Question about Magellan RoadMate 2000 GPS Receiver
Magellan roadmate 2000 no power
I have had the unit for 2 to 3 years and use it infrequently. I do not leave it plugged into the cigarette lighter plug often either. For a while I was getting an error message that the battery was critically low.
Most recently I tried to power on the unit and it was dead. I purchased a new DC cord for the cigarette lighter and used the reset button although I still have no power. I checked the receptacle and it has power.
Looks like it is the battery, although when I called Magellan they said they do not sell the battery seperately. If I send it for repair it would probably be more economical to purchase a new unit like the Magellan 1412 since I have the air vent mount and the new unit would use the same one.
    President:
  • 1,111 Answers
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Posted on Nov 05, 2010
My Magellan Roadmate doesn't work anymore when I plug it into my cigarette lighter. It says the battery is low and it is shutting down. The unit did not come with a battery charger so I am confused about...
there could be a few reasons why this is happening....
there should be a light on the car charger that comes on when you plug it in, if it isnt on when not plugged in to the gps, but while plugged in to the lighter...either the lighter fuse is blown, or the charger is defective.
if the light is on, on the charger and it still wont stay powered on, it probably has a bad usb port (very common on this model) but it could also mean the charger (if not factory) is not compaible with the unit.
another way you can try and charge it (if you determine the chargers at fault) is to hook it up to your computer via the usb cord that should of been supplied with your unit.
HERE is your manual..it will show you the differant charging options..there is also updates on that page if you need them
let me know if you need more help.
bill
Aug 17, 2010 | Magellan RoadMate 1470 GPS Receiver
Magellan RoadMate 3000T. When plugged into the cigarette lighter, I only get a little red light in the upper right corner. How do I turn it on? I can't understand their symbols. (it is a hand me down from...
Download the manual from here.
The LED in the upper right corner seems to be a charging indicator, so this means that the power supply via the cigarette lighter seems to be ok.
To switch it on, press and hold the power button for 3 or 10 seconds (depends on the state of the device - whether in sleep mode or off).
Mar 11, 2010 | Magellan RoadMate 3000T GPS Receiver
Can my Magellan 1420 be left on the car charger all the time without overcharging the battery.
There is nothing in the manual about overcharging, or a warning no to leave the unit plugged in.
Most vehicle lighters do not have power when the car is off.
Some have tow ports, a lighter and a power port.
Check your port, if the lighter does not work when the vehicle is off then you don't have to worry.
You can also contact there support dept at there website.
Feb 15, 2010 | Magellan RoadMate 1400 Car GPS Receiver
After recently purchasing my Magellan Roadmate 1400 GPS the cigarette lighter adapter cord no longer charges the unit. I am able to charge it from a regular AC wall socket but it will not start up in my...
look in the tip of the DC charger and see if the fuse has blown. This is usually the case.
Be warned! starting the car with the GPS plugged into DC can blow your SIIRF chip... no more satellites! and an expensive repair. be thankful it was the fuse this time
Jul 06, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Power problem
is there a reset button you can press? if not try charging it for 10 mins then try and turn it on
Dec 29, 2008 | Magellan RoadMate 300 GPS Receiver
Magellan roadmate 300 wont stay on
It is the cigarette adapter, mine was doing the same thing until I bought a new adapter. When the old adapter plug to the GPS unit moved at all it would lose power.
Jan 13, 2008 | Magellan RoadMate 300 GPS Receiver
No power to unit, but powers on okay in house with AC power adapter
Not sure if you'll see this post, as you asked the question back in Nov, but I
thought I'd tell you what I know anyway.
I and my parents bought the same exact unit within a week of each other.
There's works, and mine does not.
I took their cradle, and hooked it to my GPS, and it came on, no problem.
I took my cradle, and hooked it to theirs, and boom, nothing.
So, with that, I was able to isolate that the problem is definitely in the cradle.
I went to the manufacturer website, registered my Magellan Roadmate 700,
and then I was able to contact customer support. I am writing to you as
I wait for their reply. Here's their website.
https://www.magellangps.com/users/registrationHelp.asp
Hope this helps!
Nov 12, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 800 - External Power Connection
The only thing I can think to add is a general question to Magellan asking why they let a four-year-old child design the power connector as "lightly" soldered to the main circuit board. Very dumb...
Sep 04, 2007 | Magellan RoadMate 800 GPS Receiver
Magellan Roadmate 700 does not power on
Hello, Rafster! Cigarette lighter plug problems are not uncommon, and - hopefully - this is the source of your problem. Because the green LED on your plug is lit, it would suggest that the FUSE inside is okay. Still, it's worth checking! The plug is easy to open, and the fuse easy to inspect/replace. IF the fuse is okay, the cord itself or the plug end that attaches to your Roadmate could be damaged. In order to determine this, you would have to check for voltage at the output end. But, you'd need a circuit tester and a wee bit of electronics knowledge to test it. If you don't have access to a tester, then the easiest test is to simply purchase a NEW cigarette lighter cord. You can get them at most retail discount stores (BestBuy; Circuit City; WalMart; etc.); RadioShack; or directly from Magellan. They're generally less than $10.00!
Jul 20, 2007 | Magellan RoadMate 700 GPS Receiver
Broken RoadMate 700
Here are a few tests you can do. Bear in mind if the unit has not been charged for some time and the internal battery is completely flat, you will need to leave the unit on charge for some time even to get a charge light from the LED. Leave it on charge for at least 2 hours. First, check the LED is lit when the cable is plugged in to the cigarette lighter socket and/or mains charger? If it is not, the fuse in the cigarette lighter adapter may be faulty or the charger may not be working. If the fthe LED is lit, then is power available at the end of the cable that connects to your unit? Use your DC voltmeter to check this. If no power is available here, then your cable/charger is faulty - obtain a new one. If there is power at the connector, then the unit may be faulty.
Jun 10, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 2000 GPS Receiver Logo
301 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
