Question about Dell Computer Refurbished PE3250 SYSTEM BOARD Computer (K3156) Motherboard
Problem with Dell Inspiron 1100 series laptop
My laptop seem to be functioning okay although the fan was cutting on more frequently. My problem is that it will not boot, it will appear to switch on and power up but never get to the boot window screen and just turns itself off after about 5 seconds. Would the fan not working cause the system to shut down for saftey reasons? I received no errors prior to it not working, just shut it down after use. I pulled the whole system apart, down to the fan, and cleaned everything. Monitor is working. Thank you for any help, Lee
  • 1 more comment
  • Anonymous Jun 14, 2008
    Pls can anyone help; my cd drive does not write data onto an emty disk even though the drive ie a CD-RW
  • Ozo2010 Jun 14, 2008
    Can anyone kindly help; I can't burn CDs with my CD-RW drive anymore. I use DELL INSPIRON 700M. It shows a missing driver ( SCSI RAID)Controller erroe
  • ldddad Jun 30, 2008
    After approximately 20 seconds the screen goes blank. It is trying to default to an external screen. I have updated BIOS, Chipset and video, reset the Monitor choices so that the laptop is the primary, checked connections (internally and externally). Pressing Fn and F8 returns the picture to the laptop, but after a few seconds it switches back.
    Hope someone can help.
    Thanks
    Problem Solver:
  • 28 Answers
Most certainly a non working fan would cause this behavior. Laptops are much more susceptible to overheating. Fan failures can be hastened by regularly blocking the fan by doing things like using it on a pillow or soft surface. The behavior is exactly what you think.
Posted on Nov 26, 2006
  • Joe Swoboda Dec 04, 2006
    Good thought on the power issue as this sounds like a classic dead battery problem. Isn't there a widespread recall on Dell and Sony laptop batteries? I would try removing the battery completing and just booting with the AC adapter. If that works then it is likely that you have a bad battery. It hadn't even occurred to me the first time I read your problem.
    Scholar:
  • 111 Answers
I recently encountered the same issue with my 1100 it was caused by the metal casing on the video card bending upward when a previous owner removed the case I simple applied a large amount of pressure from the but of my screwdriver and hit power and there it was booting normally suprised me but now it is fully functional again
Posted on Jan 07, 2009
  • 624 Answers
Try unplugging your laptop and letting it site for an hour. If your laptop refuses to boot after it has been off for more than an hour I would doubt its the fan because an unmodified Dell laptop with a failed fan will not overheat that fast unless something major is wrong. Even if it detects a failed component (fan) it should display an error during the early part of the boot cycle. No video during the early boot phase is not typically a good sign, but I would also check to make sure the unit is getting power, LEDs are deceptive. The best way is to check the battery to see if it is fully charged. Dells have the ability to switch from the laptop LCD screen being active, to just the VGA connector on the back or both. If you have a working monitor around try plugging that in and starting up again. If you don't get anything try toggling which display is active. The typical Dell has a key in the lower left hand corner labeled "Fn" (function) in blue ink. Look for another key labeled "CRT/LCD" also in blue ink and typically is the "F8" key. Hold the FN button down and hit the CRT/LCD key once. If nothing happens try it again after 10 seconds, and again after another 10. The first click is to change from the LCD being active to CRT, the second changes from CRT active to both, the third goes back to LCD only again. If none of this works you are probably looking at a major repair, video controller circuitry is on the motherboard?..
  • tomj23 Dec 04, 2006
    Dell, Apple and several other manufacturers have a fairly extensive battery recall. You can check Dell to see if your laptop is affected at this web page:https://www.dellbatteryprogram.com/
Where can I get the ethernet controllor drivers for inspiron 1100
WINDOWS UPDATE OR GO ON ONE OF THE FREE FILE SITES LIKE TUCOWS.COM OR CNET.COM
Jul 14, 2012 | Dell Inspiron 1100, PP07L Series Laptop...
Drivers for inspiron pp7l
Go to the Dell web site and you will find drivers in support section
May 14, 2012 | Dell Inspiron 1100, PP07L Series Laptop...
Okay, machine keeps shutting off with an overheat warning message. Now the display is grayed out.
check the fan. if it is not rotating the fan has issue else heatsink needs to be replaced.
Feb 23, 2010 | Dell Inspiron 1100 Notebook
Computer Parts Needed
http://cgi.ebay.com.my/NEW-Dell-Inspiron-1100-1150-Cooling-Fan-AD4505MB-H03_W0QQcmdZViewItemQQitemZ370182398127
Aug 14, 2009 | Dell C3039 Inspiron 1100, 1150, 5100,...
Is there a stereo input for the Dell Inspiron 1100 to record?
Yes, the input is stereo BUT you need to configure Audacity to do the stereo capture. Go to File > Preferences. Once in the preferences dialog, go to the third Drop-down menu, and change from MONO to 2-channel stereo. That is.
Apr 27, 2009 | Dell Inspiron 1100 Notebook
Inspiron 1100 graphics upgrade
The Inspiron 1100 has an integrated graphics card, whereas the 51xx series are dedicated, so there is no graphic card upgrade option for the 11xx series.
Mar 11, 2009 | Dell Inspiron 1100 Notebook
Laptop won't dock
The inspiron 600M will not function in a D-Dock, but will work in a D-Series port Replicator. (Although the D600 and 600M share the same motherboard, the bottom plastics are different)
After trying the 600M in the D-Dock, it is possible the dock is damaged. I would undock the D630, then delete the docked profile. power off, dock, and reboot and see if it detects and works.
Jan 16, 2009 | Dell Latitude ATG D630 Laptop
Flashing orange light
battery charge counter is maxed. You need a new battery.
Dec 14, 2008 | Dell Inspiron B120 Notebook
Where i can find dell ----1100 inspiron ac adapter???
these are in plentiful supply on ebay.
or just look on craigslist.org
Apr 26, 2008 | Dell Inspiron/Latitude C-Series AC Adapter...
Computers & Internet Logo
1,293 people viewed this question
Alun Cox
