Question about Whirlpool LER4634J Electric Dryer
Door switch broke off
The door switch broke off my dryer-is there any other way to turn dryer on?
  • 1 more comment
  • nojelle2002 Nov 16, 2008
    where is the filter opening? how do I know if it is a top mount filter? I want to bypass the door switch option Thanks!
    Where is the filter opening?? How do I know if it is a top mount filter?? I want to bypass having to use the door switch. thanks
  • Anonymous Mar 26, 2014
    the small tab on inside of door broke offKenmore dryer
    Genius:
  • 1,028 Answers
No either replace door switch or bypass it ..remove screws at filter opening(if its a top mount filter) pop clips each corner at edge of and lift top switch
Posted on Nov 16, 2008
Kenmore elite front load dryer has power but won't turn on. It beeps once like OT is going to start but nothing
check to see if the belt broke,there's a switch on the belt pulley on some models,if the belt snaps from to large a load the pulley doesn't have any tension on it and the switch opens so the dryer won't run.when you put the belt back on the pulley sets the switch so power will go tough it again and the dryer will run,also check the door switch,if someone shut the door to hard and broke the switch the dryer won't run.these are the easy things to check without needing a meter.hopeit helps,if you're in mass. and need a tech you can call peter de's appliance 781-438-9442 very good techs
Jan 26, 2014 | Kenmore Dryers
Won't start
2 reasons a dryer won't start, either the door is not closed (or the door switch is bad), or the belt that turns the drum broke. The dryer has a switch on it that will shut off the dryer and keep it from starting if the belt is broken.
Aug 02, 2013 | Frigidaire Dryers
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
Door switch broke
The drier will not operate without the door being secured for safety reasons. There is power running to the switch and once the door is shut and the lever,or the "spring" is pushed in it allows the power to turn on.Almost like a light switch. The door switch will have to be replaced. This is a very easy repair. The switch can be found at your nearest appliance store or online. http://www.appliancepartspros.com/whirlpool-dryer-door-switch-3406107-ap3132865.html
Oct 26, 2012 | Roper RES7646KQ Electric Dryer
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
My dryer light will not shut off even when door closed and it will not start up when in push start button it does a rapid beep
is the door switch broke?first what kind of dryer and send the model number,when the door closes it hits the door switch and shuts the light off,the dryer will not run if the switch is broke,it's like trying to start the dryer with the door open if the switch broke.
Apr 25, 2011 | Dryers
Kenmore Series 80 dryer, working open the door to check load, close door, and now it won't start. Any ideas??
The door switch broke...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2010 | Kenmore 63942 Dryer
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
How do I bypass a door switch for my Whirlpool dryer-
take the top loose on the dryer to acces the door switch. If it is the old style it should have a metal suround over the black switch. If the metal arm piece has broke, Ttake it off and tape the white button down to make it run.
Nov 21, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
725 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
