Question about Maytag Washing Machines
Maytag Epic Z MHWZ400TQ the metal circle that helps to seal the machine around the inner edge came out and i cannot get it back in.
Jimster
  • 240 Answers
SOURCE: Removing Tub from Maytag Atlantis Washer
I do believe that when you remove the four bolts, it should come out. Sometimes you have to use a little force and shimmy left to right to get it to break loose (no hammers please) especially if you have a lot of scum build-up from soap. They can really be a bear sometimes to remove. Maybe put your foot in the bottom of the tub and hit it on both sides to work it free. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: We have a Maytag Epic Z front load washing machine
You better not to separate the inner and outer tubs as it's quite a job and takes a lot of effort.
Try to remove the heater on the very bottom of the front half of the outer tub. From outside it looks like an oval metal piece with a terminal on each side, a nut (or screw) in the center and a plug with 2 wires coming to it. UNPLUG THE WASHER as the heater is connected to the hot wire all the time.
Remove the nut (or screw) in the center of the heater and pull the heater out. Now you have a nice opening in the bottom between the tubs. There is a heater bracket, made of a thick wire inside. Make sure not to damage it when trying to remove whatever there is inside. Make sure the heater is aligned in the bracket when assembling it back together.
Good luck.
Posted on Oct 13, 2009
SOURCE: Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Posted on Jan 26, 2010
jsrock516
  • 5911 Answers
SOURCE: Seal is ripped
Yes, the door seal (bellow) can be purchased and replaced. The following link explains step-by-step how to change the door bellow on a Maytag Epic front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The firsat three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful. NOTE: Maytag Epic is manufactured by Whirlpool, so these instructions will apply.
Posted on Apr 30, 2010
Testimonial: "Thanks so much for your help!"
SOURCE: Maytag Epic Z Washer has object between drum and tub.
did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Posted on Jul 24, 2010
The metal wire ring fell off the rubber seal at opening and the seal is also off centered I have a matag epic washer
With it being off centered and the seal retainer coming off what needs to checked is the concrete counterweight thats bolted to the front of the tub has come loose and wobbling free.
Gene
Aug 05, 2011 | Maytag EPIC MFW9700S Front Load Washer
My epic front loader is make a very very load noise when in the spin cycle. Not quite at all.
OH,OH!!!, I think the main bearing is bad on the washer, see if the inner tub has play by moving it up and down. even if is not I'm sure the bearing is bad. with time and clothing weight the water seal worn allowing water to wash the lubrication in the bearing. this is a mayor repair.
Feb 09, 2011 | Maytag EPIC MFW9700S Front Load Washer
Seal is ripped
repairclinic.com
Apr 30, 2010 | Maytag EPICz 3.7 cu. ft. Washer
We have a Maytag Epic Z front load washing machine that is making a loud metallic noise during the spin cycle. The noise migrates radially around the tub as the drum spins. It sounds like pocket change...
Good luck.
Oct 13, 2009 | Maytag EPIC MFW9700S Front Load Washer
It sounds like an object has gotten between the drums. How do i remove the inner drum?
disconnect from power, and give yourself some room.
remove screws from rear of top and slide top back, then up to remove.
disconnect harness from control panel, etc then remove screws attaching it to frame and set aside.
now you can get to the outer front covers top screws and i believe there are some on the bottom too, but can't be certain from parts blow up photo, may just slip onto a clip.
then the inner drum support will be visible with rollers, seal, etc. and your there.
just watch the metal edges, it is often very sharp from the stamping process that cuts them out.
hope this helps,
best of luck,
ttfn
Sep 24, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
FRONT DOOR OF WASHER LEAKING
Hello. W/D here.
It's actually pretty easy to get it back on when you know the trick.
Since it has leaked on you, you may want to remove the seal off of the rim closest to the door and clean the rim and the sealing surface. The seal has a molded lip that fits on to a raised formed rim, and it gets pressed on snugly before the ring and spring are added. You can seat the seal by pressing on it all the way around with the palms of your hands.
To install the ring:
Start the ring 180 degrees from the spring, placing it in the groove behind the seal face. (You want to make sure that the seal is pressed back into place first). Work the ring on around the seal, until you get to mostly just the spring remaining. Now lever the spring over the lip and into the groove, using a small screwdriver, being careful not to damage the seal with the screwdriver.
Best regards, --W/D--
Aug 20, 2009 | Maytag EPIC MFW9700S Front Load Washer
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Front Load Washer Seal
you will have to take off the front off washer to put it back correctly.
remove the top panel 3 screws in top rear
remove the bottom panel 3 screw in bottom front
remove the top led control panel 3 screw or more along front lip
if you disconnect any wiring mark it well .
now the front of washer can be removed with or without the door (your choice)
careful with the door lock wiring.
be sure to unplug the washer.
while you are in the innards its a good time to wipe around the drum any buildup of soap etc..
and to clean the filter trap in the bottom access tube below drum.
Mar 31, 2008 | Maytag EPIC MFW9600S
Washing Machines Logo
79 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
