Question about Whirlpool LEB6200 Electric Dryer
Dryer runs but won't heat
Just replaced the heating element, checked all the wiring, and everything is connected.
  • 1 more comment
  • danmoyers Nov 25, 2008
    i have the same problem the thermofuse has continuity, the heating element has continuity the one one that doesnt have it is the small round thermostat piece by the thermofuse, can you tell me if it should have continuity or not before I go buy one, thanks
  • timeclockman Dec 11, 2008
    I have a Whirlpool Leb6000 that runs constantly with no heat and never shuts off. It is about 3 years old. How do I check to see if it is the heating element or something else.
  • derrickrobin Dec 13, 2008
    dryer runs but won't heat. where can i find the cleaning filter
    President:
  • Whirlpool Master
  • 2,651 Answers
Did you check the thermo stats for contiuity, very common issue would be a bl;own thermal fuse (2 inch white fuse)located behid the rear panel
Posted on Nov 16, 2008
I have a whirlpool front loader dryer duet, and I am not getting any heat! My husband and I took it all apart and cleaned everything and checked all the fuses and elemts everything was working just fine,...
make this test and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable. The heating elements faulty, replace it.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the cover .The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive and replace it
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 02, 2013 | Dryers
I replaced fuse, high limit thermostat and thermal cut off, still heater does not cycle on and off, just gets hotter and hotter., is this the thermistor or something bigger?
I would first check to see if the heating element is shorted out. When the vent or blower housing of the dryer get built up with a lot of lint the dryer won't vent out the heat properly and it can cause the heating element to warp and short out against the cabinet. To check for a shorted element you should unplug the dryer and remove the bottom panel. On the right side you will see the heating element, remove the two wires that connect to the element. With a multi-meter, check to see if you have continuity from either side of the element to the cabinet that hold the element. You should NOT have continuity when you check for this, if you do the element is shorted out and will need to be replaced. You can also pull out the element and do a visual inspection, sometimes you can see where the element coil is touching the housing. When the element is shorted out, it will continue to heat when the dryer isn't calling for heat. They will even heat with the dryer not running, so make sure to unplug it for safety reasons.
Jul 27, 2012 | Whirlpool Dryers
Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
Runs but will not heat
1.loose wiring----check terminals & wiring
2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
3.defective timer---replace
4.open heat element---replace heat element
5..defective operating thermostat---test thermostat, replace if defective
6.fan or it's pulley loose on shaft---tighten set screw
7.incorrect heat or timer settings---reset timer
8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 25, 2011 | Dryers
Dryer tubles does everything like its supposed to but does not heat up?
Hello there
Here is some things that could make the dryer not work properly meaning heat wise please click on the items listed in blue and go thru each of them this will help you troubleshoot this
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Apr 16, 2010 | Whirlpool LER5636P Electric Dryer
Dryer stopped heating. Runs fine but no heat all of a sudden.
Jan 05, 2010 | Whirlpool Dryers
It runs but won't heat up.
Jan 02, 2010 | Maytag Dryers
HE3t Kenmore dryer runs fine but suddenly stopped producing heat
Dec 31, 2009 | Kenmore Dryers
I checked everything now i am down to the timer will this cause the dryer not ti heat?
Heating element
Thermal fuse
Wiring
Aug 05, 2009 | Kenmore 63942 Dryer
Dryer not heating...everything seems OK
Y'ou are zeroing in on your problem. Read the info below and hopefully you will have your answer:
Heating element
Thermal fuse
Wiring
May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Ele. Dryer Model # lde7334a
Heating element
Thermal fuse
Wiring
Mar 31, 2009 | Dryers
Whirlpool LEB6200 Electric Dryer Logo
136 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
