Question about Disney DTD1363-CAR 13" TV/DVD
Dvd is not working, tv work just fine
I try all kind of dvd and for all of those says "error" after trying to read them. What should be the solution?
  • buzzcore34 Jan 01, 2009
    my sons lightning mcqueen dvd player wont read dvds at all but the tv itself works fine.please can anyone help.
  • Anonymous Feb 01, 2009
    the tv works the dvd works with some dvd's but not with other..i bought 4 dvd's yesterday and none seem to work
My grandson's Lightning McQueen dvd player was acting up. The tray would come out about a 1/4 inch and then go back in. Once I got the tip on how to remove the case, I was able to access the dvd player. You must remove all four screws from the bottom of the unit. Carefully remove the smile from the front of the tray. After that you can slide the black tabs toward the front and get to the dvd player. To remove the dvd player, first carefully disconnect all the plugs from the back of the player, better to use a needle nose pliers than to try to grasp each connector with thumb and forefinger as you might inadvertantly pull a wire out of it's connector plug.. Now on each side of the player are two detent tabs. With two small pairs of pliers or needle nose pliers, pull the detents out a little on both sides and then the dvd player will slide out. It helps if you have a third hand to pull the player while you gently pull the detents out a bit. Once out, I removed the four bottom screws and the two top ones that are under the silver tape. Lift up the top from the rear and slide back a little then off. Once the metal cover is off, you must remove the four screws that hold the plastic part of the player to the metal base of the case. I discovered that the tray had jumped off it's track, or rather was probably forced off it's track by my grandson's pulling or pushing the tray too hard. If the tray comes out manually, then the small drive belt from the slide motor is probably suspect. Replace the belt. If the belt is ok, but the slide is off it's track, then carefully pull on the sides outboard from the tray, I was able to put the tray back on it's track. It's a small white pin or tab that rides inside a long track on one side of the tray. Leave the tray slide out while you are putting the four screws back in holding the player to the metal base. Put the metal top back on with the open end on the slide end and press is down onto the metal base. Replace the top two and four bottom screws. Before you slide the player back throught the detents, aim the extended slide throught the slot in the front of the case and snap the smile back on. If you don't have the slide out and it gets pushed back into the player, the slide will lock in and you won't be able to snap the smile back onto the front of the slide. After that you can pop the players notches back into the detents. Plug all connectors back into the back of the player. Align the tabs through the slots on the bottom of the unit and slide them back until the four screw holes line up. Put the four bottom screws back in. Put the cover back on allign it so that the two screws that go to the case on each side that were hidden by the fenders. Replace the top two screws and the two counter sunk screws where the video and audio inputs are on the back. Replace the wheels. Each wheel must go back on it's correct side, Line up the tab and the space in the back of the wheel and push the wheel back in on each side. Replace the three screws in the middle of each wheel and put each fake lug nut back into place. Use a small pair of pliers to gently squeeae the tabs of the lug nuts so that they will go in the slots easier. Plug the unit back in, turn on and after you select dvd, then you can press the open/close button for the tray to come out.
No parts were needed, as the one small drive belt that comes off the tray motor had not stretched or broke. Great patience is needed just for the removal and replacement of the back of the case.
Posted on Jan 04, 2009
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
After warranty time expires (2yearsd) my LG LRY-517 DVD combo recorder/player start to make randomly disc reading errors. During half year things has going worse. Now the situation is that it does not play...
Use lens cleaner disk to run many times. It cleans the lens and also runs cd on the disk which eventually will get rid of moisture on the circuits and restore your dvd recorder on the LG unit.
Mar 11, 2011 | Televison & Video
NEC DVD +RW - 6650A will not read a blank DVD
i ran into this problem a while ago. I had to test different dvd's. I then looked on the manufacturer's website. there they stated which dvd-r, dvd-rw would work. once i tried that brand It worked fine.
Sep 10, 2009 | NEC ND-6650A DVD RW Dual Layer Burner
DVD Player won't work
DVD's: does it display any kind of error? All DVD's?
To your second question.
The manual explains cable and TV hookup for CABLE but there is no mention of off-air TV tuning.
If you don't have the manual go to:
http://www.retrevo.com/support/Motorola-DCP501-Receivers-manual/id/393bh936/t/2/ and register to get it. It's free.
Mar 09, 2009 | Motorola DCP-501 Receiver
Message reads NO DISC on Advent model DV1418A
Is the disc an original DVD or copied. If it is copied and the DVD is old the DVD will not read it and tell that there is no disc. You also need to have the laser checked. Did it do it for a number of disks or just one. If you have only tried one disk, try another
Jun 08, 2008 | Recoton Advent Advent DV1418A 14 in....
I can't play any DVD's. It keeps saying cannot read.
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 25, 2008 | Panasonic DMR-ES25 DVD Recorder
Phillips DVD combo TV.DVD
laser has gone not worth doing to expensive £60.00 plus
Aug 19, 2007 | Philips 13MDTD20 13 in. TV/DVD Combo
Mickey Mouse tv/dvd combo
Try to get other disk to read if you can not you may have a lens problem and will have to clean it. I would suggest using a fiber optic cleaning kit. You can find them on-line I beleive.
Aug 06, 2007 | Disney DTD1363-CAR 13" TV/DVD
Panasonic DVD-RV32 DVD Player-No image on RCA output
Hi Obviously the unit is playing the disk because your audio is fine, and getting some kind of black & white picture out of the composite, means that the video processor is probably ok. The most likely things to check then is the yellow video cable, (just swap the red or white in place of the yellow on both the DVD and your tv to test), or possibly the yellow RCA jack on the back of your DVD has gotten loose. If you have not done so, try wiggling it gently to see if your video comes back. If it does, and you are handy with a soldering iron, you can probably repair it yourself. Other than that, it would be a problem for a repair shop. (and a strange one!) Hope this helps, and good luck!
May 17, 2007 | Panasonic DVD-RV32 DVD Player
Error code 2881
Well Im going through the same thing and no one can seem to figure out what is going on. Ive tried all sorts of disc including a DVD-RAM Video 60 and Im still getting the same Error #2881 Code.
Nov 22, 2006 | Hitachi DZ-MV350A DVD Camcorder
Disney DTD1363-CAR 13" TV/DVD Logo
282 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
