Question about Corona Hedge Shear 10 1/2" Blade Aluminum Handle Hedge Shear Long Blade Aluminum Handle
Corona professional long-handled hedge shear
I had the shears professionally sharpened, and they still don't cut. What seems to be the problem? Thanks! Bonnie
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    does there seem to be a gap between the blades?
Try tightening the nut and bolt that hold the shears
Posted on Dec 01, 2008
HOW DO YOU SHARPPEN BLADES ON ELECTRIC HEDGE TRIMMER BUSHWACKER?
proper method is to use what is referred to as a "lapping table" professional sharpening shops have these , look in your yellow pages for scissor sharpening , but if your a skilled hand and have some time then a simple fine file will work as well , keep same angles on cutting edges ,approx. 30 degree angle
Jun 17, 2014 | Craftsman Bushwacker Bush/hedge Trimmer...
Tip
Sharpening your garden pruning shears
Every so often you will find that your gardening shears just aren't up to snuff. This will usually be most prominent when it get really difficult to cut through even the weakest of branches. Cleaning and sharpening your pruning shears is very simple and can be done in a matter of minutes.
To start you have to make sure that your shears are clean. Its not difficult to clean them, you can use a cleaning solution like scrubbing bubbles to get the dirt off, you just spray them and wipe them off with a soft cloth. If there is a lot of dirt or rust on the blade you might need to use a wire brush or a piece of steal wool to get them clean.
When you are satisfied with how clean the shears are you will need to get a sharpening stone. Carefully using your thumb on the convex blade (the big side of the shear) of the shears find the beveled edge. This will tell you the angle that you should be using to run the stone along the edge at.
When you have identified the angle that you're going to use to sharpen at, take the stone in your dominant hand and in the other hold the shears open. Applying a little bit of pressure rub the stone in small circles. You don't want to over do it, just a few times should be enough to get the blade sharp again.
The beveled edge should be the only blade that needs to be sharpened. On the flip side of the balde you shouldn't need to sharpen because it should be flat. In the case that you run your finger along the flat side and you find a bump you can use your stone to just smooth it out.
When you are satified with how smooth the blade sides are you should put a little bit of oil into the joint of the blades and open and close the blades a few times to get the oil into the gears. And finally using a cloth wipe the oil up and spread it over the blades. Wiping the oil over the blades will help to keep them from getting rusty.
To make sure that are ready to use you can test them on a piece of shrubbery or you can just head back out to the garden and get to work!
on Feb 05, 2014 | Garden
How do I sharpen my pruning shears?
You can use a mill file to sharpen your shears fairly easily. See this instructable page. Sharpen Hedge Shears with File
Jan 28, 2014 | Garden
Fiskars pruning stik head restringing
http://gmedia.fiskars.com/faq/9240replacement.pdf
Oct 14, 2012 | Fiskars 9840 Professional Pruning Shears,...
Where can I get the blades sharpened? Marco Stratford CT 06614
you can do it yourself with instructions from ehow.com. see below OR you can get it done at a small engine shop repair, where they fix the lawnmowers, slingtrimmers and chainsaws such as Makita, shtil or any other company that makes them. Hope this helps!
How to Sharpen Hedge Trimmer Blades Instructions Things You'll Need
  • Metal filer Eye protective goggles
  1. Sharpen Your Shears
    • 1 Place the hedge trimmers on a flat surface. Ensure that the blades are pointed away from your body.
    • 2 Position a pair of pliers around the bolt on your hedge trimmers. Clamp the pliers on the bolt securely.
    • 3 Twist the bolt counter-clockwise to remove it.
    • 4 Separate the paired blades.
    • 5 Hold one of the handles with the blade facing away from you. Slide a metal filer down the length of the blade until you reach the pointed end. Continue to sharpen the blade for a minute or two, and then do the same with the other blade.
    • 6 Test the blades with a piece of paper. Hold a piece of paper next to the blade, and then try to cut the paper without using a lot of force. If the paper slices easily, then your blades are completely sharpened. If the blades do not cut the paper, continue to sharpen the blades with the metal filer, and repeat the paper test.
Sep 13, 2011 | Black & Decker 16Inch Hedge Trimmer
Trimer buing Question
Double position trimmers For extended reach while on the ground, a double position trimmer avoids you having to climb up high by allowing you to adjust the handle into a right angle to the blades for a level cut across the top of the hedge. Clippings collector As you trim your hedge, collect those stray cuttings in a clippings collector for a neater finish. Automatic cut out An important safety feature, this automatically switches off the hedge trimmer once the trigger is released. Hand guard For reassuring safety, a hand guard will protect you from the moving blades and from falling cuttings as you work.
Aug 27, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
Wahl razor's not cutting, how do I fix it?
have you tried taking apart the blades and replacing them so that they line up together? Have you had a professional shear sharpener look at your blades? mabie all they need is to be sharpened again. Blades like knives or scissors need to be sharpened every once in a while. Also try replacing the blades with a new ones. The blades may have worn out. also try oiling the blades every once in a while.
Jun 24, 2008 | Wahl The Peanut Hair Trimmer
Corona Hedge Shear 10 1/2" Blade Aluminum Handle Hedge Shear Long Blade Aluminum Handle Logo
344 people viewed this question
Top Corona Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Corona Garden Expert? Answer questions, earn points and help others
