Windows wont come up
When my computer is turned on it like goes to windows xp but it wonnt load windows it says i have a disk error it also makes a beeping noise until you hit a button
  • 300 Answers
That usually means there is a disk in a drive somewhere either floppy or cd. Just remove them and restart.
However it could mean that there is hard drive trouble also. I would need more details on what you see on the screen to determine that.
Also, by saying that "it also makes a beeping noise until you hit a button" it could be a stuck key on the keyboard. If none of the steps correct the issue please reply back with as much detail as possible.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 16, 2008
My dell latitude e5400 will start up but will not load windows xp. After the dell screen comes up and the bar across the bottom of the screen becomes full it goes to a blank screen and the icon for the...
You did not post exat error ,I think Windows OS can not detect the sata hard disk.You can set up the bios for set drive sata to IDE ,or you can make the Windows cd, along with the ACHI driver for detect the sata Hard disk.
Please follow the bellow link .
http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/
OR can do another way.
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Dell Latitude E5400 Laptop
My computer act like it is coming on then when it gets almost to the end of loading up it starts making noises and says on the windows xp load up page. Then if i do f8 and i choose the option of...
Replace the hard drive. That is the problem. The windows xp is corrupted due the hard drive error. It cannot continue to load on windows. Replace your hard drive.
Oct 15, 2010 | IBM ThinkPad 600X Notebook
When booting up my computer it goes to the error page prior to loading windows and asks what mode...regardless of choice it goes to windows logo screen and sits there and wont load...
1. check to see if your pc is compatible with the software. You didn't specify if you are reloading or installing for the first time.
2.You didn't give hard drive capacity or any information about the Pc you are loading Windows on.
You may not have enough capacity on the hard drive to load the full XP
Wndows xp requires about 2 GB of hard drive space then at least 10 GB of space for swap files and operation files.
Jun 13, 2010 | Compaq MS Windows XP Home Edition for PC
DELL DIMENSION 2400 ERROR STOP: 0x00000024, (0x00100203,0X82F898
You seem to have an error in the boot sequence of the Operating system. If you are unable to access the safte mode of the OS, then you will have to do a hard boot (boot from disk). My suggestion is seeing that you have a Dell, many times they will give you a boot disk or charge you $10 for one to be sent to you. Boot disks are not expensive at all.
Once you recieve the boot disk, go into the BIOS and change the boot sequence that it boots from your CD/DVD drive first instead of your hard drive (C). Then restart the computer with the disk in the disk drive and it will load from the disk.
If that does not work, you will have to do a reimage. For that you will need a Windows OS CD (XP, Vista - whatever OS you use). From there you can either have your data slaved over to another drive prior to reimaging, or if you dont mind loosing the data, just push in the Windows OS CD and it will ask if you want to over write or reimage, answer yes, and it will begin to wipe your computer and place a brand new copy of the OS on there.
Jan 02, 2010 | Dell Dimension 2400 PC Desktop
Toshiba Satelite M100 PC notebook wont start up windows XP
This sounds like a memory problem. Download and run memtest 86, it is a small iso file that you create a bootable cd from. Run this for at least one pass.
If the memory passes boot from your xp disk and choose R to get into the repair console. Once there type the following commands
fixboot
fixmbr
then try the install again. Hope this helps
Apr 29, 2009 | Toshiba Satellite M100 Notebook
Tried to do a restore with restore disc that came with the comput
There seems to be a problem with the operating system that is being installed. This often happens if you use the restore disks that came from another computer.
Are you sure that you used the disks that came with that exact computer? Does it flash a blue screen right before restarting the cycle?
Try the restore over again and if the problem persists, you may have to either order new restore disks for your computer or buy a fresh copy of Windows XP.
Apr 11, 2009 | eMachines T3604 PC Desktop
Windows could load installer for disk drive
Change the bios seting to default, check the event and see what it is say about that error and post it here.
Jan 16, 2009 | Asrock 775VM800 Motherboard
Computer wont go past a blue error screen
Your hard drive may have quit(died). No good solution other than replace the hard drive. Do you have a restore disk for you computer, to use after replacign the HD?
Here is the website for Acer PC
Dec 19, 2008 | Acer Computers & Internet
Error on windows load
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
This is what the boot.ini file should look like. Use U'r recovery disk to create or edit the ini file as above. U cannot use DOS 6.22 to create this file if U'r system is formated in NTFS.
If U don't have a recovery disk, make one from someone else's XP computer (DOS 7.xx).
May 10, 2008 | Dell Dimension 4600 PC Desktop
:( LAPTOP wont start
First ensure that the problem you have explained is due to a VIRUS or Laptop related.Remove the hard drive from your laptop and turn it ON and check if it remains ON until you SWITCH OFF, if yes then you could install MS Win XP or any OS supported and download the drivers for the OS from the manufacturer's web site and install them all one by one . It definitely would work
Apr 30, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
David Payne
David Payne
