Kenmore 417 44052400 front load washer does not spin at high spee
The washer does not spin out at high speed and my clothes are soaked after completing a cycle. I have check the hoses around the water pump and they are all clear. The machine pumps out water just fine. I ran a diagnostic and received error code 47. I do not know if my problem is with the wiring or with the front door sensor. How can I pinpoint the problem? How difficult will it be to repair the unit? What can I do to clear the problem?
  • Anonymous May 13, 2009
    washer spins, but not at high speed.
    Genius:
  • 1,028 Answers
Most likely door lock ..remove spring around front edge of door seal pull seal away and roll back(some earlier modes the front part of seal was glued on using a sharp knife edge cut seal and glue away from cabinet) remove the 2 screws holding lock to cabinet front and pull lock through opening remove wiring reinstall in reverse
Posted on Nov 16, 2008
Clothes are still very wet after the spin cycle.
sounds like not pumping very well, try cleaning the filter/ pump
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
Is there a water level setting control for the washer or does it automatically detect and control that? I wondered if the control that has the options high/med/low/hang dry/no spin(lights are on or off...
Water level is determined automatically by the load in the machine. A pressure switch senses the water level after the clothes soak up all they can and just enough more is added. The settings as you suspect are for the spin speed.
Eric
Sep 22, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer will not spin at high speed
check for any blockages around pump and air trap area.
Sep 14, 2009 | GE WBSR3140DW Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Apr 18, 2009 | Washing Machines
Final spin speed
unplug unit for about 2 minutes this will reset the computer if not inside the lower front panel SHOULD BE a tech sheet this will tell you how to put it in diag. mode and will tell you whats going on with codes and this tech sheet will give you the meanings
Dec 21, 2007 | Kenmore 43142 Front Load Washer
Washing Machines Logo
779 people viewed this question
Top Washing Machines Experts
