Dell 1901fp power board problem
Hi, I have a Dell 1901fp lcd monitor and have a clicking noise coming from the power board. When I tap the board the clicking stops and the power comes on. When the screen comes on and shows my desktop it is to bright. Could you possibly guide me to what may be the problem.
I'm guessing the inverter transformer is faulty.
  • 274 Answers
Sounds like a loose connection or broken solder point. It could also be a bad inverter or CCFL.
Have it serviced or replaced.
Posted on Nov 17, 2008
A blue lock appears in the middle of my screen, you can not click on it. It disappears and comes back...sometimes open lock, sometimes closed. How do I get rid of it? Thank you!
Go here and look at how to disable the OSD lock; try holding the menu key for 15 seconds on the monitor.
Mar 09, 2011 | Dell E152FP 15" Flat Panel LCD Monitor
My Dell Flat Panel Monitor Model 1901FP goes black after it's on for 3 seconds. The green light stays on. I tried replacing cables. Any Solutions?
Inspect the power supply/inverter board for caps with domed tops first, if you do want to DIY repair down to component level, you can get a replacement board for $30.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 19, 2011 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
We r using dell lcd 1901fp when we power on it displays for 2 sec and then disply off but power led shows on, again we poweroff and on it it shows for two sec again disply disapper kindly suggest exact...
You could have an inverter board problem. The inverter supplies high voltage to the CCFL lamp which provides the back-lighting.
For service. parts and DIY info check out LCD Parts - click in this link to their WEB site : -
Oct 16, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
My lcd model # 1901FP when power on dispaly on after 2sec diplay off at this time power led show green .again power on /off button off and on the same (power on dispaly on after 2sec diplay off at this...
Hi, This is a common problem with LCD monitors and is usually a result of blown capacitors or it could be a failed backlight as the inverter will shut down if it detects this. You will need to open up your monitor and you will be able to see if any capacitors have "blown" but failure of a lot of components will cause this symptom.
Oct 14, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
DELL LCD 1901FP PlZ Find IC Number
The 8 pin IC is UC3843A, SMPS controller. The 14 pin IC is TEA1533AT.
Monitor Mike
Jan 28, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Dell 1901FP monitor
It is probably either a CCFL back light issue inside the LCD or a set of capacitors on the inverter/power supply board.
Would you be willing to part with it ?
Oct 26, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Computers & Internet Logo
642 people viewed this question
David Payne
David Payne
