Question about Sony KP-51HW40 51" Rear Projection Television
Maintanence question obout my Sony rear projection.
I was given a 52in Sony rear projection tv, pretty sure it is a late 90's or early 00's. I have never owned a rp before so I am not sure if I have a problem with it. I have been told, by a friend, that the picture is cloudy and that the rp's have a fluid within the screen and that mine needs be changed. I was not aware they had fluid, the only thing I knew I may need at some point to change is the projection light within the tv. 1. Do rear projections have fluid within the screen? 2. If so can I change this myself? 3. And if I can change it, where is the access for this most likely located? Thank you for the help, Lee
    President:
  • 3,130 Answers
I havent heard of any sony RP picture tubes having bad coolent fluid inside them. Most sets that had that were Magnavox. On a RP TV set, open the reflection area , most of the time the screen gets removed, clean the mirrors and lens and turn on the set. look down inside the lens at each red blue and green picture. If it looks cloudy, the fluid will need to be changed. if it does not look messed up, you might have corrected the problem by cleaning the mirrors and lens. This is not a job for a Handi-man to do. It alot of work and too may things can go wrong. If you really like the set, contact a servicer to do this for you but I have seen this to cost up to 400 b ucks, Good Luck
Posted on Dec 29, 2006
I,m not a tech but i,ve been told by a techinican that those tubes do have fluid and it,s not an easy fix to change the fluid i was told the tube has to be removed and a tech told me it would run around 200.00 by the time the tech removes it puts the fluid back in and reinstalls it and after it,s reinstalled the convergance has to be reset that,s what realigns the colors back to their correct position and i,ve heard this isn,t an easy job so i,d probably get a techinican to fix it but that,s up to you someone might have an easier opinion but the tech i talked to is one of the best thanks and maybe you can help me i have a blue tube on my big screen tv that wont light upcould you give me some insite as to what you know about a projection light that you said that may need changed think that may be my problem your welcomed to call me about this at 270-566-4327 anytime soon as possible thanks
Sony 52in. Rear Projection kp57hw40
Yeah, it can be fixed. Let me know when Tv goes to Off, how many times its Standby light blinks?
Aug 02, 2008 | Sony KP-57HW40 57" Rear Projection...
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
I have a sony tv projection. Lately when the tv is on it flashes colors and blinks off. Can you help?
it flashes blue right? ive been having the same problem. i found a temporary solution is to unplug the TV from the wall for a few hours and then plug it back in. it will eventually shut off on its own again, but it allows you to watch for a bit, at least.
Jun 30, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony xbr-52in projection tv show double picture's
It sounds like a convergence problem. A fairly common reason for thisproblem is the convergence chips have failed. They are usually referredto as "STK" chips since the model number of these chips start with STK.I will put a link to another part of this site where someone has postedpictures and a link where to get the parts should you decide to fix ityourself. Look at Ecullier2012's posting. Jean's posted site will notfix this problem. Hope this helps you out. Let me know.
http://www.fixya.com/support/t1684874-screen_blue_green_green_red_outlines
Mar 08, 2009 | Sony KP-51HW40 51" Rear Projection...
I have a sony rear projection 52 in tv i need help with...
you can do it yourself if you can orer the part..its about 120.00 i think for the powerboard and then th time it takes you to put it in. if a repairman does it hes charging you at least 75.00 an hour for labor.
Feb 09, 2009 | Sony KP-61S65 61" Rear Projection...
Blue convergence
DO you have 2 possible solutions
1.--Look under the CTR ( picture tubes) for leak coolant , all the times this set leaking, if is positive, use alcohol 90% with a bottle spray, clean the area, tied screws gasket ctr and let dry for 6 hours minimum.
2.--Loose connections on the left chassis ( convergence board), re solder ( look for possible resistor born)
Aug 05, 2008 | RCA P52926 52" Rear Projection Television
Sony 52in Projection TV
Thanks for including your model number! Just change the lamp and it should be good to go.
Jun 22, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Rear projection tv broke
try resoldering the vertical output IC. This is a common problem the tubes blank out but sound and on screen displays still work 90% of the time its the solder connections on the vertical IC that causes it.
Mar 24, 2008 | RCA P52960 52" Rear Projection Television
Sony KP-51HW40 51" Rear Projection Television Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
