Question about Bose Companion 3 Computer Speakers
Control pod on bose companion 3
Suddenly one day the sound stopped working and the light on the control pod appears very dim. I can hear faint music but cant control the volume. Cant get any crisp sound like before. Music is so faint I have to put my ear to the speaker to hear anything. Can this be resolved by replacing the control pod? Or do I have to replace the whole system? Thank you.
  • 3 more comments
  • Tony Dec 02, 2008
    I heard a loud sound coming from the woofer and suddenly the sound went to faintly heard
  • Anonymous Dec 08, 2008
    The control pod does not respond to tapping between mute and ubnmute. Currently it is unnuted and I barely hear any music. I've connected my monitor in-line speakers to test the audio card and the audio card works. Appears the problem is with the control pod
  • urackem Dec 28, 2008
    It is exactly as rbszochet30 described. Is there anything else I can check? I know the sound card is functioning properly.
  • clauds88 Jan 01, 2009
    same problem as described below
  • adnm Nov 27, 2011
    I have the exact problem. Did you find a solution? Thanks!
  • 365 Answers
Try to check the circuit board with an expert
Posted on Nov 24, 2008
Control pod failure on bose companion speakers , the sound stops
check your wiring connections, sounds like you may have intermittent connection somewhere, and this is the most likely culprit. be certain that all connections are solid. multi pin plugs are notorious for having one bad pin.
Mar 06, 2015 | Bose Companion 5 Multimedia Speaker System...
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
Hi, I bought BOSE Companion 3 Series II in May 2009. They were fabulous and were working fine until today. They have now suddenly stopped working. Even the LED on the Pod is not lighting-up. Can anybody...
This appears to be a power supply issue, since Bose does all warranty and out of warranty work I recommend you get it serviced through them, they carry all the parts that are not available to anyone else.
Apr 21, 2012 | Bose Audio Players & Recorders
I've had the series 1 companion 3 for almost 4
Hi, This could just be a sign that your Speaker system is wearing out , and done its due...Also have you had any Power Failures or surge's Lately , if so then it could of damaged the Speakers aswell..
Hope you come right bud
Happy new year
Dec 28, 2009 | Bose Companion 3 Computer Speakers
Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Jan 29, 2009 | Bose Companion 3 Computer Speakers
Where Can I purchase a bose companion 5 control pod?
You can purchase it from amazon, click here Amazon com bose control pod and choose, which one fits to you.
I hope I was helpful
enjoy
Nov 25, 2008 | Bose Companion 3 Computer Speakers
Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Oct 03, 2008 | Bose Companion 3 Computer Speakers
Can't hear voice of singer on speakers, more of an echo sound
Hello Shemon
Well, there is 2 option here, 1) your sound speakers are not connected corretly or in the right slots on the sound card.
2) your sound card, (internal or external) you have to use the mixer on software to put the right channels for the music you heard. try configuring in control panel, in multimedia devices, the speakers. for 5.1 system, or 2 way speakers or 3
try again
Dec 25, 2007 | Bose Companion 3 Computer Speakers
Dim Light on Control Pod...very low volume output
I just fixed this exact problem. There is only 1-2 volts feeding the preamp IC's pin 4 JRC 2059. Positive side of C313 should be 12v(B+ to IC's) found shorted transistor just above C313. Collector goes to V+ 15v from power supply, Emitter feeds the preamp IC's. I used a 2sc3904 (NTE123Ap) unit back up and running
Sep 14, 2007 | Bose Companion 3 Computer Speakers
Bose Companion 3 Computer Speakers Logo
2,382 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
