-Machines W3410 PC Desktop
I have an emachine T2984 that won't boot. No noise of any kind. I had another emachine T2625 that was working. I took the power supply out of the T2984 (that wouldn't boot) and put it in the T2625 and it...
Power supply sounds fine. If the pc won't power up it could be your motherboard. If the pc is powering up and you get a 'no signal' on your monitor it could be your gpu.
Jan 17, 2009 | E-Machines eMachines Refurbished EMA...
Emachine t2642 power supply
Apparently this model has a bad motherboard, which manifests as a power warning and eventually a refusal to boot up. You can replace the power supply (as far as I know, any generic one 250-watt or better will work) but it's unlikely to help. You can buy a new motherboard (and new power supply, if you want to) direct from eMachines, but it's also likely to fail pretty soon. Your best bet is to get a new computer (NOT an eMachines one) and put your hard drive in as a slave so you can get your data off.
Jun 19, 2008 | Computers & Internet
Emachine W1135
when ur starting the tower and it light are on and ur fan there is no problem with the power supply, i think that u rily need a new motherboard because ur board will not boot on start up..
Oct 17, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
E-Machines eMachines Desktop PC Logo
42 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
