Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
No power to washing machine but fuse is ok...
Less than a month ago I bought a new Hotpoint Aqulatis AQXXD169PM washing machine. To operate, you press the 'on' switch and the LCD panel lights up and you choose your cycle. This morning I put the wahing in, pressed the button and nothing happens! No lights, no power. I took the fuse out and tried another but still nothing. I tried the original fuse in another appliance and its not blown, so why is this brand new machine not working?!
  • Anonymous Mar 25, 2014
    No lights on panel. Nothing happens when on/off switch is pressed. Power supply checked to switch.
I have the same issue on a different hotpoint. Ran the tester over everything inside power is getting in and all wiring is fine. I admit, I have not tried the door lock as I would presume the lights would still turn on even if the door lock is broken, but maybe I presume wrong?
Posted on Jul 14, 2010
    Novelist:
    Champion:
  • 244 Answers
Could be 2 things 1)try closing the door and banging the machine on the front next to where your door catch goes into the washer if it starts could have a lose wire or be faulty 2)if no1 doesnt work than it will be your mains filter which if blown power doesnt get to your machine if the machine is brand new and has manufacturers warranty then these are covered through the warranty and any tampering will void your warranty though should be covered for no less than a year
Posted on Aug 22, 2007
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
I have bought a new drum for a hotpoint aqxxd169pm. But it has come without the heating element integral with the drum. I do not know how to get the heater element out of the old drum and the refit it into...
heater element should only be held in by 1 bolt which runs from inside to outside element faxe......remove the nut..........carfully prise the element out...its only kept in place by rubber ..washing up liquid may help.......
cheers
Mar 09, 2015 | Hotpoint Washing Machines
Hotpoint Aqualtis AQXXD169PM
Could it be that some liquid or cleaning fluid has got into the plastic membrane, if it has one, behind the switches? I had a microwave that did this once.
Dec 26, 2013 | Washing Machines
Hi we have a Hotpoint Aqualtis AQXXD169PM washuing machine that is approx 3 years old. It has worked fin until a day or so ago when taking out the washing it was still soaking wet. After investigation it...
Assuming that the pump is okay and water is draining properly,Could be the speed control module or motor brushes,normally they last around 5 years and wear out simple to fit , you could remove one from the motor to check that is not worn right down to Zilch,if these are okay then you may need an engineer,as this is quite an expensive part to fit,you could phone hotpoint they charge around 100GBP,to repair......Parts are supplied free of charge with a call out hence the £100...hope you get on ok...
Mar 19, 2011 | Washing Machines
Washing machine stopped working,no power,no display checked fuse,fuse ok.hotpoint wt761
Check the power outlet, the plug and the cable or with the appropriate tester see if you have mains power where the power cable connects to the machine wiring.
Jan 30, 2011 | Hotpoint Ultima WF860 Front Load Washer
Water remains in the tub after spin cycle
Sounds to me like the Water Pump is bad. Hopefully if your machine is less than a year old you can get it fixed for free, if you bought it new it will have a 12 month warranty on it. If not you can always buy the manual for your washer and try to fix it yourself.
May 15, 2010 | Hotpoint Aquarius WD63 Front Load...
Door light no working so machine will not start
check power is getting to machine with suitable electrical screw driver.to do this remove top from machine and check live wire just inside rear of machine. fault could be door lock if you have power in machine
Feb 05, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
561 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
