Contributor
- Posted on Dec 25, 2008
Re: moto q formatting microdisc
B4 u format or do a master reset on ur moto Q8 first of all remove the memory card & then perform d master reset so that d files on d memory card wl not be formated or deleted.....its a common logic afterall...
MOTO Q NOT READING MINI SD...I CAN NOT EVEN FIND IT ON THE PHONE...I FOUND MEMORY MANAGER WITH NO OPTIONS...I FOUND STORAGE VALUES, BUT NOTHING SHOWING THE SD....WHAT IS THE DEAL?
Hi. I have the same problem. I bought my motorola Q8 about two months ago and i bought a 2gig SD card to support it. everything was running smoothly until i decided to try out the MASTER RESET function of the phone. After reading the manual, i knew that all the previous settings and files in the phone will be erased. But what irritated me is the fact that now, i can no longer open my files in the sd card. all i see is the small windows icon alongside the files in my card. Whenever i attempt to open a file, the phone prompt says "You have to run the application first before you open this file". The user-manual is useless!
I have the same problem. it started when i did a MASTER RESET on my moto Q8. After the reset, i can no longer open the files on my mini-SD card.. all i see are tiny window icons next to my filenames.. Attempts to open the file is met by a prompt that says: "You need to run an application before you can open the file" the problem is.. the user manual is of no help... i tried looking for solutions in the net.. to no avail.
