Question about Telex Replica Single Cassette Deck
Telex Relica Cassette Copying
I have a problem with Telex Relica duplicator that when copying the cassette on both sides and the recording is blended together on both sides after duplicating the cassette once palyed back on the casstte player.
Can you tell me what cause this issue or do I have bad heads that may need changing..
3 Suggested Answers
  • 579 Answers
SOURCE: telex copyette 1-2-3 you can hear both sides at the same time
Clean the heads, oil the spindles.
Basic problem is the tape alignment is off a little. Could be caused by too much tape tension causing it to wander.
Hope Ya Fix It. So ya can spread the word!
Posted on Feb 10, 2008
SOURCE: How do I acquire a Telex Manual to give directions
i dont now........................
Posted on Apr 18, 2011
Sony CCP1300 Cassette Duplicator delayed start on B side in A+B recording.
The delay allows for the leader to pass the record head until modulation (sound) is detected. This is a normal design feature
Jun 18, 2012 | Sony CCP1300 Monaural 1-to-3 16x Master...
Everytime I try to copy a tape, there's a big noise on the duplicate ones, even if the recording level is zero! I cleaned the heads with alcohol, but the problem remains. I have a TELEX ACC-4000. Many...
Is this a big bass hum?
Are you in the USA?
These are all mostly pretty old units by now but pro equipment none the less.
It's got circuitry problems but may be worth repair as I'm not sure anything like this is made anymore.
Sep 21, 2011 | Telex Copyette 1-2-3 Single Dual Cassette...
Our machine does not seem to be copying on all the cassettes. One is the only one that is working now and it is recording at a delay.
Is it that they are all working maechanically, but the recordings are duff? or mechanically it's failing?
If it's recordings, the heads will need cleaning and degausing.
If it's mechanical, probably the belts require replacing and the unit needs a service
Jan 07, 2011 | Telex Copyette 1-2-3 Single Dual Cassette...
Can I use this machine (telex copyette 123)to cancel old cassettes by copying a blank cassette onto three cassettes??
You should be able to do that with it, but note that this is a mono copying machine rather than stereo, so it may not entirely write over the existing recording if it is in stereo and the heads are in a slightly different position, but that would be the same for a stereo recorder too.
I think it will work, but really for decent recordings, I wouldn't recommend 'recycling' tapes in this way, they deteriorate fairly quickly.
Aug 10, 2009 | Telex AUDIO DUPLICATORS: Mono 1-2-3 Single...
Problem copying from cassettes or vinyl.
CHANGE RCA JACKS ,,COULD BE A BAD ONE,, ALSO ,,TRY BLOWING IT OUT
May 15, 2009 | Aiwa XC-RW700 2-Disc CD Recorder
Telex copyette
Mechanism is not switching probably due to slack belt(s)
Apr 12, 2008 | Telex Copyette 1-2-3 Single Dual Cassette...
Telex copyette 1-2-3 you can hear both sides at the same time
Feb 07, 2008 | Telex AUDIO DUPLICATORS: Mono 1-2-3 Single...
Telex Replica Single Cassette Deck Logo
54 people viewed this question
Top Telex Audio Players & Recorders Experts
Ben Armstrong
Sam Palermo
Sam Palermo
jairo sanchez
Are you a Telex Audio Player and Recorder Expert? Answer questions, earn points and help others
