I lose reception on my hdtv every 20 to 30 minutes the screen flashes snow and black for ten seconds. I have time warner cable the cable guy replace the entire cable line from the street to my house and put new cable wire in my house and replaced the splitters I also replaced the cable box I have a vizio 50 plasma
  • Roland Vilches
    Roland Vilches Nov 16, 2008
    When I press the input button and switch to analog on the vizio tv it doesnt lose reception only when i switch to hdtv also i used signal booster and had the same problems with the hdtv also I change all the cable connections. The tv has been problem free for a year just started having this problem for 2 weeks.
  • Roland Vilches
    If it is the tuner why dont i lose reception when i put the tv on sdtv only have problems hdtv and where do i purchse a tune.
    Genius:
  • 1,913 Answers
Check your power supply eartings and voltage fluctuation.
try your projection in other places.
Posted on Nov 16, 2008
  • 320 Answers
Just an FYI, if you're using the HDMI output of your cable box, that COULD be where your problems are coming from. I fix TV's every day and have seen MULTIPLE instances of no or intermittent sound and picture, always with HDMI output of Time Warner boxes. I have seen customers exchange boxes 3 and 4 times and still have the problem. My solution to this is to have them use the COMPONENT output of the cable box rather than HDMI as TW appears to have handshake issues with their HDMI outputs on Scientific Atlanta and Motorola boxes. The other solution is to go with a satellite provider, as I have yet to see an issue with the HDMI output on a Direct TV or DIsh box.
    Sergeant:
  • 207 Answers
Frecoso,
I don't have all the details of your situation, so I will give you my best theory's as to the cause of your problem.
First thing I'd check is the digital tuner that Time Warner should have issued you. This box should be one of the newer varieties capable of decoding the HD signals that TW transmits through the cable line and buffers them for optimum quality.
Second verify that the station you are watching IS transmitted in HD, If it is NOT then your tuner will have to "Upscale" it to meet your picture dimensions. This may cause the "Pixelation" and Lag that you are experiencing
Third Do you have alot of devices on your cable service. Examples: more than 3 TV's and or (1 or more roadrunner) connections, VOIP phone service. Each device on the system takes a portion of the signal strength from the line and may cause poor reception quality. If this LAST case is likely to be the problem TW can put what is called a signal booster on the junction box on the distribution NODE usually mounted to telephone pole outside your home (Its kinda like a signal booster you could buy, but MUCH higher powered) But you would HAVE to ask them to put it in and they WILL charge you for a service call to do so.
Hopefully this has been helpful to you.
Best Regards,
Dave and the FixYa team
  • David Preston
    David Preston Nov 16, 2008
    The tuner should be the box that Time Warner gave you to receive digital service.
    I read now that you said you had the cable box replaced, so THAT shouldn't have been part of the problems. Though if you do think it MIGHT be part of the issue you CAN ask TW for an upgrade to a newer box. Maybe even a DVR one ;)
    Sorry for the confusion
    Dave
    Scholar:
  • 66 Answers
I don`t know exactly what the cable company told you but i do know that with a cable comp I had. They told me I had digitel TV through my cable. I didn`t notice right away but my digital channels just where not that good anymore. After calling and having them check everything and telling me that evrything was ok. I still had a problem with my picture, It just wasn`t like it used to be. I repeatedly called untill one day I got the right person. He was a regional director or something like that for all of south and central US. He then told me that they had be having problems with the digital channels in and around my area of southeast missouri. That I may vary well not be getting digital all the time. and some of the stations I was told where digital where in fact not, at least not through them. They ended by refunding a good share of my cable bill I had paid for digital cable for the preceeding 6 months.
My point is. You realy need an electronic technician to check to see if you are actually getting HDTV through your cable. It seems that if the TV is ok on analog and messes up on HDTV then there is problem with the signal coming into the house.Sence you have had everything replaced inside of the house.
  • 905 Answers
The tuner is failing and needs to be replaced , thats why it works for a little while , but it will only get worse and cause other problems if not repaired soon
electech
  • jason Nov 16, 2008
    the difference is analog and digital inputs
    are you using the hdmi input ? because mistersony is right about the hdmi input problems
    snowy picture is a sign of a bad tuner
    Brigadier General:
  • 6,966 Answers
Let's try process of elimination:
  • entire cable replace - then not a source/supply/provider issue. they would have checked the incoming signal level;
  • new cable wire in your house - then not a distribution issue. Do you have another TV that could be used to check if the same symptoms appear?
  • cable box replaced - then not a processing issue. How is the cable box connected to the Vizio plasma?
  • Have you tried attaching temporarily the cable box to another TV?
Offhand, this appears to be a cable box/provider issue but I am also inclined to think that it is a issue with the Vizio, perhaps compatibility. Have you tried another source for the Vizio, say a DVD?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa
  • Louie  Role
    Louie Role Nov 16, 2008
    Based on your subsequent post, it is likely that just recently, the signal to your are has changed. A few things you could try:
    • run your system without the signal booster;
    • feed the cable box from another cable source (temporarily) such as from the bedroom with the use of an extension RF patch cord.
  • 734 Answers
The Service Technician arrived and told me that the channels on satellite 129 has not moved to another satellite. He didn't think satellite 148 had the bandwidth for all the HD channels anyway, though he did state that it would be great if it could happen because the Pacific Northwest can easily recieve reception from 148.
They did remove my 20" dish and replaced it with a 24" dish anyway, and I was not charged for service call or dish replacement. I asked about putting a 30" dish for reception and he told me that signal strength would only move up 5 with a 30" dish to around 40 on signal strength, but I would still lose satellite reception periodically anyway. I was told it would cost me around a couple hundred for a 30" dish replacement, but they didn't have one with them and would have to order one. I'm getting around 35 signal strength right now with the new 24" dish.
The Installer told me that most CSR's don't know about the reception problem in the Northwest because they are mostly from the East Coast and there is a high turnover rate of CSR's, but the high-level CSR's do, so it would be best to ask for supervisor's until you get someone who knows the reception problem over here. Still, it sounds like there's nothing much they can do anyway.
So, until a new satellite is put up, Western Washington and Western Oregon HD Dish customers will continue to lose satellite reception for HD channels periodically.
  • futureloginn
    futureloginn Nov 16, 2008
    The SD is always lousy on a large screen. You might want to try an amplified splitter. You should consider your cable runs from the splitter to the other televisions. The splitter should be of the proper frequency range. I would take the cable coming into the house and using a one in, two out splitter take one direct to your HDTV and take the other to an amplified splitter.
  • futureloginn
    That sounds like a cable company compression problem. As new channels are added (to keep up with the competition) the cable co. has to compress the signal more due to limited bandwidth. More compression equals pixelization, picture freeze, signal loss
    Genius:
  • 1,550 Answers
Do you have any kind of signal attenuator to strengthen the incoming signal .
Losing picture when screen shows a white background
Try switching to a different cable provider. I have had many problems with their a/v boxes in the past and have found they aren't very compatible with most newer tv's. Time Warner/Comcast boxes have worked great for me.
Also, don't listen to the electronics stores, they are just out to make money, although it may fix your problem, it is unnecessary.
Check your tv's manual for settings that may fix that problem, like "source refresh time" or anything to do with signal loss and refresh rates.
For more info, contact me.
Thanks for asking!
-Josh
Feb 26, 2010 | Mitsubishi WD-Y65 65" HDTV
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
Tv screen will freeze up after running and then go out while the lights blink on and off. I have replaced the bulb, but that did not take care of the problem
I have the same problem. It flashes ten times when booting up. Once it starts displaying a video image, it freezes after 10 seconds and then cycles off. It cycles on a minute or more later.
Nov 11, 2009 | InFocus ScreenPlay 61" Rear Projection...
Numbers 2.4.4-16 appear on the bottom of screen(alternate sides)
this same problem was on my grandma's television once she got a cable box recently. she has time warner cable. we called time warner and explained this to them, and they said it was something with the update.. and the lady said you can reset the box, but it is best for the cable company to reboot the cable box. within a matter of minutes, the company reset her box and the numbers were no longer an issue. so it's just a matter of resetting your cable.
Apr 08, 2009 | Hitachi 57F500 57" Rear Projection...
According to Time Warner cable I no longer have TV Guide On Screen because the PBS piggy back signal is no longer being sent. Apparently, PBS is getting ready for HDTV. I live in Wilmington NC and we went...
PBS in my area says that my cable provider, Time Warner is no longer using the analog signal that contains TV Guide On Screen info. They did this to prepare for digital in Feb. Time Warner says they are waiting for Gemstar/Macrovision to provide a method for the On Screen feature to work. My source at PBS reckons there are over 25,000 cable card TV's that may lose this On Screen Guide. Apparently there is no legal requirement for TV Guide or your cable provider to send the guide.
Users may want to try and contact TV-Guide/Gemstar/Macrovision directly at their toll free number
1-800-386-7380. This may not be a solution but it may be a consolation for users wanting to know why they have lost their TV Guide On -Screen.
Dec 04, 2008 | Televison & Video
P50 VIZIO WHEN ON HDTV I GET SNOW
it's probably the Time Warner cable box that have issue and not the TV. Try using a DVD player and test the same input, it should work fine.
Nov 15, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
I installed Netgear wnr834b on time warner cable. it works for a minute but then power and link lights go orange and i lose connection. have replaced router but still same thing. also replaced modem and...
If you already replace the modem and the router so it only means that the problem is with your Time warner internet connection line , did you already contact time warner and let them check your internet line to make sure the signal from them is strong and working fine if not contact them...
Oct 24, 2008 | Computers & Internet
PS3 flashes white snow for only 1-2 sec. during gameplay. Is there a fix?
I also have the same problem. Just bought my PS3 today and have found that it flashes to static for a few milliseconds at any given time. I know it isn't my TV and I also know that there is nothing wrong with the console. I put it down to the HDMI cable - I chose an exceedingly long one that spans 5 meters. Personally, I think that the output voltages from the PS3's HDMI jack are lower than those found on other devices - so I presume that long cables with high resistances (in other words, cables that are fairly long and very cheap) are the cause of signal loss. Try a shorter, higher quality cable. I am going to return the one that I bought and buy a shorter one tommorow.
Jul 17, 2008 | Sony Playstation 3 (PS3) Console
Lightning strike
press menu and input both in together on the front of the TV and hold them both in together for 8 seconds then let me know if the LED blinks a two digit code.
Jun 10, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
