Question about Whirlpool GSC9455 Top Load Washer
Kenmore Elite Calypso FL
Last year I had the same error code and someone from your site told me there was a way to reset the machine by pushing some buttons on the control panel. I thought it was Jeans/Colors and something else. Can anyone help?
  • Anonymous Nov 16, 2008
    same problem here. It started when I unplugged and replugged in the wall outlet when I detected it dead during initial cycle itself.
  • 15,935 Answers
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question ^#$$%
Posted on Sep 21, 2010
Keeps getting fl error message
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
Jan 27, 2016 | Washing Machines
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Error Code FL
The FL (Over Fill) error code indicates that the flood pressure switch is open (tripped). It is likely that you are getting the LD (Long Drain) fault code because the control detects that the flood pressure switch will not reset after running the drain pump. Your likely failure is in the flood pressure switch
Tapping on the flood pressure switch with the handle of a screw driver may reset it. Reassemble the washer and see if it will work properly. If not, then you will need to replace the flood pressure switch. The part number for the flood pressure switch is 8054767. You can order this part from the Sears PartsDirect website. The part number for the flood pressure switch is 8054767.
Jul 28, 2010 | Kenmore Washing Machines
Error code FL and does not drain completly
most probably needs the water pump replaced.  not hard to do if you are a little handy..  there were a lot of problems with this machine regarding the water pumps.
Jul 22, 2010 | Kenmore Washing Machines
How do you reset the overfill switch on the kenmore Elite calypso machine? It shows FL and we cut the power. There is water inside
Flood Condition:
Nov 15, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore elite with Calypso motion top load washer is reading FL and is asking for the overfill switch to be reset. water is leaking from underneath. what do i do besides turn the water off to the...
Flood Condition:
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite calypso model 11022086
FL means flood condiction..clean or replace your pump..
Jan 09, 2009 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE CALYPSO
Call Kenmore if you bought it new they may have a record of your serial number and be able to tell you what the error message means and if you need a service call to fix or you can do it yourself. my serial number is on the back of the washer on a sticker or a typed silver tag that is attached to the washer.
Oct 03, 2017 | Washing Machines
Kenmore Elite Calypso 21082
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@
Dec 16, 2007 | Kenmore Elite 21082
Whirlpool GSC9455 Top Load Washer Logo
347 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
