Question about Gaggenau AH 400-701 Kitchen Hood
No Power - Problem locating fuse
The hood has lost power and I am trying to verify that it is not a problem with the fuse. I was told that to locate the fuse, I need to take the duct outer panel off. I unscrewed the top screws, thinking I could easily take the cover off. However, that was not the case. Next, I tried removing the bottom portion of the hood, thinking that the cover would slide down, but this did not work. So, I am thinking I may need to take the motor off to find what I am looking for, but this seems ridiculous. Does anyone have a recommendation to be able to find the fuse on this hood?
  • lsqme Nov 20, 2007
    I had the same problem with a ZMI-M90S. I took off the filters and the metal pieces under the filters. There were 2 plastic cases against the wall. I took the lid off the bottom one, but didn't see anything that looked like a fuse. I didn't check the top one. Any ideas?
  • 27 Answers
Unfortunately on these island hung types you have to drop top duct slightly and remove the WHOLE canopy (yes I know it's huge) and then remove the duct completely to expose the box housing the pc board. The only other way is to remove all the panels from the bottom and remove canopy to bottom, and then slide ducts down untill box is exposed. In any event this is not an easy job, and I wouyld advise expertise. Good Luck! Oshie
Posted on Jun 26, 2007
I have repaired many Gaggenau extractors before. On this model you were correct to remove two top screws from duct. The top and lower duct slide inside each other, and should be removed as 1 unit, by lifting the lower duct UP and then away from the wall. Sometimes there are two further screws holding the bottom duct to the canopy. Remove the filters and check for screws from inside canopy. Once ducts are removed you will see the a box, metal or plastic. Remove lid and you will see the pc board. There is a 10A fuse on there. Some models do not have fuses, and the whole board should be replaced! Good luck! C.
Posted on Jun 25, 2007
Fuse location on 1999 Damon challenger class A valvac power mirrors.
The fuse box you are looking for is located under the front hood, inside the battery control center (black metal box on the drivers side firewall. The inside cover should be labeled to identify the power mirrors. Possibly a 7.5 amp fuse but it may vary with other manufacturers. Use a multi-meter to ohm out the fuses. While you are there, go ahead and check other fuses to verify. Depending on the types of fuses used you may have to pull fuses out to check them of you cannot check while they are installed in the fuse block.
Apr 02, 2018 | RVs
Ive got 2008 1.8 petrol Ford Focus titanium with lose of power steering where is power steering fuse found and what number in location in fuse box
If this is a fuse issue it blew for a reason. For location of fuse reference your owner's manual, the info is there. The fuse box I would concentrate on is the one under the hood.
Jul 22, 2016 | Ford Cars & Trucks
Anyone know why my Clock and Radio have no power?
blown fuse check under the hood or under the dash check your manual to find the exact locations
Jun 16, 2015 | 1999 Mitsubishi Montero Sport
Where under the hood would my fuse box be for a 1997 jimmy gmc truck my power windows dodesn;t work
there is one under the backseat on the driver side , it may be located there .
Feb 22, 2013 | 2004 GMC Envoy
I WAS DRIVING DOWN THE HIGHWAY AND LOST GAS POWER PULLED OVER SHUT IT OFF AND TRIED TO RESTART BUT IT WOULD ONLY CRANK
check your fuel pump fuse, may have blown its located under hood in fuse box compartment
Aug 01, 2011 | 1999 Dodge Caravan
My aux power points are not working. What is the
there are two auxillary power sockets. The console aux power socket is protected by fuse #4 in the battery junction box. The second aux socket located in the rear is protected by fuse #1 in the battery junction box. Both fuses are 20 amp fuses. The battery junction box is the fuse box located under the hood, usually on the driver side.
Feb 15, 2010 | 2001 Ford Expedition
Which fuse on the fuse panel is the one for the power windows i lost the manual
I know thta, for a 2002 Ford Explorer, the 30 amp circuit breaker in location #62 of the power distribution box in the engine compartment is the power window circuit breaker. (unfortunately in the 2002 owner's manuals it is labelled accessory delay ) later years are labelled as the power window circuit breaker.
Hope helped with this. Remember rated this help, good luck.
Nov 24, 2009 | 2003 Ford Explorer
2001 Dodge Grand Caravan: Power to upper cigarette/power outlet?
the fuse box for interior acc. should be located left of steering wheel underneath. or behind access panel left of steering wheel on lower dash
Nov 15, 2008 | 2000 Dodge Caravan
Gaggenau AH 400-701 Kitchen Hood Logo
395 people viewed this question
Top Gaggenau Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Gaggenau Kitchen Range Expert? Answer questions, earn points and help others
