Question about Philips 42PF7320A 42 in. Plasma HDTV
My Plasma TV is not working any more.
It's been on then when black, and the red LED is blinking seven (7) times.
  • 2 more comments
  • Anonymous Nov 20, 2008
    Same problem red light flashes 7 times with no picture.
  • Anonymous Nov 25, 2008
    Tv techs from authorized Philips service do not know what the problme with TV is? They suggest me to, if I want to go with repairs, to replace Y sus upper and lower board, power supply and logic board!!!
    They could have simply said to replace whole unit, buy another TV.
    Philips suCKs, and from now on I stay away from this brand name, for sure.
    I do not understand how come law did not force them to take care of these lemon TV's. Too many customers have filled compliance.
  • gcbehrensen Nov 27, 2008
    It started with half of the screen getting pink and then finally the whole screen black. The TV turned off itself and red light flashing seven times.
  • mikegloria77 Dec 07, 2008
    same problem no pic red light blinks 7 time anyone know anything
  • 52 Answers
SOURCE: NO PICTURE
7 blink error on that model is 8.6 volt error and generally caused by y main board. disconnect y main from power supply and if tv does not shut down and vs voltage comes up (test point on power supply) replace y main and both y upper and lower buffer boards as replacing one without other two could cause additional failures
Posted on Aug 14, 2008
  • 61 Answers
SOURCE: My Plasma TV is not working any more
Sounds like a scan problem if yu suspect the y-sus i suggs\est changing the drivers to
Posted on Nov 19, 2008
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
I had the same issue with 2 of these sets. It ended up being 2 capacitors were bad on the power supply. They are located towards the bottom of the board, you can visually see they were buldging and leaking slightly. I replaced them with 2 I salvaged out of an old computer (of same values) and the tv works as it did before.
Posted on Jan 08, 2009
  • 4 Answers
SOURCE: 42" philips plasma, black screen and flashing red light
I did the same, replaced two bulging capacitors...cost me 2.00 for the capacitors and $20 for the desoldering/soldering tools. First time doing anything close to this with any electronics...tv works great now.
Posted on Dec 31, 2009
  • 2336 Answers
SOURCE: seven red blinking led
Check the link below to find the parts that are causing the LED to blink 7 times and replace them to fix the plasma.
http://www.fixya.com/support/t5048641-easy_replace_capacitors
Posted on Jun 24, 2010
Panasonic TC-P55UT50 plasma went black. power light blinks 7 times, pauses blinks 7 times. Is this a power board? or Y-Sustain?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 06, 2016 | Panasonic Viera TC-P55UT50 55" 3D 1080p...
Panasonic 50 inch plasma th 50px80ua tv won't turn on and red light flashes seven times
Hi Steve, The link below is a YouTube video showing a panasonic television with 7 red flashes, Also there's videos down the right side of the link that may help as well... I hope this helps............CHEERS..
Panasonic TC P50S30 review seven led flash
May 01, 2016 | Panasonic Televison & Video
Picture went out and no audio, red light on power blinks seven times and repeats.
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Seven red blinking led
Jun 14, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Red LED light blinks 7 times when the set is turned on; no pictur
if you have the circuit diagram of your tv,check the horizontal polarisation IC closer to the line transformer and replace it.If it doesn't work,send the question again.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My panasonic plasma tv has some error! the red led bliks 7 times then pause and then 7 blinks again. what i can do? panasonic th-42pz70e
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Sep 12, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Nov 16, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Panasonic TH42PZ70B
Flashing RED lights in Panasonic TVs means a fatal error code. Unplug the TV, wait 1 minute and replug. If the LED still flashes it needs professional service.
Sep 04, 2008 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
NO PICTURE
Jun 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF7320A 42 in. Plasma HDTV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
