Question about Dryers
Dryer squeals My dryer squeals. I have replaced the front glides and the felt "gasket" underneath the drum. I think I need to replace the rear drum bearing, everything I've read says there's a rear panel that has to be removed to get to it, but there's no panel on this model. How do I get to the bearing?
  • 370 Answers
You have to take the whole drum out of it. But if you want to save money you can just find the center of the drum bearing (hub kit) you can do this by looking for a small hole in the center back of the dryer. Then go up a half inch to an inch and drill a small hole in just the back and then pump oil into the hole. This should stop the squeeking.
Posted on Nov 17, 2008
Frigidaire affinity front load dryer
You need an upper felt and a rear drum bearing. If you buy the felt make sure you get the special adhesive to install it. The squeal maybe part of this or it could be the rear drum bearing. You can learn how to replace the rear drum bearing here in the article I wrote. http://gomestic.com/do-it-yourself/how-to-replace-a-frigidaire-dryer-rear-drum-bearing/
Jan 29, 2014 | Dryers
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
I'm finding pinholes in my clothing.
I'd be more suspicious of what you're putting through the wash, rather than the machine.
Aug 01, 2009 | Electrolux Frigidaire Affinity AGQ8700FE...
My clothes have brown marks on them that look like burn marks. has this been a problem with maytag neptune dryers? if so, what is going on?
Rollers
Rear seal
Front glides
Front seal
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Black stains sticking to white clothes on washing
Rollers
Rear seal
Front glides
Front seal
Jun 08, 2009 | Washing Machines
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
Rollers
Rear seal
Front glides
Front seal
Jun 07, 2009 | Dryers
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Torn clothes
Rollers
Rear seal
Front glides
Front seal
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Mar 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
164 people viewed this question
Top Dryers Experts
