Question about HP Office Equipment & Supplies
How do I print a selection from apage? and how do I print grayscale?
  • sandrawat486 Nov 16, 2008
    My printer is the HPPhotosmart C8180 All in one.
     There is no Page range ,no any colour button in the box which comes up after I press Print.I get a choice of all or page number.
     I am using a Mac....
  • 104 Answers
1) Let's assume you have clicked and dragged your mouse to select some text on a page. To print only the selected text, go to File (at the top of the page), then Print. You should then see a dialogue box which gives you the option to print a selection (on my hp printer, it is under 'Page Range').
You can also try the keyboard shortcut, Ctrl+P, to bring up the dialogue box.
Don't just click the printer icon you see on the menu, because that will print out the full page using your default settings.
2) You should be able to select grayscale by using the same dialogue box. Click the button marked 'Preferences', then the tab for 'Color' and you should see the grayscale option.
I don't know your printer model so the options may be slightly different for you, but hope this helps you get started.
Posted on Nov 16, 2008
  • eecom Nov 16, 2008
    Thank you for the clarification. I understand your question more clearly now. This is one for a Mac specialist (ie, not me! :))
    Thanks for your feedback, and I hope you find a solution soon.
I want to print word documents for B/W but I could not find black/grayscale
Hi
You need to get into Printer Preferences, where you can select black/grayscale from the Print Options list. Following this link:
https://files.support.epson.com/pdf/xp400_/xp400_ug.pdf
will take you directly to a manual in pdf format which you can save to your computer for future reference. The section you want starts on page 49 and on page 50, there is a screen shot of the properties you need to get to on the computer, to put a tick in the "Black/Grayscale" box.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Epson Xp-400 Small In One
I changed the drum to my HP LJ 2500L and now ot only prints in black and white. I have triple checked it's the right drum and there are no errors showing up. What's the problem?
Print a Configuration page, if it is grayscale, you probably installed a bad drum.
Make sure that "color" mode is selected in the program you are using or the printer driver. Check and see if "grayscale is selected.
If you are printing transparencies, they ONLY print grayscale.
Go to hp.com and download the latest drivers.
Apr 05, 2011 | HP LaserJet 2500L Printer
HP L7700 officejet printer leaves streaks on black ink lines only. Have cleaned heads repeatedly, changed black and color cartridges - nothing works.
Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Nov 28, 2009 | HP Office Equipment & Supplies
Color toner used up even though I selected grayscale
Selecting grayscale only will also make use of your color. when u select grayscale, look under the print options and select black cartridge only and for more economic printing, use fast draft or draft printing.
Jun 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark Z705
In the printing preferences you need to select Black and white.
1. open the document you want to print
2. click file
3. click print
4. select printer from list, then click on preferences
5. look around the pages.
In Color tab I found a print in Grayscale - this setting will print the document in black and white colors, the pages may be diffrent on diffrent printers. look for black and white setting or Grayscale.
picture: printing preferences, color page on a hp printer, select grayscale with black cartridge only.
May 19, 2009 | Lexmark Z705 Inkjet Printer
When I want to print a clipart picture in grayscale, my printer still does a pinkish color. This is a problem with my church bulletin.
The software print setting is probably designated as color. Follow these steps to check this setting:
  1. In the software application you are trying to print from, click File , and then click Print . The Print dialog box opens.
  2. Make sure your printer is selected, then click Preferences . The printer Preferences dialog box opens.
  3. Select the Color tab, then make sure that the Print in grayscale option is selected.
Dec 14, 2008 | HP PSC 1410v All-in-One Printer
How to print with black/white only with brother MFC-3360C USB printer
Set the product software print setting to grayscale. Follow these steps to change this setting:
  3. Select the Color tab, then select the Print in grayscale option.
May 06, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP deskjet printer D2460
Welcome to Fixya !
I assume that the printer is set to print in grey scale as below. follow the same procedure to change it to colour mode. If its still priniting in the Grey scale mode, Then please check the ink level in the printer.
Print in grayscale
To print in grayscale
1. Open the Printer Properties dialog box.
2. Click the Color tab.
3. Click Print In Grayscale.
4. In the Print In Grayscale drop-down list, select an option.
5. Select any other print settings that you want, and then click OK.
Apr 03, 2008 | HP Deskjet 2460 InkJet Printer
Ben Johnson
