Laptop battery is not charging
My mother plugged the laptop with the wrong adapter. Then suddenly it smells that there is an electrical fault. I've unplugged it. I try the laptop after few minutes. Everything seems okay but the charging of the battery is not working. There is always a need for plugging the adapter for it to work. I am hoping for your favorable response. Thank you very much.
  • 4,806 Answers
You need to repalce the battery, it will only work on AC power only now as the power surge damaged the battery, thank your lucky stars that the surge didn't blow the whole laptop because 98% of the time it does!
Posted on Nov 16, 2008
Gateway ZX4300 - power adapter problem
Verify all specifications of your previous charger and new chargers/adaptors.
Jun 24, 2013 | Computers & Internet
HP 425 laptop does not charge
The first steps you could apply are-
1. Check the plug points. Test some other charger on the same plug point. If it's working, then go for the next step.
2. Use an alternate charger. If you have a friend with the same laptop / same charging adaptor, borrow it and see whether the laptop is being charged from that. Or you could go to an electronics
shop and see whether they have a spare charger just for checking purposes. If no adapter works, then it's not the adapter's fault, it's the fault of the laptop charging port.
3. To be sure, you could attach your adapter to an extension cable (a spike guard would be suitable. It prevents sudden peaks in current, thereby protecting your laptop from damage) . If it doesn't charge still, it's a fault within the laptop.
To check the charging port within the laptop, you'll have to go to a hardware specialist (assuming that like me, you're not adept at hardware!) . The specialist should guide you properly.
If the laptop is within the warranty period, you could try the service centre. Hope I've helped :)
Replacement HP 425 AC Adapter 90Watt 19V 4.74A Option
Nov 24, 2012 | HP Computers & Internet
Gateway nv52 won't charge
It sounds like you either have a dead mother board or a bad power inlet. Did the machine work with the new battery while it was charged? If so, then the battery connector was good and the inlet was bad. If not, your motherboard could be dead. I've also seen where a bad battery connector would syphon off enough power to not power on the machine or charge the battery.
Nov 14, 2012 | Gateway NV5215u Notebook
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Even when laptop is plugged into an electrical outlet, it will suddenly think it is not and drain the battery power..the indicator lights will flash and battery power will drain.
There may be a fault in the laptop's power supply adapter.
Try testing its rated output voltage versus the actual with a multimeter.
If the adapter comes in 2 sections, 1 cord from the wall to the adapter, and then the adapter to the laptop, be sure to test both sections.
Replace the adapter if required.
Also check that the connection socket where the power adapter plugs into the laptop is not loose and preventing proper electrical contact.
Good luck.
Feb 28, 2011 | 4D NSpire Power Supply NSP-300P4D 300W...
I have compaq notebook pc...using vista... my battery was working perfectly fine. suddenly, now when i plug in. it says, 0% available , plugged in not charging. i have tried uninstalling and then...
how old is the laptop?
either your battery has developed a fault or the laptop connectors have developed a fault therefore not registering the battery output.
also check the ac adapter.
Jul 09, 2010 | Compaq Presario Notebook
Laptop died suddenly and is not charging
Take the battery out and discharge the capacitors by holding down the power button for 15 seconds. plug in the charger without the battery in to see if you get a charge light. If you do, replace battery and plug in charger and power on laptop. If this does not work, you may have to pull the cmos battery for 15 minutes and try it again.
Oct 03, 2009 | Computers & Internet
Laptop won't turn on
No I think U have problem with ur mother board..
Nov 29, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
