Question about Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl Low / No receive audio
The radio has good tx audio and pa audio, so the audio chip is working. I can create audio by do a "finger resitance" across the pcb. any ides where to look? everything on the radio is good except rx audio. Even took anther 148 and jumpered between the red wires on vloume, the radio would create sound from the other radio. RX does work, needle moves and you can pick up some sound by "fingering the pcb..... cobra148 gtl malaysia pcb 1995 build
  • 27 Answers
No audio out / low audio out....This is a constant problem with the COBRA 148 gtl....to get a good level of volume replace the
electro caps ...start around the two speaker wires and work back from there. I'm in the process of rebuilding a 148 gtl and have found caps that are leaky and dried out...after replacing nine the volume went up to a good level...now i need to fix the distortion
and background hash. Did you know that there are many posts
on FIXYA about this same problem I.E. great TX , great PA but poor , or no audio out. these sets have been made in sevetal countries...The sets made in Taiwan or China have poor quality
front panel pots (the carbon track is micro thin and simply wares through to the material the track is printed on) This has the same effect as removing a wire from a pot I.E. no audio. The good news is that 99% of parts in the radio are freely available and that includes the front panel controls. ONE WONDERS IF THE SET IS WORTH THE EFFORT !!!
CHEERS GUYS / GIRLS.
Posted on Jul 03, 2008
  •  Laron
    Laron Aug 20, 2011
    Good info so i figured you needed a vote. Thanks!!!!
  • 4 Answers
Check/replace the resistor that you can jump with your finger. I did the same on a resistor right beside the ta7222 whutever ic and got my receive back, I am sending out weak sound, but not enough to register anything on my tester yet. looking into my final transistor now and other ideas would be appreciated
Posted on Feb 20, 2007
Is it posible that the speaker plug-in is damaged
Posted on Dec 27, 2006
148nwgtl no audio just noise volume good, it had talkback wired in
would like to remove it
Posted on Jun 18, 2011
Is there any hiss coming from the speaker.check first common faults .check speaker might not be working .unplug check speaker with circuit tester to see if it has contact . or put an ex speaker at the rear next to pa plug.to see if another speaker will work.
Posted on Jan 28, 2007
Trc 424 with tx mod coming out of the internal speaker.
check for a resistor soldered across the P.A. jack and external speaker jack (solder side of the board) if you see one, remove it
Nov 17, 2013 | Radio Communications
Bad audio ic (yd1022) in cobra 29ltd
Your asking a question i guess.
If you dont have talkback plug your external speaker in the pa port and lower the volume now with the pa/cb switched to pa then key and talk if you have audio the chip is good..
if sill in doubt?
This is the 10 pin chip on the side. When testing this audio chip power up the radio with solder side top cover off use a metal probe with your finger on this probe touch pin 4 and it should squeal this indicates it is good.
Aug 21, 2011 | Cobra 29 LTD CB Radio
I got a cobra 21 from my grandparents house when we were cleaning it out and i am trying to hook up my pa to it but it wont work i checked all my wireing and i am getting power to the radio but the pa is...
If the audio chip is bad in radio you will hear no audio on cb either.
Are you sure it is in right port?
CB/PA switch on PA
Mic bad there is and audio wire the can be broken in mic this will still let needle move on meter.
Hope this helps
Jul 26, 2011 | Cobra 21 LTDST 40-Channels Base CB Radio
Hi My Cobra 29 LTD CB Radio have output signal, but no AUDIO for RX and TX to! What can be ?
Hello d e a a,
Welcome to FixYa.
My name is John and I will be assisting you with your issue today.
This problem could be several things!
#1. It could be the white wire has came un-soldered from the mic plug end!
#2. It could be the audio chip !
#3. Capacitor coming off the chip!
#4. Bad speaker, if you have no receive! Try inserting a PA speaker in the back and try it!
The tools you will need are Capilizer, OHM meter.
Let me know if you need any further assistance
Any comments are always welcome here and thanks for choosing
FixYa today and in the future
John
Feb 23, 2011 | Cobra 29 LTD CB Radio
Cobra 25 LTD classic no transmit or receive.I have checked the mic and finals and they check ok. I beleive it might be somewhere in the VCO.Any help
With the radio on, and the case off. Rub your finger gently across the contacts of the audio chip on the trace side of the board. If you hear noise from the speaker it is good. if you don't hear anything(make sure the speaker is hooked up) then the audio chip is bad. You need to change it.
Jan 27, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 142 gtl no audio on receive work on pa, an on ext spkr get talk back,,,,but there no talk back in radio.... no audio on int spkr. tx good...
Hi and welcome to FixYa,
Initially, the speaker of course has been checked?
Offhand, would partial schematic of the mic and speaker section help?
Good luck and thank you for asking FixYa.
Dec 18, 2009 | Cobra Radio Communications
Just a thought from Mechanic
Well, first your pa does not go thru your audio chip,take the cover off,with the radio circuit board down, the audio chip is on the right side-rail,the chip close to you, now turn it over and inspect it for cold solder joints,if you need to replace it you have to heat sink it with heat sink silicone, to remove it you need wire wick,it soaks up the solder,make sure you clean the old off with a paper towel,use 60-40 rosin core solder........hope this helps.....
Feb 05, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
2,445 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Ernest Taylor
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
