Question about GE JGBP26 Gas Kitchen Range
Self clean light blinks when you turn oven on (oven does not work)
Oven does not work,self cleaning light blinks when you turn the oven on. If you move the self clean handle over to the right and turn on the oven knob to clean mode then the light is solid and so is the oven light but nothing happens (oven does not turn on) any help thanks
  • Anonymous Mar 24, 2014
    how to clean a self cleaning oven
  • Anonymous Mar 31, 2014
    I am not able to push in & turn the oven temp knob in a CLOCKWISE direction to "Clean" as instructed in order to clean the oven - it only turns counterclockwise, & I can't complete the process to start the self-cleaning cycle because of that.
I had this same problem with mine (still posted under unsolved) This is the simpler model with the old turn style knob and the lever you slide over to lock the door for cleaning What I think (keep in mind I know little about ovens, more about cars) is that the switch that tells the oven the door is latched is staying engaged, and this is part of the lever mechanism. I cleaned and lubed this mechanism (obviously I would guess you want to use a food safe lubricant) and then moved the lever several times with the oven on so I could see if it turned on. After a few tries the cleaning light went off and the oven light came on. No, its not really a technical answer, all indications to me where that the problem was in the switch which is part of the latch mechanism. Good luck
Posted on Dec 25, 2006
    President:
  • 878 Answers
Check to see if you have it in the lock mode. Press bake and broil pads together for 2 seconds until SF shows in the display. Then press the self clean pad, the display will show loc off or loc on. Toggle to loc off by pressing the self clean pad and press start. Try this first. Catriver...post back.
Posted on Nov 26, 2006
I can 't get the door open
Self clean oven I assume. Look under the cover on top, and follow instructions for turning on and off self clean mode. If this does not work, and the door handle will not move, call a tech. to come. Do not try to force the handle. It will cost more to fix.
Nov 28, 2010 | Ovens
Self cleaning lock handle does not unlock
Unplug power, wait one hower and plug cord back.
That should reset the oven, if it does not, the oven timer control is clearly defective and should be replaced , you find parts here.
Oct 08, 2008 | Thermador Ovens
Self cleaning stops aoon asfter starting.
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 18, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door after self clean cycle won't unlock
Both the oven" ON " light and " Clean " light will flash when the clean has finished . When the " clean " light flashes , slide the latch handle to the left as far as it will go , then turn the " OVEN SET " knob to " OFF " to open the door.
Mar 26, 2010 | GE Profile JGS968SHSS Gas Kitchen Range
Turned on self clean on my GE Spectra JBP24B0B4WH Range
Hello Cliff Hendershot,
One USA manual ... said turn off power for 10 minutes
(sounds reasonable after looking up cost of control board)...
USA websites are not responding to your number.
Closest I could get was to a $78 (us dollar) control panel
>> ((IMPORTANT PART ... has a video that shows repair))
http://www.appliancepartspros.com/ge-oven-control-t09-wb27t11312-ap5177950.html
I could NOT get a good READ on your JBP24... page 8
So I attached a JBP19 (below)... Page 12.
The most COMMON reason to FAIL after a cleaning cycle
is your OVEN CONTROL is "off normal"
(You still do not have your MANUAL MODE restored).
Normal = "AUTOMATIC" LIGHT Off (NOT LIT)
Check your "oven controls"
else
Oven elements do break during routine use...
Check both roast & bake elements for continuity.
GE JBP19 Owner Manual Usingthe Oven
Carnac the Magnificent
Jun 08, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
DO NOT KNOW HOW TO USE SELF CLEAN ON OVEN?
Hi April,
Without a model number, I'm shooting in the dark but I'll give you basic instructions that fit for most ovens, OK?
First off the door has to be locked PRIOR to cleaning. Look around the top of the oven door, there should be a handle (for mechanical models). Rotate this handle from the left to the right to lock it. If there's no handle, that means your oven locks the door by itself when "Clean Mode" is selected.
Now, at the control panel, select "Clean". At this point, you may have options on the length of time it should clean, select 3 hours and hit "Start".
There ya go! Hope this helps. If not, DON'T RATE THIS SOLUTION! Just write back and provide the model number, I'll give you exact instructions with that. Deal? Cool.
SG
Mar 23, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
I don't remember how to use the self cleaning feature
Remove everything from the inside of the oven, lock the door if your model has a latch handle that you move from left to right to lock the door, then set the oven selector switch to clean.
Dec 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Blinking auto self clean light
There is probably a switch attached to the oven locking mechanism that need to be replaced. I had a similar problem on my GE electric oven and it worked for me.
Nov 16, 2008 | Kitchen Ranges
Gleb30tsa
find the circuit breaker panel and turn off the one labeled "oven". wait 30 minutes and restart. any luck?
May 31, 2007 | Frigidaire GLEB30T9D Electric Double Oven
Self clean light blinks, oven does not work
You were right. The locking mechanism switch somehow became jammed and the oven thought the door was locked, even though I could open the door. I didn't know if I was supposed to take the top off and moving the lever back and forth did not help. Finally I turned the oven on and just kind of jiggled the latch in the unlocked position. I kind of moved it back and forth furiously and the cleaning light stopped blinking and the oven light came on. I'm glad it is working now, but I will be manually cleaning my oven from now on! Thanks for your help.
Dec 25, 2006 | GE JGBP26 Gas Kitchen Range
Open Questions:
GE JGBP26 Gas Kitchen Range Logo
3,009 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
